Question about Leviton Electrical Product 48210-VA Video Amplifier Module
Installed video amplifier, now cable will not work
The main cable into the house is connected to a two way splitter. From the two way splitter, one line goes to our internet modem and the other line goes to the input connection on the 48210-VA amplifier and a line goes from the output connection to the input of a six way 1000 mhz Leviton splitter. The amplifier is plugged in bit the cable TV will not work. I tired turning the fm switch on and off with adjusting the gain control but nothing. Cable works fine if I bypass the amplifier.
  • promaxus Jan 12, 2018
    There is not enough information here to answer. You have a six port splitter for some reason but you only discuss one TV fed from the splitter. What about the other TV's fed off the splitter, are they working? And if no TV's are connected, why is such a large splitter employed? There is loss through any splitter, and the more outputs involved the greater the loss tends to be.
    Also not sure what the fm switch would have to do with it, as you are passing RF frequencies to the TV. Really hard to diagnose as described.
3 Suggested Answers
kakee
  • 1269 Answers
SOURCE: cable company installed wireless router for
Make sure you can go online directly to the modem. If that is confirmed, you can connect the router directly to the modem and install it using the setup CD that came with it.
Posted on Oct 23, 2009
  • 69 Answers
SOURCE: A client of mine has
If you don't have physical access to the equipment, the shortest and easiest way to configure your leviton gateway would be to connect the linksys router to one of the numbered ports rather than the WAN/uplink port. That would bypass the DHCP server of leviton, however, you will have to do away with one of the PCs connected to leviton.
Please contact me for further clarification, if needed.
regards
Sandeep
Posted on Nov 25, 2009
Don't understand why local channels no signal it is not storming
Do you have an internal or external antenna? Does you have an signal amplifier, signal splitter or switch connected?
If the TV was previously connected to this antenna and received multiple channels, check the orientation. External antennas can turn under some conditions. With digital (ATSC) signals, this can be a significant issue, as the tuner may not see enough of the signal.
If there was an powered amplifier attached, check if the unit is getting power. Next check if the signal improves when the amplifier, switch or splitter is removed. In my house, usually only a few channels will be initially blocked by a faulty amplifier. In that case, the amplifier turned into a signal filter for a section of the VHF range. Replace the amplifier or switch if it faulty. If you are using a switch, try an amplifier/splitter that will limit the signal attenuation.
Use www.antennaweb.org or www.tvfool.com to check if where the antenna should point. Antennaweb.org assumes an external antenna and gives very conservative channel lists.
If the problem persists, check if another TV tuner works when connected to the antenna. You could connect a tuner box between the TV and the antenna as a solution. Tuners vary in signal strength sensitivity. Alternatively, replace the TV or the input board with the tuner. (If the TV is under warranty, contact the manufacturer. However, for most small TVs (under <32"), the repair costs are not worth the effort. Sites like www.shopjimmy.com can tell you if parts are available - this site specializes in parts from TVs that were damaged in shipping.)
I hope this helps.
May 24, 2018 | Televison & Video
No tv channels found on autotune . Aerial is in Loft.
To get a 6 way or 4 way signal, it has to be amplified. Does your splitter have a power connection to it. If you just have one lead going into a block and 6 outlets, that is for a high gain signal to go in that is already amplified. You can test by disconnecting all the leads but one. Use the closest set to the loft and use that one to get the sharpest signal by turning the aerial left and right. It has to be in the right direction and if it is off by just two degrees, you will not get a picture. Also aerials and better situated outdoors for the best signal.
Jun 23, 2017 | Televison & Video
Trying to hook tv up outside of house ran cable from box in my house wont run my tv outside can I buy hdmi ******* and have it work ? Thanks
I'm hoping you hooked the cable you ran for the outside tv to the output of the cable box and didn't make the mistake of splitting the cable that comes into the satellite box. If you take the cable that goes to your TV inside you should be able to put a splitter in it and run the TV inside as well as the one outside. If it is a long distance to the outside TV you may want to buy a powered splitter that amplifies the signal. You should also be using RG6 coaxial cable to cut down on lose.
Sep 22, 2014 | Audiovox Directv Rca Drd430rg Receiver...
How do I cable this connection please?
It depends what input connection the second TV has available. You cannot directly daisy chain HDMI cable from Apple TV to the two TVs assuming both have HDMI input. But you can purchase an HDMI 1x2 splitter and connect the 3 up provided the 2nd TV also has HDMI. The challenge maybe the distance you can have between the two TVs. Max is 15 meter but you could cascade 2 units to create longer distances.
http://www.ebay.com/itm/HDMI-Splitter-Box-High-Speed-Full-HD-1X4-4-Port-Hub-Audio-Video-1080p-Amplifier-/191120909726#ht_2675wt_1337
Apr 28, 2014 | Televison & Video
Hello,I have purchased a digital converter to connect to my tv to receive local stations,My question is,What do i need to connect all 4 tv's that I have to the converter? or Do i need a converter for...
The converter has only one tuner, this means it can only tune one station or channel at a time. The output of the converter is usually a single coaxial cable jack. The output is generally a user selected channel - often Ch 3 or Ch 4. When you connect the output of the converter to the antenna input of the TV, you set the TV channel to match the setting on the converter (again, Ch 3 or Ch 4).
You could install an amplified splitter to split the output of the converter and run a cable from each TV to the splitter, more on this amplified splitter, later. Set all the TV's to the same channel as the converter output (Ch 3 or Ch 4) and you would be able to watch whatever the converter is tuned to. This means ALL the TV sets must watch the same channel. What is showing on one will be shown on all. This may not be a problem if you live alone and own 4 TVs. You could simply turn one TV off when leaving a room and turn on another when entering a new room. This will be a problem if there are two or more people in the house that wish to watch different programs at the same time. To accommodate everyone, you would need as many converters as there are different programs that are to be watched on different TVs at the same time - 4 would be a good choice to provide the greatest flexibility of tuning for every TV.. You would simply install the additional converters on the other TVs just as you did with the first TV.
If you wish to use a splitter to divide the output of the converter to several different TVs (or have a single antenna and want to send the signal from it to several TVs for that matter), an amplified splitter is highly recommended. A standard splitter only divides the signal and has no provisions to boost the signal from the antenna. The more ways a signal is split, the less signal there is to supply to the TV sets. The result is a snowy picture. An amplified splitter not only splits the signal the way a standard, non-amplified splitter does, but also boosts the signal from the antenna to each TV. This provides a much stronger signal to the TV which results in a better picture. Pick an amplified splitter that has enough output jacks (based on the number of TVs you wish to connect).
I hope this helps and good luck!
Sep 13, 2011 | Televison & Video
Horizontal lines across screen picture going fuzzy in and out and then no picture at all
A horizontal line that rolls from the bottom to the top of the tv could be a Hum Bar. This is from a bad ground either for the house electric system or for the cable system. By code, these grounds are supposed to be connected (bonded) together. In other words, the electrical interference is going through your tv instead of into the ground. Fuzzy picture is usually from low cable signal. This can be due to bad cables, connections, or splitters or problems outside with the drop (cable line outside that runs to the house). Splitters, by design, lower the cable signal (i.e. a 2 way splitter cuts the signal in half). If you have unnecessary splitters you should remove them. If you have more than about 6 or 7 tvs, you may need to add an amplifier.
Jun 25, 2010 | Vizio VF551XVT 55 in. HDTV
My modem shuts off all the time and I have to keep disconnected it and wait to plug it back in.And then again for it to happen again often. The green lights on the modems only light up to 3 at times or...
You have a signal problem most likely. Too many cable splitters on the line that modem is on, therefore reducing your signal power. An amplifier will not help because most of the time this is an upstream related signal issue. The best thing to do for cable modems is run them a direct line from your de-marc point. This is usually in your basement in some panel (newer homes), or outside where your power and other utilities come in. Just make sure the line running to your modem is off of the very first splitter. For example you would have your main line coming in, go to a 2 way splitter, one leg to the modem, the other leg to a 4 way splitter that powers your 4 tvs in the house.
Of course it could always be the main line to your house is bad, or just that the modem is bad. But honestly - too many splitters and low quality cabling/splitters is 99% of the cause.
Nov 15, 2009 | Computers & Internet
Our first tv has a booster amplifier on the coaxial cable, i have purchase a new tv and need to know what product i need to us to attached the new tv's coaxial cable too. We have used a splitter box, but...
To have good picture quality you need zero DB (decibels) for one TV without a splitter. You can use and inline amplifier for each individual TV hooked up to the cable input with a output leg connected to each TV. If your house in wired in parallel (one main input hooked up to a splitter with all of the other TV's run off of the splitter) you can use a whole house amplifier hooked up inline between the input line and the splitter. If you house is wired in series (the input goes to the first outlet, then splitter to second outlet and so forth) each splitter knocks your signal levels down 50% each splitter. Amplifier placement depends on how the home is wired and how many TV's are in the home. Splitters can be either balanced (50/50 split) or imbalanced (75/25) etc. On a two way splitter 75% of the signal goes out one leg, while 25% goes out the other (usually for FM transmissions). If you have a three way splitter the signal is divided by the number of output legs. Splitters do go bad as well (sometimes only one leg). You can also buy an amp that is multi- port (which splits the signal and amplifies in one unit/ one input and 2,3,4 outputs). Amplifiers are electric and there is no way that the splitter can interrupt the power that would take all the signal away. If you meant that it drops the signal level so the picture is unacceptable, that's different. If you have another splitter in the house try using that one, the other might be bad. All in all you can purchase most anything you need at a Radio Shack and are very inexpensive. Amps can be purchased in different gains (boost). +10db, etc. I cannot believe that your cable company is giving you such minimal signal that 1. you need an amp?, and 2. that one splitter drops your picture to nothing? Your line extenders (amps for the lines that feed your neighborhood) might have problems or need adjustment by the lazy, cheap, cable co. also. I had problems with my cable company (when I had one) my modem would not stay online. 4 months later, they diagnosed the problem and my drop (RG56 cable line that feeds my home from their tap in the cable box outside) was bad. My friend could stay online and 2 months later comcast adjusted their amps (line extenders) in the neighborhood and then he was fine. I know this is a lot to digest, but I'm just trying to draw a clear picture so you can understand it all. I hope this helps and good luck!
Nov 07, 2009 | Televison & Video
Comcast Cable Down All Day Every Day
Here's some things to check:
If there are signal splitters on your cable for TV, computer, more than one tv, the signal is getting divided ...every splitter will weaken the signal.
Check for unneeded splitters, also there are splitters that have a wider frequency capability.
Consider upgrading to 2hgz splitters if needed.
Also I think that the more homes that are on the cable tend to make the signal weaker...I don't comcast would fess up to this, but I'm pretty sure it's true.
Make sure all your cable connections are snug and you may want to double check for corrosion etc. on each connection.
I resorted to a signal amplifier on my home. We've got comcast for cable tv and internet, with multiple tv's and multiple computers.
The amplifier (motorola) boosted the signal for everything and we've got way less dropped, frozen pix, black screens and the internet is back up to speed.
Comcast even came out and put a signal strength meter on the in-line to the house and stated it's within their limits... Glad I put the amp on the line..
Give it a try.
K
Sep 01, 2009 | Pioneer VSX-406 Receiver
Actually it a lnt5271f, but...
Your cable line coming to the house may be fine, but each device has a section of cable running to it separately. This will be coming from one or more splitters leading from the main cable. Follow the cable line that leads to your new problematic TV, to verify that both ends of the cable are firmly connected.
If you use a cable box then send the signal to this TV, be sure you have the cable/cables correctly and firmly attached/seated in order to get the full signal strength.
Also make sure that the cable is sound and not damaged or frayed in any way from end to end.
Jun 09, 2008 | Televison & Video
Leviton Electrical Product 48210-VA Video Amplifier Module Logo
47 people viewed this question
Top Leviton Computers & Internet Experts
ashburton
Michael Galve
Michael Galve
Are you a Leviton Computer and Internet Expert? Answer questions, earn points and help others
