Question about Microsoft Windows Vista Ultimate Edition
COM surrogate has stopped working
It is giving me error again and again that 'COM surrogate has stopped working'.how can i solve this problem in windows vista?
  • blakeclynch Feb 16, 2009
    same problem
  • Seb85 May 02, 2009
    com surrogate has stopped working . its telling me this all the time , what can i do pls ?
    Problem Solver:
  • 12 Answers
Try using the following link to solve your problem
http://www.howtogeek.com/howto/windows-vista/fix-for-com-surrogate-has-stopped-working-error-in-vista/
Thank You
Regards
Nikhil Mahajan
Posted on Jan 22, 2009
If I diable com surrogate will it harm my computer
Com surrogate is a service that allows switching on the com ports. Without it, communication to your devices will stop. If you're encountering this error there is a driver problem with your com port controller and you need to install the correct drivers.
Sep 01, 2014 | Microsoft Windows Vista Home Premium...
COM surroget not working
Here is a great trouble-shooter for your current issue.
Reference:
Aug 01, 2010 | Microsoft Windows Vista Ultimate Edition
''COM surrogate has stopped working.................
Sir COM means "Component Object Model". These are basically DLL files which are used for system tasks and if they get corrupted then you get same problem. For solving this you need to repaid your windows using windows disk.
Jul 21, 2009 | HP Computers & Internet
Com surrogate
These should help:
http://www.superbdevelopment.com/forums/general-tech-talk/3600-windows-vista-com-surrogate-has-stopped-working-fix-solution.html
http://www.mydigitallife.info/2008/06/13/how-to-fix-com-surrogate-problem-when-opening-video-format-files/comment-page-1/
Error message: "COM Surrogate has stopped working."
COM objects are often defined in Dynamic Link Libraries (DLL files). The Program file for COM Surrogate is actually dllhost.exe that can load a DLL and make its objects available to other programs.
The COM Surrogate error message is often related to codecs and other COM objects that aren't fully compatible with Vista. These are installed by other programs. The most common culprits are DivX and Nero. The first thing you should do is upgrade to the latest versions of these to see if that fixes the problem. Another possible fix is to disable thumbnail previews in Explorer. To do that:
In Windows Explorer, click Organize, then select Folder and Search Options
Click the View tab
Check the box that says "Always show icons, never thumbnails"
Click OK
To help troubleshoot which codec(s) might be causing the problem, you can use a free tool called InstalledCodec. You can use it to disable individual codecs one at a time.
You can download it at http://www.nirsoft.net/utils/installed_codec.html
Hope that helps
Mike
May 13, 2009 | Dell Inspiron 1521 Laptop
The desctop is locked
COM Surrogate errors The Component Object Model (COM) is a platform for developing software components developed by Microsoft and commonly used on operating systems such as Windows Vista, Windows XP or Windows 2003 Server. COM has been known under many names over the last few years including OLE, ActiveX, DCOM and COM+. Essentially it is designed to allow for easy re-use of software.
So what are these errors? COM Surrogate errors can occur when something wrong happens when software uses in-process components outside the main process either on the same machine or on a remote server. The default DLL surrogate (Dllhost.exe) can act as a host for in-process components. This is often used on Windows Vista, XP or Windows Server 2003.
According to Microsoft
"The file Dllhost.exe is an executable component that you can run remotely and instruct to load any in-process component, providing the component with a surrogate parent process and security context."
How to help fix this? Usually some software is out of date on your PC. You could try updating your software components. You might try updating software like Nero or DivX as this often happens with media software players for video files, music or MP3s. Other people have reported success by using QuickTime or Real as an alternative to using the software that caused the previous errors. Here is what you need!!! Click on the Above Link. Follow Each and Every Step!!!
Hope This Helps!!! Please Rate my Response!!! Thanks!!!
ROGER
Mar 13, 2009 | Microsoft Windows XP Home Edition
My computer is hanging
when i start my pc its come after 5 minutes it hangs and it not's work & Task manager also not works and main problem no antivirus is there but recently i have done Malware Anti bytes software but no virus is there plz tell me how to solve this problem and my pc is slow
Jan 17, 2009 | Computers & Internet
COM surrogate stopped working. What can i do ?
Easy solution, click start, control panel, system. choose advanced system settings. Under the tab of advanced you will see performance, click on settings for that. Choose the tab that says data execution prevention. Click the button that says turn on DEP for all programs except for the ones I list. Then click on add. The file is in windows, system32 folder c:\windows\system32 and the file name is dllhost.exe You will add it to the list as described and press apply this will prevent the error.
Dec 06, 2008 | Microsoft Windows Vista Ultimate Edition
Com surrogate has stopped working
http://fileforum.betanews.com/detail/Vista-Codec-Package/1159994557/1
Just download this small program and everything should be just fine . I was having the same problem , ive been told that its because of nero or divx codecs , didnt unistalled anything just installed this program and my problem was solve !
Nov 28, 2008 | HP Thin Client - AMD Geode NX 1GHz - 256MB...
Com surrogate and run ddl 32 problem
download codec pack and install it, ex - k-lite codec pack its free on net
Nov 11, 2008 | Microsoft Windows Vista Ultimate Edition
Microsoft Windows Vista Ultimate Edition Logo
293 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
