My crosley washing machine vibrates bad in the spin cycle. it is level and clothes are evenly distributed
  • 159 Answers
SOURCE: Noise at end of spin cycle
Sounds like the drive block is defective. The drive bloce is a aluminum part that attaches the drun to the gearcase. If you remove the agitator you will see a large nut on top of the basket. If the drive block is worn yo will see aluminum peices on top. It is very simle to relace. You will need a spanner wrench to remove the nut. With the nut removed lift the spin basket up and out. Remove the block. You will see that the new block will only fit on one way. Tap it down untill it will not go any further, replace the basket, make sure you tighten the nut securly replace the agitator and you will be back washing.
Posted on Jul 12, 2007
  • 641 Answers
SOURCE: Machine vibrates excessively during spin cycle
Open washer's cover and look for a released or a malfunction shock absorber. Good luck!
Posted on Sep 04, 2007
NitrusInc
  • 326 Answers
SOURCE: Kenmore washing machine shakes violently
There is the tub that spins on the bearing the " the active tub"(the one the clothes go in obviously) and around that tub is the "stationary tub", between the two are what they call "snubs" these are either rubber wheels, bushings or on cheaper models just a rubber boot that works as a shock absorber if you will, and keeps the movement of the the "active tub" with in its axis. If a wheel is broken, or a bushing/boot is torn or broken then there lies your problem.
I hope this helps.
Posted on Apr 23, 2009
SOURCE: spining makes noise and machine vibrates a lot
All machines vibrate and make sound while spinning including front load. Dont worry, its perfectly fine
Posted on Sep 01, 2009
reddyanantha
  • 205 Answers
SOURCE: tub is banging loudly on spin cycle . machine is leveled
please check the shock obsorbers and replace them if they are not holding the drum.
Posted on Dec 14, 2009
Why my washing machine vibrate when spinning
if it only vibrates when in the spin cycle turn off the machine and cloths distribution re-balance you have to many heavy cloths on one side of basket. Turn it back on and let it continue this should solve your vibration problem
Jul 13, 2015 | LG Washing Machines
Ds codemkeeps coming up even though the door is shut
The "dc" error code indicates an unbalanced load is preventing your washer from spinning properly. Try redistributing the load, then press the Start/Pause button. If the load appears well-distributed, you may need to make adjustments to the leveling legs to make sure the washer is properly leveled, removing the clothes and running a spin only cycle to make the necessary adjustments. Once firmly leveled, be sure the plastic leg locks are tightened to prevent them from vibrating loose.
Apr 14, 2014 | Samsung WF337AA Front Load Washer
I have a whirlpool cabrio model wtw6600sw0 ans my washer tub is unbalanced and rocks bad. i have leveled the machine and evenly distributed the load! could there be something wrong with the tub or...
after you leveled the washer did you turn the locking nuts on the legs up against the bottom of the washer cabinet to keep the legs from vibrating back out of level?if you dont lock them they will change height during spin
May 06, 2012 | Washing Machines
My washer jumps and moves accross the laundry room during the spin cycle. We have made sure it is totally level and made sure there aren't a lot of clothes in the washer at one time.
You have a wash Load Unbalance, as you have done, ensure the clothes are evenly distributed in the drum, so it is either that or the balance weights have come off the drum inside...I have also seen it when a bearing has gone bad. probably going to have to get someone to have an inspection.
Feb 04, 2010 | Kenmore HE2 Plus Front Load Washer
Whirlpool LSR8233EQ0- The load is still wet after spin cycle
Inner tub loose or bearing or stem is bent. Check belt for oil or wear.
Oct 20, 2009 | Washing Machines
On the spin cycle my miele walks acrossed the floor
make sure you loads are balanced, put heaviest clothes in first... if you can rock it by hand then the legs are not adjusted properly. If you stand 2 feet away from front of machine, jump up and down and see it move the floor is soft and you need 2 sheets of plywood to make 1 1/2 inches put under the machine
Aug 06, 2009 | Washing Machines
Major shaking during spin cycle
I have the exact same washing machine with the same problem. It is a poor design and Maytag knows it. We should be entitled to a refund. This was a very expensive machine.
Apr 13, 2009 | Maytag Neptune MAH6700A Front Load Washer
Shakes during spin cycle
Most out of balance problems are from the clothes in it. Stop it, move the clothes around - kind of even out the load and try again.
Mar 29, 2009 | Washing Machines
Roper RAX7244EQ1 Vibrates during spin cycle
Dear customer
Please perform the following checks
This may be a spin problem or a drain problem
Drain:
  • Make sure the drain line is clear
  • Check the drain hose for a partial blockage
  • Inspect the water pump
Spin:
  • Test the lid switch
  • Test the timer control
  • Test the centrifugal switch
  • Test the water level switch
  • Inspect the motor coupler
  • Inspect the drive belt (belt drive only)
  • Inspect under the washer for soot (clutch)
  • Test the motor
  • Inspect the pulley
  • Test the transmission
Please rate this,Thank u
Nov 21, 2008 | Roper RAS8445KQ Top Load Washer
Noisy spin cycle on washing machine
hi there,
Most noises from a washing machine occur during the spin cycle. If you hear loud thumping/or sound
during the spin, the load of clothes may have become unbalanced. Stop the washer and
redistribute the clothes, then re-start it. Repeat these steps if necessary.
Dec 11, 2007 | Zanussi FLE1416W Front Load Washer
Washing Machines Logo
81 people viewed this question
Top Washing Machines Experts
