Question about Kenmore Vacuums
Kenmore intuition bagless suction problems
After sucking up a pair of stockings that got stuck around the roller brush and finally got it out. There seems to be no suction at all when I run it on the carpet, I cleaned the filters and the dirt collector. There is suction but not for the main floor.
The flaw is in the design. The roller on these things will go bad on you eventually as the roller motor is incorporated into the roller itself rather than being belt driven. To seal against hair and dirt from getting into the roller bearings there is felt around the surface of the roller towards the end, this felt looses its shape over time and lets the hair get in and do its damage. I have had to replace the roller twice and am not looking for solutions to replace the felt with something a bit more sturdy.
Posted on Apr 10, 2013
SOURCE: Kenmore Progressive Model # 116 25914507
I had the same problem with my vacuum. I called in for technical service and was told to push the "reset button". It turns out that there is a small red button right next to the dirt indicator light. I pushed the button, plugged the vacuum back in and started it up and it worked like a charm! :) Hope this helps!
Posted on Mar 26, 2008
SOURCE: no suction with Eureka Boss Pro Lightweight Bagless Upright, 411A
I checked the vacuum hose to see if there was a clog. 1st, disconnect the hose from the unit so you have access to both ends. Now, place a marble or other ball in one of the hose and see if it will make it all the way through. I found a major "hairball" about 8-10 in down from the vacuum end. I took a metal cloths hanger and bent it in half and did a "roto-rooter operation. It took about 30 minutes, but now it runs like new. I hope this works for you.
Posted on Nov 17, 2008
SOURCE: bissel proheat 2x main suction problems
bissel pro heat x2 does not suction up the cleaning fluid
Posted on Sep 09, 2009
  • 73 Answers
SOURCE: Capture bagless not sucking!
Both ends of the hose will unscrew, allowing you to push out hair and fiber clogs with a broomhandle. There is a coarse filter above the dustcup which will release with a 1/4 turn counterclockwise, allowing you to remove the hair and fiber bundles trapped in the inlet. The filter below the dustcup also tends to clog. Anything more and you have to start getting out the hand tools. bgovan445@live.com
Posted on Feb 28, 2010
  • 294 Answers
SOURCE: No suction on floor part
From your problem description, you may have a blockage in the foot. Check the intake under the vac by the roller.
Posted on May 02, 2010
No suction
check for clogs and maybe the brush roller is too caught up with hair and fabric from the carpet.
Mar 16, 2010 | Dyson Ball DC24 Bagless Upright Vacuum
I have a Kenmore Progressive Inteleclean Upright vacuum cleaner (with Bag) . It has good suction only through the hose now and none through the bottom for cleaning carpets. and, there is a noise like it...
Theres a little bendable neck that hose with suction plugs into. Thats the one thats clogged. You will have to fish it out by taking off the roller and clearing the clog.
Sep 22, 2009 | Kenmore Progressive Bagless Upright with...
My eureka 437 stopped sucking
I believe the filter on your vacuum is clogged. Bagless vacuums require the filter be brushed or washed and dried, If they are not, the filter will clog, resulting in the reduction of suction. Clean filter about every 3 months or sooner if the same problem happens again. Hope this helps.
Aug 20, 2009 | Eureka Vacuums
My VAX Vacuum has lost ALL suction power. I've
vax power pet 1 filter keeps getting clogged up so dirt not going into cylinder
Jul 05, 2009 | VAX Appliances Vax X5 Bagless Upright...
Not picking up fuzz
I've had a similar problem with my DC07 Animal, although there WAS suction and the machine seemed in otherwise good condition, the vacuum seemed to be working normally, yet very little was vacuumed up. I would go over and over sections of carpet and get very little debris in the container. In my case, the cleaning brush roller bar was competely covered in debris (hair, dirt, string, stuffing from our chewed up dog toys, etc.). I removed the bottom cover and manually removed all this debris from the cleaner/brush roller, reattached the cover and it worked like new with great suction.
Apr 04, 2009 | Dyson DC14 Animal Bagless Upright Cyclonic...
Only suction to attachments
Something is stuck in the throat of the floor head, between the brushes that turn, and where the hose connects at one side (usually right hand side) of the floor head.
Reply back what you find.
Feb 04, 2009 | Kenmore 35912 / 35913 Progressive Upright...
Roller brush on x5 chipping apart
Not too good, but there are motor problems with these models all the time. Personally I do not know it can be fixed without replacing 3/4 of the machine, which can be pricier than a new higher quality sweeper. I work for a repair shop/ dealer so if you need some assistance let me know.(570)326-1731
Feb 22, 2008 | VAX Appliances Vax X5 Bagless Upright...
Doesn't suck
you need too change the belt on the bottom where the brush is take off bottom cover and underneath is the belt if its broke replace it
Dec 22, 2007 | Kenmore 35912 / 35913 Progressive Upright...
Vacuums Logo
91 people viewed this question
Top Kenmore Vacuums Experts
Are you a Kenmore Vacuum Expert? Answer questions, earn points and help others
