Question about Vicks Starry Night - White/ Blue
The motor in my humidifier was extremely loud and now it has stopped working. Do I need a new motor? Would it be cheaper to buy a new humidifier?
2 Suggested Answers
  • 188 Answers
SOURCE: My new humidifier hardly puts out any steam, and
make sure you mix 1-2 tablespoons of table salt with the water and stir until the salt dissolves.
Posted on Feb 17, 2011
Vicks warm air humidifier replacement part
Does this help you? http://www.appliancefactoryparts.com/humidifiers/vicks/v5100ns.html
My OX husband trod upon his new humidifier LOL...broke the tank and I cannot stop leaking. Anyone have a site where I can buy just a Vicks tank?
Feb 18, 2013 | Vicks Warm Mist V745A 1 Gallon Humidifier
Rattle noise
if you just got it check for packing material stuck around the fan area
if there is nothing , then take it back for a warranty exchange as it is not as described ---quiet
Jun 26, 2017 | Honeywell Humidifiers
Kaz 2100 Warm Steam Vaporizer was stored empty for about an year. Today I filled it with water, plugged it in, waited and waited...... no results. Wouldn't start. There is no buttons to push, nothing to...
Chances are the rubber pump inside the unit cracked and will not work anymore. This type of unit is a "Disposable" unit and is not intended for repairs. Its cheaper to buy a new one then buy parts for this.
Hope it helps.
Jan 28, 2011 | Kaz 2200-6 2 Gallon Humidifier
Usually very quiet when running. I went to turn it on this evening and the motor sounded very loud.
Bearings are failing in the motor very common problem try grainger.com you will need info off the motor to match it up. They have awesome tech support for matching motors and cheaper than the oem.
Dec 17, 2010 | Honeywell HCM315T 3 Gallon Humidifier
My aprilair's humidifier motor began to make loud squealing noise
Put some lubricant, oil, WD40, etc. on shaft of fan. Spin the fan with your finger and work the oil into the shaft until the fan spins freely again. Reassemble and problem will be gone for 2-3 weeks. Repeat again until you want to replace the fan motor.
Dec 31, 2009 | Aprilaire 700 Humidifier
Aprilaire 550 makes extremely loud grinding noise when turned on
yes it should be bypass but solenoid could be trying to open but the voltage to it may be to low if you have 24v ac power at the 2 small wires. but to change shut down power to furnace and water to humidifier.you loosen the 2 compression nuts unwire they cant be reversed so dont worry then 2 mounting screws then reverse to install
Dec 17, 2009 | Aprilaire 550 Humidifier
Loud noise
Try checking the pick up tube that spins from the motor to the resivoir. If this is not seated properly or off balance even just a bit, it can cause your humidifier to sound like a small waterfall. Hope this helps
Aug 01, 2009 | Vicks Cool Mist V400 Humidifier
Loud clicking, banging noise
We recently had the same problem. After cleaning both the furnace filter and the humidifier water panel, the clicking noise (electric air filter) and the loud bang went away.
Nov 30, 2008 | Aprilaire 550 Humidifier
Loud "Glonk" when humidifier turns off
Try turning the water valve going to the soleniod down. There may be too much pressure. You may have to replace solenoid one more time after making the adjustment.
Mar 12, 2008 | Aprilaire 700 Humidifier
Vicks Starry Night - White/ Blue Logo
42 people viewed this question
Top Vicks Humidifiers Experts
Paul Carew
Robert
Are you a Vicks Humidifier Expert? Answer questions, earn points and help others
