Question about Husqvarna Riding Lawn Mower 42 Inch Cut Yth2042
2007 Sienna rear wheel stuck dont think it's the hand brake
    New Friend:
  • 3 Answers
Not sure why this is in a Husqvarna post... but anyway, regarding the 2007 Toyota Sienna I assume you're talking about:
You probably have a stuck brake caliper. They're easy to change, just search YouTube for a video, and look at this link:
http://www.ehow.com/how_5805469_tell-need-new-brake-calipers.html
Posted on Dec 31, 2012
Adjustment screw came out and now car is stuck in park
jack up the car on the driver's rear and see if the raised wheel will rotate. if not your problem is the brakes. remove the wheel and drum and replace broken or missing parts.
Apr 28, 2015 | 1995 Ford Thunderbird
Rear brake cailpers won't collapse on 2007 ford fusion
Open bleeder valve & push caliper piston, in as
you rotate piston to screw in parking brake
Do this by hand,only use a clamp on the front calipers
Apr 08, 2013 | 2008 Ford Fusion
The driver's side rear wheel is stuck and will not rotate on the axle. How can I get this unstck? Do I need to replace the wheel hub?
I'm going with common sense here
Do you even have the brake drum off?
You won't know about a wheel hub until you get to it
Most likely you have two things : rusted parking brake
cables ,that quite working years ago & need replacing
& negelect, as far as stripping down the brakes once a year,
to prevent those those issues in the first place
Sep 22, 2011 | 1997 Plymouth Breeze
I've got a 1990 gmc 3500 2wd p/u the rear brakes dont seem to be working 100%.there is what looks like a leveling valve in the rear line above the rear axle.i dont know what this is and would it have...
it could have something to do with your problem I think this valve is exactly what you think it is, because 75-80% of the braking is on the front wheels this valve restricts the pressure to the rear wheels.....hope this helps........cheers.
Aug 17, 2011 | GMC C3500 Cars & Trucks
The brakes are getting stuck and the wheel doesn't tuen
You do not say what kind of bike, speed bike?Coaster brake? hand brakes, pedal brake? If, it is a hand brake, it usually means that your wheel is bent and needs to be trued. You cannot adjust brakes with a bent wheel and you need a truing stand.. If it is a coaster brake you need you hub rebuilt as there is an part broken inside the hub.
Apr 16, 2011 | Schwinn Cycling
2007 toyota sienna a shimmy has developed that is very spuratic steering wheel shakes etc. i have checked tires for bad spots, wheel weights , tire pressure everything seems fine. does it sometimes ,...
Change Power Steering Fluid
Check engine and transaxle mounts
Check front drive axle joints
Strip Brakes and clean off all rust, and lube,
so calipers and pads release
Mar 03, 2011 | 2007 Toyota Sienna
My 2007 Honda accord hand brake lever is already high, that tells me it need to be adjust. I look under the car tried to find where to addjust it, it may be inside the rear wheel, can you help me?
Your brakes need to be adjusted first.Then worry about the handbrake.Don't get this wrong or it could be very bad.Get the brakes done,adjust the h/brake.
Cars can go but they MUST stop.Dont shortcut on the brakes.
H/brake adjustment is usually beside the h/brake lever
Hope this helps
Jan 17, 2011 | 2007 Honda Accord Sedan
Will I need a caliper reset tool kit to change the brakes on my 2007 toyota sienna or will a standard c-clamp do the job? And since it is an ABS system, I assume that brakes must be bled, correct?
Brake Pads Removal & Installation Front To Remove:
  1. Remove the front wheels. Front brake caliper (exploded view) toyota-09-00-5838.gif
  2. Loosen the caliper bleeder.
  3. Hold the slide pin; remove the 2 mounting bolts and remove the brake caliper from the support.
  4. Support the caliper.
  5. Open the brake bleeder. Press the caliper piston into the bore.
  6. Close the bleeder after the piston has reached the bottom of the caliper bore.
  7. Remove the brake pads, support plates, wear indicators and anti squeal shims.
  8. Remove the slide pins and bushings from the caliper support.
To Install:
  1. Lubricate the slide pins and bushings with brake grease.
  2. Install the bushing on the slide pin.
  3. Install the slide pin on the caliper support.
  4. Install the brake pad support plates on the caliper supports.
  5. Lubricate the anti squeal shims with brake grease.
  6. Install the anti squeal shims on the brake pads.
  7. Install the pad wear indicator facing upward and install the pads on the caliper support.
  8. Install the caliper on the support.
  9. Install the 2 mounting bolts, hold the slide pins and tighten 25 ft-lb (34 Nm).
  10. Fill the reservoir and bleed the brakes.
  11. Install the front wheels.
Rear To Remove:
  1. Remove the rear wheels.
  2. Loosen the caliper bleeder. Rear brake caliper (exploded view) toyota-09-00-5842.gif
  3. Hold the slide pin; remove the 2 mounting bolts and rear brake caliper assembly from the support.
  7. Remove the brake pads, support plates, and anti squeal shims.
  8. Remove the slide pins from the caliper support.
To Install:
  1. Lubricate the slide pins with brake grease.
  2. Install the slide pin on the caliper support.
  3. Install the brake pad support plates on the caliper supports.
  4. Lubricate the anti squeal shims with brake grease.
  5. Install the anti squeal shims on the brake pads.
  6. Install the rear pads on the caliper support.
  7. Install the rear caliper on the support.
  8. Install the 2 mounting bolts, hold the slide pins and tighten 25 ft-lb (34 Nm).
  9. Fill the reservoir and bleed the brakes.
  10. Install the front wheels.
Sep 18, 2010 | 2007 Toyota Sienna
Emergency brake sticking.....i think. Mazda B4000 pickup
Are you sure it is the emergency brakes?Or is it a caliper stuck,because it is bad,or the caliper brake hose is stopped up?Jack the wheels up,one at a time,and try to see if they will turn by hand.This will tell you if it is front,or rear.If it is the emergency brake,then the cable from the front,to the bake,is most likely the problem,it is rusted ,and frayed,and stuck,you will have to disconnect it at the rear,from the brakes.If this helps,let us know,If it is the calipers,in the front,the wheels will not turn by hand.Brake loose the caliper bleed screw,and if the caliper turns the wheel loose,then the brake hose is bad,if it does not ,then the caliper is bad on that wheel.
Dec 05, 2009 | 1999 Mazda Pickup
Cost of repairs 2006 Sienna Limited AWD
your talkin a good chunk of money definitly over 100 dollars i would think after the labor cost probably around $350.....
Oct 01, 2008 | 2006 Toyota Sienna
Husqvarna Riding Lawn Mower 42 Inch Cut Yth2042 Logo
111 people viewed this question
Top Husqvarna Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
