Question about HP Pavilion a705w PC Desktop
Hello I have a hp pavillion a705w it wont turn on any monitors
Hi, a few weeks ago my hp pavillion a705w wouldnt work with any monitors, for example when the monitors arent hooked up with the comp they turn on and say no status and the little light at the bottom turns green, but as soon as i connect it to the pc the light turns orange and the screen stays black, the pc turns on and the cd drive even opens but why wont any monitors work with it?
  • Anonymous Jan 23, 2009
    Hello I have the same problem that erikaeleton has. I have an hp pavilion a705w it will not turn any monitors on. When you turn the monitor on and then turn the computer on the monitor indicator light changes from green to amber and it stays dark the complete time.
How Would I Go About Hooking 2 Monitors Up To My a705w
Posted on Aug 15, 2009
    Problem Solver:
  • 15 Answers
Http://mobileinfo360.blogspot.com here is your solution
Posted on Jan 18, 2009
Integrated 10/100 Network Card for HP Pavillion a705w: My brother-n-law HP Pavillion a705w is dropping it's internet connection after about 2 minutes. We thought it was the Cable Modem Box (Motorola)......
Hello my name is Israel. On your type of cpu your network card is integrated into th emother board. YOu can purchase one and just connect it inot one of the slots. the instructions as well as the software should be included in the package. It will be a very painless installation. You can probably get a dlink network card at Best Buy for about $15. Good Luck.
Feb 15, 2011 | HP Pavilion a705w PC Desktop
Hi I have a HP pavillion DV6 iv'e had it for about 2 years and it wont turn on. I had it on once about 2 months ago after i researched a solotuion to the problem but after i turned it off again it wouldnt...
Hardware failure: the chipset of the motherboard has overheated and failed. You will need to take it to a repair shop, you will probably gonna have to replace the motherboard.
Feb 14, 2011 | HP Pavilion dv6000z Notebook
Is there a sight that can go to that will show me the schematics for my hp pavillion a000 model a705w
hi.. here's a link where you can check how to change hardware for this computer.
http://h10025.www1.hp.com/ewfrf/wc/documentSubCategory?tmp_rule=36374&tmp_task=useCategory&cc=us&dlc=en&lc=en&product=435558
You can check this link for system specification as well :
http://h10025.www1.hp.com/ewfrf/wc/documentSubCategory?tmp_rule=50874&tmp_task=prodinfoCategory&cc=us&dlc=en&lc=en&product=435558
Hope that helps.
Dec 25, 2010 | HP Pavilion a705w PC Desktop
What memory do I need to upgrade my hp pavillion a705w
hello
for that particular HP computer, you need this memory module
256MB, PC2700 DDR-SDRAM DIMM memory (32Mx64, DB221AX)
ask for P/N DD234-69001, SHOULD BE ABOUT $20-$25 PER STICK
hope this helps
Nov 09, 2010 | HP Pavilion a705w PC Desktop
My son bought an HP a705w 3 weeks ago. The thing worked fine at the home where he got it, I was there with him. He got it home and removed the cooling fan from the video card(which I told him NOT to do!)He...
Locate the VGA connector (encircled in red) at the back of the PC:
Plug the monitor cable in it and start the system. If its functional the display should come.
Remove and re-install the RAM. It helps sometimes. Remember to un-plug the system from the mains before carrying out this procedure.
I checked the mother board specs (HP A705W) and it has no external video card slot nor any fan except on the processor. Did your son put a PCI video card?
By the way, it isn't wise to remove the fan if there is any on any device. Not only the device will be damaged but can result in a fire hazard as these components get VERY hot during working.
If the after reinstalling the RAM, PC does not boot, its likely a hardware fault. You have to get it checked by a tech. If its not repairable a new board is required and make sure that other components are working before making a purchase. Mother board model is MS-6577.
Apr 01, 2010 | HP Pavilion a705w PC Desktop
Hp pavilion a705w Light flashed in front and back on and off
Try a different monitor with your PC. If it does the same thing then you know the problem is with your PC. Also connect your PC to a different monitor. If it works OK then your monitor is bad. Does it beep at startup? Describe beep codes and someone on this website will decipher them for you. This might help to diagnose the problem.
Jan 12, 2009 | HP Pavilion a705w PC Desktop
Monitor reads - "no vga signal". Thus, I have no picture. It just stopped working
hi there, check the system if it is ok, if so, check your video cable, you have a video problem. try to see if there is a cold solder on video section, do some test. ty
Dec 25, 2007 | HP W22 LCD Monitor
HP Pavilion a705w PC Desktop Logo
514 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
