SOURCE: GE 24 hour programmable basic timer - how do i
So, this timer came with no instructions. What do you want for $3.99. Made cheap in China and instructions cost more than the timer.
The timer has a dial with tabs all around the 24 hour clock. They are in the down position which is on. You must pull all the tabs up in the times you want the timer off. This is different from all the other timers I have that used that have two removable tabs that are placed at the start and end times.
Put the switch on the side of the timer in the timer position.
SOURCE: setting GE Plug in mechanical timer 24 Hr Model
pull the pins up for off, down for all, so pull all the pins up then push down the pins for the time you wan the time on
SOURCE: I need instructions for how
GE 15075 manual:
http://www.jascoproducts.com/support/manual-downloads/applications/DocumentLibraryManager/upload/Plug-In-15075-Manual-eng.pdf
GE 15075 is a plug-in timer.
Before you plug it in, set the timer so you're not bent over at the receptacle.
Rotate dial until current time lines up with triangle located on inner dial.
There are movable pins located around the dial.
These pins cause the timer to turn on and off.
Pins out = timer on
Pins in = timer off
plug in your lamp and the timer turns on and off.
After power outage, set current time again.
SOURCE: i need instuctions on how
See both GE strip timers to identify product:
http://waterheatertimer.org/GE-timers-and-manuals.html#striptimer
GE 15077 digital or programmable strip timer manual
http://waterheatertimer.org/pdf/GE-15077-Manual-eng.pdf
If this manual does not match your timer, add a comment.
SOURCE: greenbrook GP 24 24 hour
Open following link to identify timer and download manual:
http://www.greenbrook.co.uk/categories.php?cat=4
If timer is not shown, then add a comment with in-focus photo of timer posted on Flicker for possible help
