Question about Crafts & Hobbies
Glue does not come out
What are the yellow and red led lights stand for?
    Champion:
    New Friend:
  • 217 Answers
Can you please provide the brand name and the model gun so that I can try to help you? On most guns, the yellow light means it is still warming and the red light means it is hot and ready to squirt, but i need to know the gun type to be sure
Posted on Feb 26, 2013
My LG Television have 6 lights in the picture?????
If you have a LED back light LG TV, the problem is the LIGHT DIFFUSION PLATE on top of each LED diode dropped off, you may use supper glue to glue it back, but be aware that the diffusion plate has polarity, if you put it in a wrong position, it will not distribute the LED lights evenly, usually the plate has a small tab on the out-circuit edge, you may look at the other none-drop-off plate to glue it back. please do not put any glue in between the plate & the LED diode, only little glue to cover the three original glue spots.
Apr 22, 2017 | LG Televison & Video
Installed new lamp. When powered up blue solid light and yellow blinking light (15x) , tv would torn off and on several times trying to light lamp. Once that failed red blinking light and yellow solid...
Hi Genaro,
Blue led light lit solid and yellow led light flashes is an initial attempt of the set to re-light the lamp.Red led flashes and yellow led light solid means that the lamp won't light up that's why it only has sound without the picture.
Since you've replaced the lamp twice and still the symptoms persist, I suspected that the fault came from the ballast board and not on the lamp itself. If the ballast board gone to malfunction, there's no high voltage will produce to light up the lamp and will sensed by the processor and trigger the error code (Flashes/solid led light with color code).
To verify whether the ballast board is faulty or not, check if the lamp will lit by looking through the lamp door louvers at the rear of the cabinet upon turning on the set.
Please let me know what you will find to assist you further.
Jdvillanueva
Nov 05, 2011 | Toshiba 65HM167 65" Projection Television
Ryobi charger model # 140295003 has a red and yellow light. When charging red light is on what does the yellow light mean? Also how long should the battery be left in the charger?
Completely wrong. Quoting from the user's manual:
"The charge indicator light (LED), located on the charg- ing stand, will light up red and glow when the char- ger is properly connected to power supply. This light indicates the charger is operating properly. It will remain on until battery pack is removed from charging stand or charger is disconnected from power supply.
After normal usage, 3 hours or less of charging time is required to fully recharge battery pack.
If both red and orange LED indicators glow, the battery pack is deeply or completely discharged, and 6 hours or longer of charging time is required to fully recharge battery pack.
Note: If charger does not charge battery pack or orange LED continues to glow after more than 30 minutes of charging, return battery pack and charging assembly to your nearest Ryobi Authorized Service Center for electrical check."
So to summarize: red = charging. orange (yellow) = fully discharged battery. orange after 30 minutes - bad battery or bad charger.
Apr 23, 2011 | Garden
The last led light blinks green and sometimes it turns solid red
red light is stands for hardware boot and the green one is stands for system boot and disc boot. when red light remains solid it means your system is in 0% cpu usage and nothing doing, stop working
May 09, 2010 | Intel SC5299BRP
Green & Yellow light on 14.4V charger
It sounds like your battery is bad.
If both yellow and green LEDs come on, this indicates
a deeply discharged or defective battery pack.
Allow the battery pack to remain in the charger for 15
to 30 minutes. When the battery pack reaches normal
voltage range, the red LED should come on. If the
red LED does not come on after 30 minutes, this may
indicate a defective battery pack and should be
replaced.
n After normal usage, a minimum of 1 hour of charging time
Nov 24, 2009 | Ryobi Multi-Volt Battery Charger
Lights on Rechargable Lantern.. Swissgear SG66301
I don't know how to solve your problem but, the three lights mean this:
Red LED light indicates the battery is being charged
Green LED light indicates that the battery is fully charged
Amber LED light incidates that the battery power level is low - the battery needs recharge.
Do not recharge you battery over 24 hours.
Nov 03, 2009 | Kitchen Appliances - Others
Wont turn on
your ps3 is done. this is known as the yellow light of death.
Jun 16, 2009 | Sony Playstation 3 (PS3) Console
Blinking red and yellow light
Generally if both the (red) alarm LED and the (yellow) data LED are both blinking, it is an indication that the tone cartridge needs to be replaced. You should be close to out of cartridge.
Jan 12, 2009 | Brother HL 1440 Laser Printer
Crafts & Hobbies Logo
69 people viewed this question
Top Crafts & Hobbies Experts
R.A. Ellis
R.A. Ellis
Debbie
Are you a Craft and Hobby Expert? Answer questions, earn points and help others
