Misplaced the pedestal mount screws for Samsung pn58c8000 TV during a recent move. Can anyone point me to the proper sizes or location for replacement?
eagle338
  • 4889 Answers
SOURCE: no screws for the tv to mount to the bracket
You will 4 m5x18mm and 4 m5x25mm machine screws. That should do the trick..
Posted on Mar 01, 2009
  • 3 Answers
SOURCE: Tv didnt come with screws....
The size is #8-40 X 3/4". This is a specialty screw, so you're screwed
Posted on Dec 13, 2009
satavlad
  • 405 Answers
SOURCE: I have misplaced my 4 wall mounting screws (M6x45)
M6X45 is a standard metric size, M6- diameter, 45(mm)-length
Posted on Dec 22, 2009
Testimonial: "Great help..I also saw a fix for my intermittent power supply problem on the Akai HDTV!"
budmrtn
  • 11361 Answers
SOURCE: screw size to bolt panasonic 32 inch lcd into
Metric M5 or M6, they should come with the mounting kit.
Posted on Dec 23, 2009
budmrtn
  • 11361 Answers
SOURCE: LG 42" wall mount screw size
Metric M5 or M6, when you buy wall mounting bracket, it will came with a bag of screws for attaching the TV to the bracket. All my wall mounting brackets for my TV come with screw.
http://s807.photobucket.com/home/budm/allalbums
Posted on Jul 01, 2010
Testimonial: "Thank you! We'll head to Lowe's tomorrow to pick up the appropriate size screws. We just moved into a new home and they left the wall mount up for us, but did not leave any of the extra screws that went with the mount. Thanks again! "
Can you tell me what size screws I need to mount my Toshiba Model 46G310U on a wall?
M6 or M8
http://support.toshiba.com/support/search?s_query=mounting+bolts
User Manual
Page 6
... stand. 3) Once you have removed all four screws holding the pedestal stand in place, remove the pedestal stand ..., level, stable surface that can support the weight of the surface. Four screws Hook Sturdy strap (as short as possible) 46 / 55" TV VESA Mounting Pattern 32" TV VESA Mounting Pattern Four screws Hook Sturdy strap (as short as possible) Four screws Hook Sturdy strap (as short as a quilt or blanket. Make ...) 200x200 mm 200x200 mm 400x200 mm 400x200 mm Screw Size M6 M6 M8 M8 (unit in mm) 40" TV VESA Mounting Pattern Removing the Pedestal Stand 1) Carefully lay the front ...
Toshiba 46G310U Mounting Screws
Sep 24, 2017 | Televison & Video
What size of screws/bolts do I need to mount the base to the TV?
It uses metric machine screws. You may have to spend some time at your local "big box" store searching for the right hardware, BUT length is important from a safety perspective. Insert a toothpick in one of the holes and mark where it is flush at the top. Take your toothpick to the store and match length with the M4, M6, etc. screws you will be sorting through.
A large screen TV such as yours requires two people to place it screen down on a soft surface such as a blanket for hardware installation. Be sure to tighten the screws firmly. Enlist the same two people (or designated alternates) to lift the TV and place it where it should be located.
Sep 05, 2015 | Westinghouse Televison & Video
I would like to remove the pedestal or stand from a LG 42LG70 TV because I want to place the TV on a wall mount.
Usually the safe way to do this is look first at the owner manual but lay set face down on a padded surface so all weight is on the frame around the screen and no weight on the screen itself, exert no downward pressure in that position or screen may be damaged.
Usually pedestal is secured by 4 or more screws that may require the back cover of the set to be removed first, to get at---a careful look with it face down will show if part of the pedestal is under the rear cover of the set or not.
Dec 18, 2012 | LG 42LG70 42 in. LCD HDTV
Help with mounting screws on ge pedestal sbsd137hww
Would anyone happen to know the size of the mounting screws for the ge pedestal sbsd137hww
Aug 04, 2011 | Dryers
I can't remove the stand off the tv
Hi, i have instruction on removing your base stand.
1) Carefully lay the front of the unit face down on a flat,
cushioned surface such as a quilt or blanket. Leave the stand
protruding over the edge of the surface.
Note: Extreme care should always be used when removing
the pedestal stand to avoid damage to the LCD panel.
2) Remove the jack pack cover on the back of the TV to expose
the pedestal stand screws. The jack pack cover can be removed
without tools.
3) Remove the four screws shown in the diagram below. This will
allow removal of the pedestal stand.
4) Once you have removed all four screws holding the pedestal
stand in place, remove the pedestal stand from the TV by
sliding the pedestal stand away from the TV.
Feb 12, 2011 | Toshiba REGZA 52RV530U LCD TV
We had the tv mounted on the wall and now want to mount uit back on the pedestal. We have the pedestal but seem to be missing the piece that locks the tv into the pedestal
Hi my name is Roety,
I can help you with your issue ,
The pedestal slides up into the back, and is held by 4 or 6 screws thats all
If I have helped you with your issue please click accept.
If you have more questions you can still respond until this post expires,
I will reply asap
Thanks
Nov 09, 2009 | Samsung LN-S4095D 40 in. LCD HDTV
Try to mount TV to the wall and need to release the TV stand
To Display your LCD TV using a Wall Bracket:
If you decide to wall mount your LCD TV, always use a ULlisted wall bracket appropriate for the size and weight of the LCD TV: 32HL37/32HL37U/32HL17/32HL17U: 38.6 lbs (17.5 kg)
37HL17: 46.3 lbs (21.0 kg)
42HL17: 59.5 lbs (27.0 kg)
1) CAUTION: Two people are required for installation.
2) Unplug and remove any cables and/or other component connectors from the rear of the TV.
3) Follow the instructions provided with your wall bracket. Before proceeding, make sure the appropriate bracket(s) are attached to the wall and the back of the TV as described in the instructions provided with the wall bracket.
4) After attaching the appropriate bracket(s) to the wall and the back of the TV, remove the pedestal stand from the TV as described below.
1) Carefully lay the front of the unit face down on a flat, cushioned surface such as a quilt or blanket. Leave the stand protruding over the edge of the surface. Note: Extreme care should always be used when removing the pedestal stand to avoid damage to the LCD panel.
2) Remove the jack pack cover on the back of the TV to expose the pedestal stand screws. The jack pack cover can be removed without tools.
3) Remove the five screws. This will allow removal of the pedestal stand.
4) Once you have removed all five screws holding the pedestal stand in place, remove the pedestal stand from the TV by sliding the pedestal stand away from the TV.
Sep 28, 2009 | Toshiba REGZA 32WLG66 32 in. Television
Missing pedestal screws for 3000 series 42 inch LCD. model 42PFL3704D
I just received the same TV (Philips 42PFL3704D/F7) in a box...with no screws to mount the pedestal to the TV. What size screws do I need to buy??
Jul 07, 2009 | Philips 42PFL3704D LCD TV
What is the screw hole size in back of tv
The screw holes are metric. The set is supplied with M5x25 screws to attach the pedestal, so the wall mount screws will be in that same range.
Mar 01, 2009 | Panasonic Viera TH-42PZ80U Plasma TV
Removal of flat screen pedestal so I can wall mount tv
Had the same issue. I turn the unit upside down and while holding panel down just pulled staight up on the base. The circular base popped off without any damage. I just needed to remove for shipping.so I didn't have to remove the cylindrical post. Once the base is removed you can see a screw that probably attaches that cylinder to the unit. Carefully removing it should work. Good Luck....j
Nov 23, 2008 | Televison & Video
Televison & Video Logo
91 people viewed this question
Top Televison & Video Experts
