Question about Audiovox KLV3913 12 in. LCD TV/DVD Combo
Dvd door will not open
I can hear motor try open,close,loading
How do I open the DVD/CD Loading Door? It will not open!
You have a physical problem---make sure front of unit is not touching the door or out of position----
May 22, 2012 | Televison & Video
Go Video DV 2150 - DVD door won't open at all. You can hear a mechanism working behind the closed door, but nothing happens and the door remains shut. Any advice??
There is a small belt under the loading tray which would have gone slack ( loose ) and the sound you hear is it slipping on the motor pulley. If you are confident you can remove the mechanism and turn it upside down and access this belt. Dismantle only if you can get the spare belt or your efforts will be in vain.
Sep 13, 2011 | GoVideo Go Video DVD/VCR Combo
Disc tray does not open
When you press the eject button you should hear the loading motor engage trying to open the dvd door, if you hear the motor! it indicates a bad loading belt that is stretched or direct drive gear problem, either way dis-assembly will be required to take a shot at repair.
Jan 01, 2011 | Memorex MVD2022 DVD Player
Ihave a Cyderhome dvd player, and i cannot get it to play.The green light on but cannot get the tray to open,what can i do ?
You seem to have two different problems. The tray won't open and a DVD won't play. First use the emergency eject slot on the bottom of the unit to eject the DVD. Now test the drawer by seeing if the drawer will auto close when you push the drawer closed without a DVD. If you hear the loading motor running but the drawer will not close than check the loading motor drive belt. Also check the 12V and 5V power supply outputs. Low voltages are caused by bad filter caps.
Nov 20, 2009 | Cyberhome CH-DVD 300 DVD Player
Unable to open the door of the dvd --when you press the eject button to open the slot---the door does not open---everything else works
Quick trick
First let's find out if the motor is dead or
the magnetic clamp is to strong for the motor.
Press eject then listen closely for the sounds of struggling motor
if you hear it trying SLAP the top right over the DVD drive
and that should break the magnetic seal and release the tray
you may have to try a few times Press eject and open hand slap kinda
hard the top of the DVD drive , don't worry you won't hurt it.
if that works email me and ill tell you how to fix this.
Rob
rsheehan@northernsteeldesigns.com
Oct 14, 2009 | GoVideo Go Video DVD/VCR Combo
I have a broksonic sc-20145 and the dvd player drawer will not open/close. could it be a bad motor?
With your ear next to tv do you hear the sound of a motor trying to open the dvd door. If so probaly a plastic gear that has failed that opens the dvd door otherwise could be the motor. Just go buy a $30 dvd player and connect to the tv input. not worth repairing and stay away from tv/dvd combos in the future for this reason that your having to expierence now.
Aug 15, 2009 | Televison & Video
My LITEON 5045GDL+ dvd drawer wont open.
HI, you have two issue here. the load motor is malfunctioning. this is causing the door open and close feature to lock up. this motor is connected to the gear assembly. it should be replaced soon. the second issue is the optical lens assembly. this len assembly has failed. the laser is burned ut. this is causing the no play issue.
In conclusion, i recommend replacing the optical len assembly and the load motor as well. this will fix this issue. try not to force the door open often, this Will damage the loading dock gears.
Jun 18, 2009 | Televison & Video
Internal DVD
hi if your dvd driving belt is slack, it wouldnt be able to draw the door to a position where it will press the loading switch, so it will eject back. 2. if your dvd laser lens is dull or too dirty or dead it might be making attempts to load severally.if the disc driving motor is bad, the tray can be open & close many time without a success
May 24, 2008 | Polaroid 3211TLXB 32 in. LCD Television
Door opens and closes 3 times
v\:* {behavior:url(#default#VML);} o\:* {behavior:url(#default#VML);} w\:* {behavior:url(#default#VML);} .shape {behavior:url(#default#VML);} Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} t needs to be realigned
unplug power
open unit
clip_image001.jpgremove dvd drive (4 screws)
remove power cable to dvd right rear of unit on circuit board
(squeeze plastic connector and pull up)
remove ribbon cable CAREFULLY wiggle it from side to side and it will come up clip_image002.jpg
Then with drive removed, open up drive to access the bottom near front door
Once open you will see a smalll motor and a white pice of plastic that slides. with tray closed slide that piece of plastic as far towards the middle as it will go clip_image003.jpg
with that slid all the way over you should be done.
close it up and be carefull sliding the ribbon cable back into place
Worked for me!
Good luck
Dec 22, 2007 | JVC DR-MV7 DVD Recorder/VCR
Keeps opening
may have a microswitch that signals that the door is closed that may be faulty. look for a switch that is actuated when the door closes.
Nov 06, 2007 | Emerson EWR20V4 DVD Recorder/VCR
Audiovox KLV3913 12 in. LCD TV/DVD Combo Logo
Top Audiovox Televison & Video Experts
Jaime Hernandez
romy sibug
romy sibug
Are you an Audiovox Televison and Video Expert? Answer questions, earn points and help others
