The backlight on ACER Aspire 7738g is not working after power failure.Where can i check if the LED if is ok?
Is there any fuse or something else i can check?
IB4G2008
  • 3587 Answers
SOURCE: media test failure
sounds like your hard drive is unhappy..can you boot from recovery disk?
Posted on Mar 13, 2008
  • 7 Answers
SOURCE: acer not work
Acer Aspire One BIOS Recovery The AA1 has a built-in BIOS recovery routine, making it possible to flash the BIOS even if the system doesn't boot anymore. It's only meant for emergencies and may void your warranty, so use at your own risk.
Follow every step carefully!
First format an USB stick with FAT.
Download the latest BIOS, and put both FLASHIT.EXE and the BIOS file in the root directory of the stick. Rename the BIOS file to ZG5IA32.FD, that's important. Do not remove the USB stick.
Turn the AA1 off, make sure both battery and AC adapter are connected. Press Fn+Esc, keep it pressed and press the power button to turn the AA1 on. Release Fn+Esc after a few seconds, the power button will be blinking. Press the power button once. The AA1 will now initiate the BIOS flash, do not interrupt it under any circumstances. After a while the power button will stop blinking, and the AA1 will reboot shortly after. Wait patiently.
The BIOS has been flashed and all settings reset to default.
If for some reason you made a mistake during the procedure and it doesn't reboot by itself wait 5 minutes before turning it off, just to be safe that it isn't still flashing the BIOS.
Download WIN98BOOT.ZIP and HPUSBFORMATTER from the internet normal bootable like a diskette won't work with a usb stick
I had mine 2 months it's a common problem with the notebook.
The onely thing that you have to do is download these programs with someone with a internet connection.
Good luck
Posted on May 25, 2009
ailia
  • 175 Answers
SOURCE: acer aspire one black screen and no boot
Contact with notebook repairing engineer. Might be coz of some short circuit, BIOS corruption or any malfunction of the hardware.
Regards;
Hassan
Posted on Jul 08, 2009
SOURCE: Acer aspire 4930 wont turn on
If the power LED on the Notebook is blinking but not turning ON then the issue is related to the power supply unit and service is required.
Posted on Nov 03, 2009
  • 82 Answers
SOURCE: Acer Aspire 5610 LCD backlight problem
If it is less than 1 year old, go to http://www.acerwarranty.co.uk for UK or http://support.acer.com/ for US.
I did this last year for my girlfriends laptop backlight problem and it was a free courier both ways and was repaired within 2 weeks (new part required). No cost to you.
Otherwise, sorry I dont know how to fix it.
Posted on Nov 14, 2009
The acer 5536 wireless lan communication button indicator isn't on and the screen is black.
try external monitor to laptop with screen disconnected ,if it works laptop ok screen has problem ,common problem blown fluro light or power to screen and power to fluro ok fluro has problem,check power to screen fluro nil then screen power supply problem or led check wire loom from case to screen power supply.
Sep 08, 2014 | Acer ASPIRE 5536-5883 COMPATIBLE LAPTOP...
Back light sometimes works
If your laptop appears to boot up and the hard disk LED flashes, then the problem is probably a back light fault. This can be a faulty inverter or a faulty CCFL lamp. Please click on this link and follow my instructions to identify the fault and possible fix :- http://www.fixya.com/support/r3598095-faulty_laptop_lcd_screen
Nov 10, 2012 | Acer Aspire As5250-0327 320gb - Perfect...
Aspire 7738g hdmi
You may also need to change the input source on your television. On my tv there are multiple HDMI ports and I can switch between them.
Check the remote for an input button or check in the settings menu on the tv.
Jul 11, 2012 | Acer Computers & Internet
I bought my acer aspire 7736z-4412 a little over yer ago. I don't do much on it other than check out facebook. It recently decided to shut down while I was online and now it won't start at all. I...
there are a few things that could cause this but here are the first two to look into before the last and worse case
your power adapter may have died. you need to have it checked. if it is ok then you porbably damaged the jack. if the jack is ok well then your motherboard has an issue. either the board is damaged or another problem exists.
Jun 29, 2011 | SIB 320GB 2.5 Inchs SATA HDD Hard Disk...
I cannot get my laptop to start. I have bought a new power cord, and it will not charge or start. I have an acer aspire 7736z. What could the problem be?
Try removing the battery, it may be defective. Remove the battery and see if the unit powers up when plugged in.
Check to see if the charge light at least comes on when it's plugged in....if it doesn't, then the socket the power supply plugs into may need to be re-soldered.
May 27, 2011 | SIB 320GB 2.5 Inchs SATA HDD Hard Disk...
My multimedia touchpad on my acer aspire 8930G isnt working anymore... the volume leds and the mute led lights up, cant do anything with it anymore. Won't even react on adjustments made in Volume Control...
Well, I had the same problem too, so I called the acer support and solve it in a sec.
You just need to close your pc, take the battery off for a few seconds, and put it back in again.
Just as simple as that....
Good Luck!!!
Oct 14, 2009 | Acer Aspire 6920 Notebook PC
Acer aspire 9420 sreen backlight dead
Check the luminance Tube If it is ok then check the power up circuit of tube,check flexible cable connected from motherboard to the power up circuit, check for dry solder in the circuit. But be careful,don't touch or handle the power up circut of tube while the laptop power is turn on because of step up high voltage generated in that circuit.
Sep 28, 2008 | Acer TravelMate 2300 Notebook
BenQ FP767 17" LCD Monitor Problem - Power LED Blinks
Look for small power transistors 2SC5707 near yellow invertor transformers which go to backlight connectors.
But if problem is blinking power LED powersupply capacitors maybe an issue,check visualy and/or replacement.
Also fuse that maybe blown is not glass fuse near mains socket,It is semiconductor black or yellow colour labeled PFxxx near heatsinks of power supply secondary.
Please rate the solution and provide feedback.
Samir
May 25, 2008 | BenQ FP767 17" LCD Monitor
Computers & Internet Logo
61 people viewed this question
David Payne
David Payne
