Question about Electrolux EIED55HMB Electric Front Load Dryer with IQTouch Controls Med
Eied55hmb electrolux dryer door adjustment
Door wont shut
  • Official Brand Answer
  • 4,342 Answers
Good Afternoon Vijay, thank you for your post! From what you have described it sounds like the door strike is not aligning with the door lock or the dryer possibly has a defective door switch. You may want to connect with a local servicer who will be best equipped to pinpoint the problem. If you don't know a qualified technician, you can use the service locator option on the manufacturer site to find one near you.
Posted on Aug 03, 2013
ALL LIGHTS ON MY ELECTROLUX EIED55HMB ARE FLASHING HOW CAN I REBOOT IT?
Unplug the unit for 10 minutes, then plug it back in. It should go to default settings. Consult you owners manual.
Oct 23, 2017 | Electrolux Dryers
Electrolux cde7700lw0 dryer
Good Afternoon Brain, this is Z. I am happy to assist you!
I understand that your Electrolux dryer (CDE7700LW0) door indicates it is open and your dryer will not operate. Let's try resetting your dryer by either unplugging it or flipping the household circuit breaker off. It is best to wait approximately ten minutes and then turn on your dryer. Select a normal cycle and verify if the dryer will start. If your appliance will not operate then it possibly have a faulty door lock assembly or a communication problem with the control board. In this regard, I would suggest contacting an Authorized Service Technician that will be able to assist you in the diagnosis of your appliance.
Apr 10, 2014 | Electrolux EIED55I Dryer
I have ane electrolux dryer with reversible doors. I would like to keep the door opening to the left, but it hits the wall. Is it possible to adjust the door to make it stop before hitting the wall?
Hi Wendy, this is AP
I understand you want to reverse the door opening on your Electrolux dryer. I would be happy to assist you with those instructions. Are you able to provide the model number for your dryer? If this is a new dryer you may visit the manufacture website, locate your appliance, scroll down to bottom and you will see a listing of documents available, the installation instruction manual will have the reversal instructions listed. . I hope this information helps to some degree - thanks for your question, and please do not hesitate to reconnect if you have additional information regarding your question.
Thank you,
Mar 21, 2014 | Electrolux Dryers
HOW DO I CHANGE HEATING ELEMENT ON MY ELECTROLUX DRYER?
You might try this step by step process. It is not for Electrolux, but the process should be similar. Changing the Heating Element
Apr 08, 2013 | Electrolux EIED55HMB Electric Front Load...
I own a 1Q-Touch Front-Load Electrolux washing machine. The door won't open. What can I do?
Hello Elizabeth P Cochran - Try resetting the unit by unplugging it or flipping the household circuit breaker off. Wait approximately ten minutes and restart unit. If the door does not open, then it sounds like the washer is possibly experiencing a communication problem with the control board, wiring failure or faulty door lock. Contact a professional to move forward accurately to properly diagnose/repair unit.
Jan 15, 2013 | Electrolux EIED55HIW Electric Front Load...
Electrolux Dishwasher door won't close or latch shut
Contact a professional to replace the door switch or adjust it.
Aug 07, 2012 | Electrolux Dishwashers
Hi I have an Electrolux dryer which has started showing the error message e60, when i hold the start button and the one next to ity I get error e62 showing can you help?
the "E60" error code will appear when there is an error with the door switch and sensor, An unbalanced door will produce the E60 code. Try to close the door gently and listen for the click. If the error remains, the door switch may need to be replaced.
the "E62" error code will appear when the lint filter and tubing need to be cleaned or replaced. The dryer will start and run for 15 seconds before shutting off. It will restart when prompted and run for another 15-20 seconds before shutting off. These steps must be repeated until the dryer continues to run the full cycle. Tim
May 12, 2011 | Dryers
My machine lights up but once you shut the door it
the door activation switch is stuck in a open circuit and you have to remove the door itself to obtain access to replace!! the switch
Jan 22, 2010 | Electrolux EW1200i Front Load Washer /...
Electrolux dryer error code e61
There is a 'tech sheet' in the back pf the dryer. Unplug machine, Remove the access panel on the back to get to it. Reach in and it should be there. It will tell you how to do a button check. You have to enter a test mode through the buttons.
The E 61 is a stuck button.
Enter function test mode and perform key
stuck closed (active). (button) test to determine which button is at
fault. Carefully free the and perform the test
again. If button is free but the key struck code
still exists, replace electronic control.
Sep 25, 2009 | Electrolux EIED55H Dryer
Electrolux EIED55HMB Electric Front Load Dryer with IQTouch Controls Med Logo
148 people viewed this question
Top Electrolux Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you an Electrolux Washing Machine Expert? Answer questions, earn points and help others
