Is it STK 465 ic--You need the Whole unit or only the replacement part Ic ?
  • 7,627 Answers
What kind of Laptop?
Posted on Dec 31, 2012
4 Suggested Answers
  • 846 Answers
SOURCE: How much is it to replace the whole Board instead
Just try to find a chip on the motherboard that has maxim 1987 printed on it and try to move the pins with a flathead screwdriver. If they move, they need to be resoldered. I work for Laptop repair NYC and we do this repair frequently.
Posted on Dec 20, 2009
caroldon
  • 17130 Answers
SOURCE: i need Original Sansui CR-M7
These Audio output IC's are not easily available unless you try for some old stock in good electronic stores. mention the details of the STK number and if you are not able to get this same , it is better to substitute with a universal type output - Mosfet type or IC matching the power supply.
Posted on Feb 19, 2011
SOURCE: i gave ma lap to a service centre.......he told me dat its power ic ISL 6262 is short nd hav to replace......he s n shortage of dat ic......is dr any site like ebay 4m wr i can get dat IC?
Have you tried eBAy?
Have you Googled "eBay similar sites"
This link displays about 250 million hits:
50 Ebay Similar Sites ' Websites Like Ebay.com
Posted on Nov 23, 2012
Mirror image??
Hi:
Your problem is the convergence circuit, you need to replace the convergence Ic's there are two large black IC's mounted on a large metal heatsink. The part numbers are STK-392-110 replace them with the same part number or use STK-392-120 for better and long lasting.
Sep 09, 2011 | Panasonic Televison & Video
I have a Fisher Stereo Amp Model CA-9025 thats not producing any sound. I have the cabinet off the unit, the unit will turn on, but won't produce any sound. Any other fuses to check or other ideas?
These units use STK amp pac ICs (large black part attached to the rear heatsink). In many cases, this IC is defective. It is possible that there is a problem with the voltage regulator circuit, but that is less likely. This IC needs to be replaced. Expect to pay in the $50 range (or more) for the part.
Dan
Mar 12, 2011 | Sony Audio Players & Recorders
Model 50UX26B/27K MAGIC FOCUS NOT WORKING - BLUE SHAWDOWS
Hi:
This is due to a convergence IC failure, the blue convergence Ic is faulty, but when replacing convergence Ic's replace both of them as the other is not far behind to fail you in the future, the part number to use for replacing them is STK-392-110 , I suggest if you have someone replace them, that you have them use STK-392-120 instead as they work better and longer. If you take off the back of the television they are the largest IC's in the unit, they are mounted on large metal heat sinks..
Aug 23, 2010 | Hitachi Televison & Video
Replacement STK numbers for convergence amps
This unit does not use the STK series convergence amps.The convergence power supply is what you need.I will provide that number for you after while.
Jan 19, 2009 | RCA P52960 52" Rear Projection Television
STK IC CHIP 392-110
I made the same repair in a Toshiba 42h81 I replaced the STK 392-110 and after a lot of searching found the cheaper ones last 6 month or so be sure to use Sanyo IC's and replace the resistors with them when the IC's let go they take the resistors out I posted my repair On my page if it will help you dennisgm052.weebly.com
Dec 02, 2008 | Toshiba 42H81 42" Rear Projection...
STK IC 392-110 Chips
am having stk 4392 amp board 2 channel, i want to change this two channel in to one channel. what modofication should i do
Blinking colors
there is a stk ic in the tv.which is located on the main board of the tv.that stk ic has gone faulty so u r getting this problem. u can get this new stk ic for replacement at  radioshack websites.
Dec 01, 2008 | Toshiba Televison & Video
Convergance- Red X will not move to make crosshairs white. Picture is doubled with red and blue. TV is a 55 in Mitsubishi VS55601.
This problem is related to the Convergence controller IC called STK.It must get malfuntioning replace the STK IC with the same numer IC. But one thing is importent that there must be two IC STK's and you have to change both of them.
Thanks
Oct 11, 2008 | Televison & Video
Mitsubishi ws-65809 concave picture
There will be either one or two of them, and they will be heavily heat sunk - as in mounted on a big heat sink, with vertical fins. That's all I can say without seeing the unit in front of me, open. They usually face towards the front, are in the middle of the middle board, and the name of the ICs is covered by a screw-on plate, which has to be removed for replacement.
Be generous with the heat sink compound when replacing the ICs, get the old stuff offa the heat sink with a putty knife if it has dried out.
To check whether you need to replace the ICs or not, with the unit on if you tap on the heat sink with something long and not conductive, like a stick, and it affects your conv - be VERY careful, this has to be done while the unit is on - you can probably get by with just resoldering the legs. If not and it just won't converge, IC replacement will be necessary. I recommend replacing both if you replace one, because next week the other one may go out and you may have to get in and out of the unit all over again.
Best way is usually to remove the entire light box, tho sometimes it's best to remove just the board, other times you can prop the whole board up and do the resoldering on your back.
Mr Bob
www.imageperfection.com
May 25, 2008 | Televison & Video
SAMSUNG PCL5415R
Probable bad convergence IC's---STK units on large heat sink.
Also,possible blown fuse (soldered-in) hidden under heat sink.
Samsung is known for making the fuse devices hard to find.
Let me know if you need more help....T.
Oct 19, 2007 | Samsung PCL5415RB 54" Rear Projection...
Computers & Internet Logo
18 people viewed this question
David Payne
David Payne
