Question about Exercise & Fitness
Horizon digital DT850 treadmill turns on can select workout hit start button belt does not turn on/rotate
    Top Expert:
  • 12,223 Answers
Step 1:
seee the video attached and lube the rollers bearing too. Happy NEW yEAR .God bless you
Step 2:
Test the input voltage motor, if there are the motor need repair see my personal TIPS for motor help. see the diagram attached.
Horizon digital DT850 treadmill turns on can selec - 12_31_2012_7_04_21_pm.jpg
Step 3:
test the output voltage board, for input voltage motor, if there are NOT the board is faulty.
Posted on Dec 31, 2012
  • 14 Answers
SOURCE: Horizon Model 3.2E LCD showing MILE EP 5101
THis is a reboot error. The upper control board is not loading properly. It might flash temporarily but If it stays on the upper control board will need to be replaced.
www.twincityrepair.com
Posted on Mar 02, 2009
  • 3 Answers
SOURCE: Buttons Froze during workout, now none of them work
It sounds like you just need some calibration. To calibrate incline, turn power on press press any incline buttons, as the incline try to change unplug the key. Now re-nsert key and incline will self calibrate,
Posted on Sep 02, 2009
SOURCE: V-fit treadmill belt wont turn
call the threadmill cops. they will come and beat up that error
Posted on Nov 05, 2009
maxtreadmill
  • 832 Answers
SOURCE: Treadmill turns on but belt not turn on
Press the Stop and the Speed Up keys down while inserting the safety key this will get the into calibration mode. The next step is to press the Stop key one time. The Time window should read EP:2P. Some newer models may also say FP, Pass, or the like. This means that it passes the EPROM test. if it says 2F, FF or Fail then the upper console needs to be replaced
Press either incline key and the incline will calibrate automatically.
BE CAREFUL, THE TREADMILL WILL RUN AT FULL SPEED IN THIS NEXT MODE! DO NOT STAND ON THE WALKING BELT. Press the Speed Up key and hold it down until 85 is shown in the Distance window (some models may show the 85 number in another window
If the belt does not move in this mode then the controller board is defective and needs be replace.
Posted on Jun 01, 2010
SOURCE: horizon treadmill won't start running
The manual said that after lubricating the deck, press Stop and Speed buttons together for 5 minutes and this will reset the lubrication message and the treadmill should work.
Posted on Aug 22, 2010
I have a Horizon Treadmill, Model T101 with ERROR Message 5101 MI 09. What does this mean? How do I fix it?
Hi there.... this may be a problem with the upper console CPU timing or associated parts. You can contact jatinahATrocketmailDOTcom for repair on these stalled consoles. Good Luck!
Oct 19, 2016 | Horizon Exercise & Fitness
What does lube bell mean
Either your treadmill has a typo or....well, it's LUBE BELT.
Go here: http://www.horizonfitness.com/support/customer-support
Download the manual for specific model and it will describe how to lube the belt. There may be a RESET procedure required to turn off the message and turn on the treadmill.
GL,
Td
Aug 12, 2014 | Horizon Fitness Horizon T90 Treadmill -...
Roller working side
China famous power cord manufacturer providing free power cord samples
Oct 20, 2013 | Horizon DT850 Motor Control Board
The T202 belt is not in the center
At the end of of the running belts2_bing.gif in the end caps will adjusting bolts you will need a allen wrench to adjust the tension. Start your treadmill2_bing.gif and turn clockwise a 1/4 turn each time see i f you can stop the belt. You need to be aware that the drive belt can also cause this problem so I suggest that you remove the motor shroud and when you are adjusting whether the front roller is moving and the running belt has stopped or the roller has stopped and motor is rotating ( adjust Drive Belt)
Jan 21, 2013 | Horizon Academy Sports Fitness T202...
My horizon ct5.1 turns displays select workout, buttons all beep but do not respond
replace the old batteries with a new ones, type hybrid rayovac, with the same polarity. clean the contacts batteries with c. cleaner
2) Tight the ribbon cable inside the display board.
3) Adjust the REED swithc, see the diagram attached. Test for open or faulty. Clean it, tight the connector very well.
God bless you
Jan 09, 2013 | Horizon Exercise & Fitness
Horizon DT850 treadmill belt won't move
Step 1:
please see the video and lube too the rollers bearing. Happy new year and God bless you
Step 2:
test the input voltage motor, if there are voltage in the motor, the motor NEED repair, see the diagram attached, and see my personal TIPS for motor help.
Step 3:
Dec 31, 2012 | Horizon DT850 Motor Control Board
Hi i have horizon treadmill t401 i don't when i start it 3 miles for hours for my workout it stoped and restart very fast i don't no what to do can u tell me how to solved the problems please
1)this a problem by lack of maintenance schedule. LUBE the deck belt, probably you have a worn deck belt.
2) Lube the rollers bearings too , inmediately.
3) measure the input voltage motor in the terminal, if there are the motor need repair.
4) measure the output voltage board, if there are NOT the board is faulty.
se the block diagram. attached. see my personal TIPS
God bless you
Oct 07, 2012 | Horizon T401 Treadmill Walking Belt
Lubed belt but display still says lube belt and I cant do anything how do i clear the display I have the horizon gs950t
After lubrication you have to reset your treadmill settings. Then only the message will go off. To reset the tread mill do the following.
1. Hold the "Stop" button for three seconds to reset the treadmill and clear the current workout selection or screen. The console will reset but will save any accumulated data
2. Press and hold the "eTRAK" button for 10 seconds to reset the console date. This permanently deletes any previously accumulated data
3. Press and hold the "Stop" button while pressing the Speed "+" button. Hold for five seconds to reset the console after applying lubricant to the machine. Lubricant application is usually only necessary when you receive the "LUBE" error
ok
May 04, 2011 | Horizon Fitness Horizon T90 Treadmill -...
The belt is slipping when running on ithas been standing in cold conservatory
Mar 01, 2010 | Horizon Exercise & Fitness
Exercise & Fitness Logo
91 people viewed this question
Top Exercise & Fitness Experts
Electro Med Services...
Howard
Howard
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
