Question about Maytag Refrigerators
Maytag refrigerator model # MBL2258XES1
Maytag refrigerator leaks water from bottom freezer
peyton32034
  • 410 Answers
SOURCE: Bottom of Maytag Freezer Ices Up
You have a plugged defrost drain. easiest way to fix it is unload freezer compartment defrost all of the ice, then remove the 2 screws that hold the rear cover in place about half way down the back wall. once this is removed use hot water to flush out the aluminum evap pan at the bottom of the coil. once it is cleared i will usually pur a little bleach in to kill any algae build up.\
be sure to unplug the refrig and use caution not to cut your self on the evap coil as the fins are very sharp..
Posted on Dec 16, 2007
aborcass
  • 2651 Answers
SOURCE: Maytag refrigerator leaks water from
sounds like you have a clogged defrost drain tube. removing back panel of freezer will give you acess to drain trough, melt away the ice with a hair dryer, youll find a drain hole under there somwhere,pouring boiling water down the drain will clear it pretty quickly( i use a steam machine purchased from the infomercials works awesome, after you clear it and all water drain down tube wrap a piece of solid copper wirearound the heater( black calrod heater right above the drain trough) and stick it in the whole maybe an inch or so. now everythime the heater comes on to defrost it will prevent the hole from freezing over
Posted on Apr 23, 2008
  • 1462 Answers
SOURCE: MY MAYTAG REFRIGERATOR
remove back panel inside freezer and there is a tray at the bottom with a drain hole in the middle. this is blocked with ice. melt off with a hairdryer and follow up with hot water till it flows waay freely
Posted on Oct 02, 2008
SOURCE: Maytag side by side is leaking water from the freezer sid
We also had the exact same problem with our Maytag side by side. We kept getting a small puddle down on the floor under the freezer side of the unit. There was also a giant ice block puddle that had formed on the inside bottom of the freezer compartment. We solved the problem in about an hour. First, we pulled the unit out from the wall and checked behind and underneath the unit with a flashlight. The little drip pan that collects the water was completely dry. That told us that there was a plug somewhere in the drain line. We removed all of the food and shelves inside the freezer so we could access the inside, back panel. My husband unscrewed the two bolts and removed both panels. We found the problem. The drain pan had frozen and all of the water was overflowing inside the freezer compartment and ultimately out onto our floor. There was also a giant snowball around all of the wiring. We used a heat gun and gently de-iced the snowball and the ice in the drain pan. The manual also says you can use a hairdryer for this. Then, my husband used his air compressor and gently blew into the hole to clear out the blockage. We checked behind the unit again and saw that the clog had released and water was flowing into the drip pan. Problem solved. It is important to get the clog out of the drain line so that the problem doesn't occur again. We put everything back together and everything seems fine now. I am also going to check the defrost timer to make sure it is timing properly every 28 minutes or so. You need your manual for this to determine steps to check the timer. It is important for the timer to be set correctly so that the unit goes into defrost mode every 28 minutes. This will also help keep the water flowing and draining w/out having time to completely freeze up. The original root cause of our problem is we had a faulty ice-maker. It had overflowed about 3 months ago. The heavy surge of water, and the small plug in the line is what started this. Another problem we have had with this unit is the plastic tubing in the back. We had one of the lines turn yellow and crack. So every few months we pull the unit out from the wall, vacuum underneath and check the plastic tubing for leaks and breakage.
Posted on Nov 07, 2008
SOURCE: leaking fridge
my maytag had cloged defrost drain cleaned drain all ok
Posted on Jul 03, 2009
I have a water leak at the bottom of my Maytag refrigerator and want to stop it.
Check that the drain under the evaporator is not plugged up/if so excess water will spill over onto floor.
Aug 22, 2017 | Maytag Refrigerators
How do I repair water leaking in the bottom of the freezer on Maytag model MBF2258XEW
Check your door seals. The air gets in, the moisture freezes then the defrost cycle turns it into water.
Sep 14, 2014 | Maytag Refrigerators
Maytag mff2258vew2 french door bottom freezer leaks
The cabinet heater in freezer is may not be working and causing condensation on the walls of the freezer. Have it checked by a service man.. also make sure the refrigerator is level. and it is not over packed with food. Newer models must have a certain amount of space for the air to circulate.
Oct 04, 2017 | Maytag Refrigerators
Late model freezer below maytag refigerator leaking water out the bottom where is the drain located?
drain is in the back behind the plate . and below the evap coil . if its covered with ice you cannot see it .. mm
Aug 06, 2010 | Maytag MFI2568AES Stainless Steel Bottom...
Water leaks out of freezer bottom same time every day model rsd22
The drain for the water to get away when defrosting is frozen shut...
Checkout this tip to help you..
http://www.fixya.com/support/r3780310-water_running_in_refrigerator_from
heatman101
Jul 13, 2010 | Maytag MSD2756G Side by Side Refrigerator
Maytag side be side model msd2454gr
heatman101
Jul 10, 2010 | Maytag MFI2568AES Stainless Steel Bottom...
Maytag model # MSD2754GR the refrigerator leaks
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Clear the bottom of the refrigerator so you can get at the drain. Then get a turkey baster and fill it with hot water. Insert it in the drain in the bottom and squeeze it cleaning the drain. Several applications will solve the problem, and do not forget the freezer side as well.
Good Luck,
Gilsh
Nov 30, 2009 | Heating & Cooling
Oct 02, 2008 | Maytag Refrigerators
Refrigerators Logo
519 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Shehu Pro
Shehu Pro
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
