Question about Apple iPhone Smartphone
Iphone numeric keypad
I suddenly the numeric keypad on iphone not responding whats the cause of this
  • 2 more comments
  • minded man Feb 10, 2009
    in my iphonw my numrical keypad is not wrking so how can i solve this problem
  • nealesh Mar 13, 2009
    suddenly my i phones keypad stopped working
  • Anonymous Mar 23, 2009
    None of the numbers on the keypad are responding when I try to dial out. I can still dial by using my contacts and call back lists, but I can't key in a number.
  • joe2931 Mar 23, 2009
    iPhone 1G.  The numeric keypad in phone application does not respond when tapped, so cannot dial new numbers (must first create contact).  All other keys/functions appear to work, e.g. I can type in the phone number of a new contact.
  • 53 Answers
Try to clean the screen
Posted on Feb 18, 2009
Is there a way to lock keyboard while entering data
The Hidden Numeric Keypad on Your Laptop - For Dummies
www.dummies.com/.../the-hidden-numeric-keypad-on-your-laptop.html
The key to finding a laptop's numeric keypad is to use the Num Lock key. ... It's great for entering numbers or working a spreadsheet, but rather frustrating at other ...
windows 7 - Touchpad does not respond when I am holding ...
superuser.com/.../touchpad-does-not-respond-when-i-am-holding-key-o...
Mar 11, 2012 - Is there any way I could check what is wrong with my laptop? ... holding Space works fine for a normal click for entering the number in non-pencil mode. ... The mouse may work while pressing these keys. .... tour help blog chat data legal privacy policy work here advertising info mobile contact us feedback ...
Oct 27, 2015 | Computers & Internet
My number keypad has stopped responding how can i fix it please
Hello and Welcome to FixYa!
If your numeric keypad is not working please first make sure that the numeric lock button (may be a light too) are on. Try to press the numeric lock button once and then use the keypad. If this doesn't work try pressing it again.
If you have any further queries, please do not hesitate to comment again. If this solution was helpful to you, kindly rate it.
Regards, Waqar.
May 22, 2011 | Computers & Internet
Numeric pad on control panel: Problem: only numbers 0,1 and 2 respond to pressure. All other functions seem to be working properly. I have tried disconnecting the appliance.
Most likely there is a problem with the keypad connector at the controller board. Usually these have a sliding collar that locks the keypad's flat flexible circuit material cable in place. Pull it up about 1 - 2 millimeters on both ends until it hits the stops (it doesn't take a lot of force, and it may even be loose already given what you describe). The cable should then pull out easily. Polish the contact stripes on the cable end with a white pencil eraser (the kind found on mechanical pencils), then wipe clean with a piece of tissue paper or clean dry cloth. Insert the cable back in the connector, and push the collar down so it is locked at both ends.
This is the most probable fix. It is possible that the connector is the problem; electrical contact cleaner may help. Other possible causes are a broken key-scan line* in the keypad, micro-controller chip failure, or a bad connection on the circuit board in the affected scan line.
*The keypad is wired schematically (if not physically) in rows and columns. The micro-controller activates a line in one direction, then scans all of the lines in the other direction to see which key if any has been pressed. 0,1 and 2 are on one of these lines, probably with several non-numeric keys; the remaining numbers are on another line (or two).
Dec 22, 2010 | Panasonic NN-H765 Microwave Oven
Keypad press does not respond when on an automated
try to remove the keypad and press the inner buttons to see whether it works. if it fails to work you have to change it
Apr 11, 2010 | Motorola Mobility Moto Q
Numeric keypad does not respond.
make sure that the num lock is on. There are 5 indicator lights on the left side of the power button, the first indicator on the left is Num Lock, make sure this is lit up.
Mar 30, 2010 | Dell Inspiron 6000 Notebook
My iphone suddenly has large icons 7 i cannot
Maybe you accidentally enlarged it.
Here's what you need to do to shrink them down or put them to normal size. Double-tap using 3 fingers on the screen of your device. That's the simple way of fixing it.
For more iPhone / iPod touch tips like jailbreaking and unlocking, click here.
If you need online help about jailbreaking and unlocking, you can contact me personally at this email: sale-47hyk-1863377234@craigslist.org
Oct 08, 2009 | Apple iPhone 3G
Keyboard letters 'm,j,k,l,u,i,o' permanantly locked for numerals. i have no idea how i switched this function on.
NumLock is on. Look for the Fn key in the lower left corner, and lookint in the top right, the NumLock key.
Mar 22, 2009 | HP 2133 Notebook PC
Iphone unlocked problems
i just purchased an unlocked i phone 1st gen and it was working fine with my tmobile carrier but all of a sudden i synced it with i tunes and now it wont let me make calls
Oct 11, 2008 | Apple iPhone Smartphone
IPhone touchpad only partially responding
I followed the following fix and it works. all rows are working based on this recommendation. I can not go to apple as I have used ziphone to unlock the iphone.
http://limitededitioniphone.com/iphone-touchscreen-fix-increase-sensitivity/
Jan 06, 2008 | Apple iPhone Smartphone
Apple iPhone Smartphone Logo
1,094 people viewed this question
Top Apple Cell Phones Experts
Computer Repairing
Computer Repairing
Lesley Cameron
Lesley Cameron
Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
