Question about Philips wacs7500 streamium 80gb wireless music center & station black
Philips Stremium WACS7500 not working
I have had my Stremium WACS7500 for several years. Without any warning it has simply stopped working. It appeared that the main screen had frozen. I switched off power and then re started, however this simply resulted in a completely blank screen and none of the feature buttons were illuminated either. The standby button is illuminated green, however the system does not respond to the remote control either. Has anyone experienced this problem before? Your assitance would be much appreciated Many thanks Karl
  • 4 Answers
SOURCE: NO POWER, PICTURE, OR SOUND, power button flashes green 2-3 times
had same problem. update tv software with a usb drive. do not take the tv apart. its easy download to computer unzip to usb drive and put drive in right side of tvs usb slot with power off, then turn power on, you should get an update screen.
did not work for me the first time i had to format usb drive to fat (not fat32) and then unziped to the drive took 10 minutes to update. I have tv 60PP9200D/37
Posted on Apr 28, 2008
SOURCE: volume control appears on screen uncommanded and cannot be sent away
I had exactly the same problem. The volume up button was constantly on, causing the on screen display to be permanently displayed. Here is the solution to fix it. This will also work for any other front panel buttons that are misbehaving.
Note: If you monitor is still under warrantee, don't try and fix it yourself - just send it back.
If you open your monitor you will find a small circuit board with a row of microswitches mounted on it. This is the circuit that's causing the problem.
To open your monitor you will need to remove the stand (one plastic cover that unclips by hand and 4 screws that can be removed with a philips screwdriver). This will then reveal two additional countersunk screws that need to be removed.
You can now remove the front cover. There are 4 clips at the base of the cover that can be removed by hand. You then need to pry the cover off, starting at the corner next to the power button. This is really quite stiff and you need to use a reasonable amount of force. Don't worry about the loud cracking sound as each clip along the side releases.
Once the cover is removed you will see the circuit board with the microswitches staring you in the face.
This board needs to be replaced but if you want to fix the problem immediately here is what I did.
Disclaimer - Proceed at your own risk from here on in.
Plug your monitor back into the power and reconnect to your PC. Make sure it's on and still showing the same problem.
The curcuit board unclips and there is a 7 pin connector that also can be unclipped. Remove the board and undo the connector. You don't need to switch off the power.
After the board has been removed for a few seconds, the on screen display that was permanently visible should disappear.
Now I temporarily disabled the malfunctioning button by bending the associated pin on the connector 90 degrees and then reattaching the connector.
How do you know which pin is associated with which button. Trial and error. Simply bend down a pin, and reattach the connector. If the problem persists, unplug and try the next pin.
When you've found the correct pin, straighten the others and reattach the connector.
Clip the curcuit board back in, making sure the connecting cable is clear and doesn't get pinched.
Reassemble your monitor and you're good to go.
The next step is to order a new circuit board from Philips. These should be really cheap (I hope) and you now know how to fit it yourself.
I'm going to try ordering one tomorrow.
Mark Gladding
Posted on Aug 04, 2008
SOURCE: My dvd model is philips dvp 3005 and it is in standby mode
my dvd player did the same problem. and i solved this just with a screw driver:) if your dvd player s guaranty finished!! switch off the player and open the screws which r 2 on sides and 3 behind the dvd. open the cover and take off the two group of cables on the chipset which are on the mechanical part side! (mechanical side: dvd driver) than plug the cables again to their socket. its done! close all and go on ! i hope this will solve your problem as mine...
Posted on Feb 18, 2009
  • 70 Answers
SOURCE: not repond The remote control
Hi, Unfortunatly, Philips had a design flaw from the manufacturer. You will need to have it serviced by a technician,but the replacement part is called an I.R. Board. It should only cost about 2 or 3 dollars,but the labor is the main cost of the repair,which you have a warranty for.
Posted on Jun 18, 2009
Pellepeloton
  • 55 Answers
SOURCE: Philips MCD708 Remote does not work...
Test your remote with a digital camera display, if no flashing LED then try to repair the remote with my Instructable: http://www.google.co.nz/url?sa=t&source=web&ct=res&cd=1&url=http%3A%2F%2Fwww.instructables.com%2Fid%2FRepair-your-remote-controls%2F&ei=mpVVSrr6O4_-sgP0-oDPDg&usg=AFQjCNGyomjVuVMr6mFT1L36ffi06FhCDg&sig2=kheNi9TulBWzmhGOMiIX7g
Posted on Jul 09, 2009
When switched on screen just blinks what is wrong
Get in touch with Philips support: http://www.support.philips.com/support/contact/contact_page.jsp?userCountry=ca&userLanguage=en
Mar 04, 2015 | Philips WACS7500/05 Shelf System
WACS7500 HDD partition
U can create a total of 4 physical partions on any disk...
U can then create total3 primary and multiple extended ones
What exactly is u need depends on what purpose the computer system is for
Oct 25, 2014 | Philips WACS7500/05 Shelf System
Stopped working for no reason
Light on? Do the fans run?
May 10, 2013 | Refrigerators
Philips Streamium WACS7500 STAYS ON CAN NOT USE
It is difficult to determine how much to repair because the computer needs a detailed check/test. Your computer repair shop can give you a quote.
Oct 08, 2012 | Computers & Internet
Wacs7500 streamium cannot read discs, just says 'no disc' or cannot read disc. have tried a cd lens cleaner with no success
remove the cover and gently clean the lens with a q-tip dipped in rubbing alcohol, then blow the lens dry. if all else fails, replace the optical pickup assembly (lens and spindle motor) or the whole player.
Jan 28, 2010 | Philips Audio Players & Recorders
How to connect Music Match Jukebox and Philips Stremium WAC7000
Hi, I went to a free forum where they don't milead you - ;-)))
Oct 17, 2009 | Computers & Internet
Shaver head light stays on
Your shaver does not have a sensor that identifies when you change the head. It is simply on a timer. Depending on your specific model, the light may simply go off after a couple of weeks or you may have to reset it with the power button. Refer to your user manual for details
Apr 08, 2017 | Philips Philishave HQ7782 Electric Shaver
We have a trusted Philips Azur Precise 4310 iron. Worked fine for the 2-3 years we have had it - then, suddenly, nothing! Power light on handle has gone out and the iron has completely stopped working...
It looks like a problem with the power cord. Try splicing the cord with a new one near the base of the iron and see if this helps. If not, it could indicate some connection problem inside the iron. In this case, it would be cheaper (and wiser) to simply go in for a new iron box..
Sep 28, 2008 | Philips Computers & Internet
Just went black without warning. Now won't come on.
What does the power light do when you press power? Does it blink? Please respond to this same post and I will try to help you with the problem.
Jul 19, 2008 | Philips Magnavox 9P6034C 60" Rear...
Philips wacs7500 streamium 80gb wireless music center & station black Logo
Top Philips Radio Communications Experts
Computer Repairing
Computer Repairing
wwlvictoria
wwlvictoria
Tom Chichester
Are you a Philips Radio Communication Expert? Answer questions, earn points and help others
