Question about Desa International GWP20T GLOWARM Wall Mounted Panel Heater
MY comfort glow model CBT30PT vent free gas heater is putting off an odor when it is on? what can I do about the odor?
Our heater was built in 10/ 2005 and has worked fine, no odor, etc until this year. The model #CBT30PY, serial 018365275. We have never had the problem before. We have checked all gas line, cleaned the unit before using it and the odor is still there. What can be done about this odor? Any information would be helpful.
  • Wayne Wintemberg
    Wayne Wintemberg Jan 05, 2014
    mine always has given off a odor I don't know what to do about it either I want to try some other type of heater, any ideas
SOURCE: comfort glo propane ventless heater won't light
I have several of these heaters in my rent houses and love them. The most problem I have is not being able to ignite the pilot with the user control igniter. Remove the screws that hold the front cover in place along with the front cover. Hold the pilot control down and ignite with a lighter. Keep the pilot engaged until thermocouple is warm enough to keep pilot gas flowing. If it will light this way then you need to blow out the pilot orifice. It seems that every year I have to go in after the summer season when the heater is off and clean the pilot/orifice lines with high pressure air. I believe spiders/bugs/dust block pilot orifice when it is not in use. You can also tell that orifice is blocked when you don't get a good blue pilot flame with pressure behind it allowing the flame to submerse the thermocouple. If the the thermocouple is not getting enought heat it will turn pilot gas off for safety reasons.
Posted on Dec 06, 2009
SOURCE: Where is the model # located on my Comfort Glow propane heater?
Usually it is a metal plate stamped to the unit.
Most common places to find it is usually located where the gas
valve and burner is located, it could be hooked to a chain.
Sometimes it is located on the side.
-Good Luck
Posted on Jan 08, 2010
SOURCE: I bought a comfort glow vent-less space heater
According to the Comfort Glow Website, this is a Natural Gas unit. If you use propane you will need
a minumum 100# LP Cylinder and a pressure regulator. I have a Comfort Glow unit and went through the same process.
If you have it hooked up to a 30lb cylinder without a regulator I would think that if you purged the gas line
of air you should be able to light the pilot.
On a new unit you can expect to push the spark ignitor button at least a dozen times while holding
down the gas valve button.
Good Luck
Posted on Feb 20, 2010
  • 10 Answers
SOURCE: I BOUGHT A USED UNVENTED
Check manual, get LP conversion part number than order. If no manual look online under the model number and look up.
Posted on Oct 05, 2010
mxc2
  • 146 Answers
SOURCE: comfort glow mod. cbt30pt lp
It sounds like you are loosing connection with your thermocouple to the gas valve.
Here are som einstructions on reseating the thermocouple.
http://www.msservice.net/ts/reseat_thermo-clean_pilot-ODS.htm
Posted on Oct 13, 2010
Comfort glow mod. cbt30pt lp gas valve closes off after ten seconds on
Oct 11, 2010 | Desa International CBP20T Wall Mounted...
Looking for a Comfort Glow Kerosene Heater Manual. Model #PHS/D
I am looking manual or answers for Comfort Glow Portable Heat System Model PHS/D with serial # 3D006270186
Jan 03, 2010 | Desa International Comfort Glow Infrared...
Pilot won't light
You may have to bleed some more air out of the system.
Your ODS pilot may be clogged with dust or lint and needs to be blown out with air(less than 30 psi).
Your regulator or gas valve may be faulty.
Dec 09, 2009 | Desa International Comfort Glow Infrared...
Do I leave gas value open when comfort glow vent free gas heater is not in use.
Just for tha sake of safety, close it!. You never know when something will happen. Usually right after you have questioned something and ignore it! Good luck...Lee
Nov 10, 2009 | Desa International Comfort Glow Infrared...
Have Model CGP30TB Copmfort Glow propane heater. Pilot light won't stay lit. Flames also coming from what seem to be air vents just below flame on pilot light.
sounds like an obstruction in pilot assembly.try using canned compressed air to blow directly into pilot. this technique is successful about 70%. if not,pilot assembly must be removed and cleaned thorougly
Sep 10, 2009 | Desa International Comfort Glow Infrared...
Comfort Glow Vent-free Gas Heater
I have a comfort glow gas heater that the pilot lights and when I start the heater it works for about 30 seconds then the whole thing shuts down.
Jan 02, 2009 | Heating & Cooling
Comfort Glow Vent-free Gas Heater CGN18B
the pilot light is operated off a millivolt generator. that is the small tube directly in the pilot flame. its purpose is to generate a small dc current which is connected to the pilot valve inside the main valve. setting the control to pilot opens just the pilot gas supply. when operating normally the millivolt generator keeps a small electromagnet pulled in that keeps the pilot gas supply open. if it don't work the pilot gas supply valve closes. replace the thermocouple.
Dec 04, 2007 | Heating & Cooling
Desa International GWP20T GLOWARM  Wall Mounted Panel Heater Logo
287 people viewed this question
Top Desa International Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Desa International Heating and Cooling Expert? Answer questions, earn points and help others
