Question about Whirlpool 24 in. DU1100XTP Built-in Dishwasher
I need an exploded view of whirlpool dishwasher
I need to find an exploded view of a whirlpool du1145xtpb3 built in dishwasher. It fills then the motor just hums. I think I should start by replacing the motor capacitor but I cannot find a diagram or service manual. Also, the washing light had been blinking seven times in a row. I reset it with the heated dry, normal sequence and it no longer blinks. I found no chart inside the lower panel to tell me what seven blinks means.
    Problem Solver:
  • 5 Answers
Something in the heater circuit -or- the motor has died. I found the front bearing on mine was toast.
Posted on Jun 08, 2009
Where can I find a diagram of dishwasher. Leaving soap scum and I found what looks like a part of dishwasher laying in bottom. Can't figure out where it came from.
There are excellent exploded view parts illustrations at any of the following websites:
searspartsdirect.com
appliancepartspros.com
pcappliancerepair.com
Another great website for parts is repairclinic.com, but they only include close up parts photos and not a view to see where it is located on the appliance. If you have questions, please post back with your MODEL NUMBER and let me know. I hope this helps you.
May 03, 2011 | Whirlpool Gold 24 in. Built-In Dishwasher...
Whirlpool Gold Dishwasher
Here is a tip the will elaborate on your problem more, but the bottom line is that you need to replace that fill valve...
http://www.fixya.com/support/r4021363-dishwasher_trouble_no_water_entering
heatman101
May 31, 2010 | Whirlpool Gold 24 in. Built-In Dishwasher...
Completely dead. breaker is fine. have live power at dishwasher. ???? Replaced heater, pump and check valve last year. No obvious burnt or disconnected wires.
There is a thermal fuse located behind the operator console on nearly all Kenmore or Whirlpool manufactured dishwashers. There were some noted problems with certain model dishwashers where the wire gauge on the thermal fuse was too small and would heat up causing the thermal fuse to blow prematurely. There is a replacement kit available that includes a wire harness with a larger gauge wire that you simply splice in place. It handles current better and prevents the fuse from blowing prematurely. To ease your mind, there were no reports of fire hazard.
If you need to view a diagram of your dishwasher, enter your model number at the website mentioned for some excellent exploded view illustrations. The thermal fuse is usually listed under the "Control Panel Parts" heading.
If you have any questions, please let me know. I hope this helps you.
Oct 15, 2009 | Kenmore 24 in. 17482 / 17484 / 17489...
Does the whirlpool GU1500XTLS1 have a fuse - I do not have any power to the console?
Yes, there is a thermal fuse located behind the operator console. The part number for the replacement kit is 8193762. You can view an illustration at appliancepartspros.com. It sells for about $13 and the instuctions with a wiring harness are included with the kit.
NOTE: You MUST follow the instructions and use the wiring harness. There were some noted problems with certain model dishwashers2.gif where the wire gauge on the thermal fuse was too small and would heat up causing the thermal fuse to blow prematurely. The replacement kit includes a wire harness with a larger gauge wire that handles current better, preventing the fuse from blowing prematurely. To ease your mind, there were no reports of fire hazard.
If you need to view a diagram of your dishwasher, enter your model number at the website mentioned for some excellent exploded view illustrations. The thermal fuse is listed as item 6 under the "Control Panel Parts" heading.
Oct 06, 2009 | Whirlpool 24 in. GU1500XTLS Stainless...
Liquid soap mistakenly used - bubble explosion
Fill the detergent cup with fabric softener for a full cycle. Don't be alarmed if bubbles seep out.
Finish off with a white vinegar wipedown of the insides if it still feels soapy.
Sep 09, 2009 | Whirlpool GU2400XTP Built-in Dishwasher
Dishwasher doesn't spray water after filling?
could be a blocked pump or capacitor fault,check if pump armature will move(centre rotating part)you may be able to view end of pump with lamp,there may also be a slot for a screwdriver to move armature,you will feel if there is something stuck,hope this helps
May 27, 2009 | Whirlpool DUL300 XTL Built-in Dishwasher
I have a whirlpool dishwasher (gu2500xtpq6) wont fill up
water level should be approx 1/4--1/2 inch below the heating coil.. this is normal fill level
Apr 28, 2009 | Whirlpool 24 in. GU2500 XTP Built-in...
Whirlpool DU1055XTP dishwasher fills with water but won't wash.
Can you be more specific? Does the dishwasher fill and then overflow?
Apr 11, 2009 | Whirlpool 24 in. DU1055XTP Built-in...
Whirlpool 24 in. DU1100XTP Built-in Dishwasher Logo
1,294 people viewed this question
Top Whirlpool Dishwashers Experts
Oloyede Monsuru
Mike
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
