Question about Whirlpool Water Heaters
Replace dip tupe on ee2h50rd045v whirlpool water heater
4 Suggested Answers
  • 21 Answers
SOURCE: Whirlpool energy smart water heater
Two flashes means that the high limit temperature has been reached. Once this happens, the temperature control system will shut off. Make sure that all element access doors are in place. Push the "Push to Reset" button to restart the temperature control system. The water heater will self test for ten minutes before it will start to heat. If you get the 2 flashes again then you may need to replace one or both elements. Each element should measure 5-25 ohms.
The "thermostat" is the knob marked "Temperature Control". Make sure that the operating mode is set to 1,2 or 3.
Posted on Jan 13, 2009
  • 5 Answers
SOURCE: Dip Tube
You may want to check the heating elements first. Where I live there is a lot of lime in the water that can coat the elements.
Posted on May 01, 2009
  • 5245 Answers
SOURCE: Troubleshooting whirlpool ee2h50rd045v water heater
1) Copy following links for whirlpool energy smart resources:
http://waterheatertimer.org/pdf/Energy-Smart-troubleshooting-guide.pdf
http://waterheatertimer.org/Whirlpool-Energy-Smart-electric.html
2) Control box is probably bad.
There are 2 types of control boxes for older-style energy smart water heaters.
You will need model number and serial number from label on side of tank to order from Whirlpool.
3) This older-type energy smart water heater is probably discontinued by AO-Smith, American, State, Craftmaster, Reliance water heater group that makes Whirlpool and Kenmore water heaters.
New generation energy smart offers interface with home automation and/or non-existent smart grid.
Older energy smart only offered potential interface with non-existent smart grid.
Posted on Dec 23, 2012
I have a us craftmaster EE2H50RD045V electric water heater. I worked fine until we had a 2 hour power outage and now its flashing to check the elements. It keeps resetting itself and flashing.
can only assume one or both elements shorted out and the only fix is to open it up and check them.start with the bottom one they usually fail before the upper
Oct 10, 2015 | Water Water Heaters
Dec 23, 2012 | Whirlpool Water Heaters
Hi...I have a Whirlpool water heater and the water only stays hot for a few minutes. How do I adjust the temperature or settings so that I can have hot water all the way through the shower instead of...
I am guessing this is an ele water heater and the temp setting are not the problem.
Problem: Not enough hot water or water temperature too low. When the top of the tank is hot the upper thermostat removes power from the upper heating element and transfers the power to the lower thermostat and heating element. If the lower thermostat is defective, then the lower portion of the tank will not be heated and the supply will be greatly reduced.
Check for power at the upper thermostat terminals where the power is sent to the lower thermostat and heating element. If there is no power then the upper thermostat should be replaced. If there is power then check for power at the lower heating element. If there is no power at the lower heating element then replace the lower thermostat.
If there is power to the lower heating element then it should be getting hot. If it is not, replace it. Another possibility is a broken dip tube. Check for a broken dip tube and replace if necessary.
The dip tub is located under the fitting where the hot water comes out.
Feb 03, 2011 | Whirlpool Water Heaters
2 green flashes. hot water is blazing hot set at 120 degrees.have the energy smart unit model#ee2h50rd045v . what is wrong?
2 green flashes is 'High Water Temp.'
Typical energy smart manual:
http://waterheatertimer.org/pdf/Whirlpool-energy-smart-electric-manual.pdf
3 flashes is Temperature Sensor failure.
4 flashes is Upper element
5 flashes is Lower element
Troubleshoot section says:
1) Make sure access doors and insulation are installed.
2) Check elements for resistance of 5-25 ohms (if element has a short in center of element, it might not trip breaker)
http://waterheatertimer.org/How-to-test-water-heater-element.html
3) replace element and reset control system.
Buy ordinary 4500 Watt element from hardware store.
http://waterheatertimer.org/How-to-replace-water-heater-element.html
4) I also suspect the self-diagnostic control box.
Manual says: Repair parts may be ordered through your plumber,
local distributor, home improvement center, or by calling
1-877-817-6750.
You need serial number, product number and model number from label on side of tank.
Jan 11, 2011 | Whirlpool Water Heaters
Lack of hot water from water heater
Unit needs a new "dip tube" It is cracked and allowing cold in water to mix with all hot water resulting in "lukewarm water". Need plumbing skills to change out at cold inlet top of heater,pull out old,buy new at hdepot 5.99 reinstall.
This has been a small manufactor recall on this matter
Please rate Thanks
jj505
Mar 29, 2009 | Whirlpool Water Heaters
I am not getting hot water from my water heater
Yes i would agree plastic dip tube .Do you have the hot water entering where the cold inlet is , do you have cold also attached ?
Dec 16, 2008 | Water Heaters
Dec 02, 2008 | Water Heaters
Water Heaters Logo
Top Whirlpool Water Heaters Experts
Donni Steen
Jim Goldsmith
Jim Goldsmith
jdthefixer
Are you a Whirlpool Water Heater Expert? Answer questions, earn points and help others
