Question about VAX Appliances Vacuums
I have a problem with Vax Rapide Ultra 2 carpet washer
When i am trying to push the washer with lever pressed (to release the clean water solution on the carpet), it only dispenses it through two ports and so creates parallel line while moving forward. When you pull it back (with lever not pressed), it sucks up everything. What i am not sure of is whether it only jets at two places on carpet or should multiple jets comes out from the washer making the carpet wet throughout?
reddevil6
  • 1673 Answers
SOURCE: Vax problem
Could be a bad pump.
Posted on Feb 22, 2008
Candyhelp
  • 136 Answers
SOURCE: Hoover Steamvac Ultra
make sure all parts are snapped in again i did the same thing.......
Posted on Mar 17, 2008
SOURCE: vax carpet shampooer wont release shampoo
if you unscrew a bit on the base that allows you to take off the brush, you will see a black plastic strip with very small holes in it. These are where your shampoo comes out of. Take a needle and re-pierce these holes and it should work again. I have just sorted mine out. good luck .
Posted on Mar 08, 2009
SOURCE: water lesking from vax rapide carpet washer
i have been using a vax v26 carpet cleaner and the washing water is leaking from the bottom then the solution will not come out has the pump given up?
Posted on Jun 14, 2009
SOURCE: every time i push the steam vac forward it dispenses water
you are having the same problem i am and so far the best solution i have found is i need a new clean tank just got my steamvac today bought it cheap so not complaining much the other solution i found was to only have the cleaning solution tank in for as long as i need it if i put the cleaning solution on the floor then take out the clean tank the dirt tank still sucks up the water
Godbless and Goodluck ...by the way just in case you dont have it here is the manual for your model
http://www.hoover.com/pdfs/manuals/F5914900.pdf
Posted on Jun 21, 2009
Vax rapide
I brought a rapide ultra carpet washer today , cleaned half of my front room brilliant then stopped spraying water using the trigger on the handle, as the handle comes off for easy storage I took it off, and what\'s happing is when you pull the trigger to release water a piece of plastic pushes on another piece ov plastic to release water and it was not working only by me pushing my finger on the other piece of plastic in side the handle bit, so mines going back ,
Aug 14, 2013 | Vacuums
Vax rapide ultra not sucking water
Dear Sir:
Retach the nozzle to the cleaner. Cleaned can be blocked most of the time.
Wait for cool down, and try again.1( See the hose defective 2( Test pumpmotor for some wires loose or belt if there are, so you need replace.
God bless you
May 26, 2012 | VAX Appliances Agilty V123 Upright Wet...
I need an instruction manual for a Vax Rapide Classic carpet cleaner
i have recently been given a vax rapid deluxe unfortunatley it didnt come with the manual.my problem is the water isnt coming out ? please help
Sep 11, 2010 | Vacuums
HELLO CAN HELP ME HOW TO EMPTY IT OUT WHERE DO I PUSH OR PULL
my vax rapide carpet washer powerjet will not let out water, who is out there who knows why.
Mar 08, 2010 | Dyson DC17 Animal Bagless Upright Cyclonic...
Water lesking from vax rapide carpet washer
Jun 07, 2009 | Dirt Devil CE5500 Floor Keeper Upright...
Vax rapide not realising water out
I have just managed to fix the problem i had with my vax rapide not releasing water. I also tried tilting it and that did not work. I unscrewed the brush from the base of the carpet washer and there is a black plastic strip with holes in where the water comes out of and onto the carpet. I used a needle to unblock these tiny holes which had become blocked after the last use. I now have it working again.
Nov 12, 2008 | Kenmore 23612 Progressive PowerMate Bagged...
Vax carpet shampooer wont release shampoo
Jun 01, 2008 | VAX Appliances Vacuums
I have a vax rapide carpet washer was using earlier and blew my trip switch noticed that the filter is falling to bits doyou think it can be repaired?
http://www.geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=553160
Generic problem for all Vacuums
I have a Vax Rapide
Posted by paulxlyn on Apr 28, 2008
I have a vax rapide carpet washer was using earlier and blew my trip switch noticed that the filter is falling to bits do you think it can be repaired?
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure.
Yes, you can contact your local vacuum cleaner dealer and if they don’t carry the Vax Model then feel free to contact the Vax Rapide Factory Manufacturer phone number or the website for further information and to order parts if needed. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.vaxusa.com/
If you have specific questions and you can't find the answer you’re looking for here, please call our Customer Service Department at 877.894.2031
M-F 8AM-7PM EST or check out our Contact Us page for more information.
Thanks, Don – The Vac Man
Go Ahead. Use Us.
Apr 28, 2008 | Vacuums
Vax problem
Feb 07, 2008 | Vacuums
Vacuums Logo
109 people viewed this question
Top VAX Appliances Vacuums Experts
seanwalters1
Level 1 Expert
Tom Chichester
Are you a VAX Appliances Vacuum Expert? Answer questions, earn points and help others
