Question about Compaq Presario 5000 PC Desktop
Floppy drive doesn't work.......not listed on My Computer
Floppy drive doesn't work......it is not listed on My Computer. It was working fine, and yesterday make strange noise and stopped. It is broke and can I repair it, or do I need to put in new drive? Compaq Presario 5000
    Scholar:
  • 88 Answers
Floppy drives are very cheap and easy to replace, another option, you might consider if you have a USB slot is to purchase an external floppy drive.
External's cost a little bit more but they are portable and you don't have to open the computer to install them.
Posted on Jan 18, 2009
    Problem Solver:
  • 15 Answers
Some one change your bios configuration and there make floppy drive disable you need to enable that then you can see your my computer list
It doesn't works
Does it work, if you install the disk-drive into a computer?
If not, then the drive is "dead", and needs to be replaced.
Feb 09, 2013 | Panasonic JU 257 (JU257A827P) Internal...
Iomega floppy usb-powered external floppy drive on windows 8
Hi, Sounds like driver related problem to me. Try use this tool to update the drivers: Driver Update Software for XP Vista 7 8. Wish you best of luck.
Nov 30, 2012 | Iomega Floppy USB-Powered External Floppy...
Does it work with Word 2010
I don't understand your question.
Normally a device (your floppy drive) is not operated by an application (Word 2010), rather, the device is operated by your operating system. I presume your operating system is some version of Windows and I presume your floppy is a USB device. That being the case, when you attach your floppy to your computer, the operating system identifies it as a resource. When you open your application (Word 2010), one of the 'save' options should be your floppy drive. If that drive doesn't show up directly, you may select it from a list of devices offered by Windows through save window that appears when you click SAVE..
The direct answer to your quesiton is ... there should be no reason to think the drive can not be used with the application. You can save (a document) to any device that is available to your computers operating system, even those shared through other computers on your network.
If I missed the ball, please clarify your question. If I did hit the mark, please remember a favorable evaluation for this response will be appreciated.
Thank you for your interest in FixYa.com today and please come again.
Jul 18, 2011 | SmartDisk (RF-FDUSB-TM2) (RFFDUSBTM2)...
Just bought a teac fd-05pub usb portable diskette drive. i have a dell computer with windows vista. when i pluged it in the device was installed, however the power light comes on for a few seconds then...
The below is on the basis that the drive is visible in "Computer"...
This can be tow thing, one the drive is not receiving enough power from your USB port, try unplugging any addtional USB devices connected to the PC, if this doesn't work try a powered USB hub. Second the floppy disk is faulty or the drive itself is faulty.
Hope this helps, let me know how it goes.
Thanks
Jul 11, 2011 | Teac FD-05PUB External Floppy Drive
I applied samsung sfd-321b floopy disc. but it doesn't work. the green light is on. But I cannot find on my PC. How can I solve the problem.
If the green light is constantly on then the ribbon cable has been fitted the wrong way around.
To fix some ribbon cables have a twist in them this side goes to the floppy drive and not the motherboard. The red line on the ribbon cable corresponds to number 1 on the drive itself.
Hope this helps!
Jul 10, 2011 | Samsung SFD 321B (SFD-321B) Internal...
Currently have a samsung floppy drive device manager shows its installed but not showing in computer bios changed to make as default boot device system doesn't recognize it have a PANASONIC product...
During the boot process you will see on the screen to press a certain key to enter setup
Press and hold that key during the boot up process to enter BIOS the scroll down to advanced bios features press enter change your first boot device to either swap floppy drive or boot up floppy seek both could be disabled press escape then press f10 to save to cmos to restart
(note after you have loaded the operating system you must go back and change the first boot device to your hard drive)
hope this helps
May 07, 2011 | Panasonic (JU-256A216P) (JU256) External...
Floppy drive not listed in computer mgmt
Your floppy disk drive has failed. You will need to replace it. they are usually pretty cheap.
May 31, 2009 | HP Computers & Internet
Need a new one
Any brand name floppy drive will work just fine. Does not have to be the exact same model or model number.
You can pick these up at either any computer distributor online (www.newegg.com , www.tigerdirect.com , other ones out there) or almost at any place that sells computer related devices (walmart, best buy, frys, local small computer shop). The plugs/pins are all the same in the back of the floppy, so it is completely interchangeable.
Apr 16, 2009 | Computers & Internet
Brand new Mitsumi internal floppy drive not recognized by Windows
Check the BOIS setup. Press on boot and see it the Floppy drive is turned on.
Mar 05, 2009 | Mitsumi (D359M3 SILVER) Internal Floppy...
Compaq Presario 5000 PC Desktop Logo
62 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
