Question about Refrigerators
What size generator do I need to run my Kenmore refrigerator model 253.68802011
How many watts do I need in a generator?
    Genius:
  • Refrigerators Master
  • 1,669 Answers
A 3Kw generator will power most refrigerators unless you add too many other devices to the circuit. There is a surge of electricity needed at start-up of any compressor.
Posted on Dec 31, 2012
5 Suggested Answers
  • 10865 Answers
SOURCE: i have a kenmore elite refrigerator. Am trying to
plan on 11 amps which would be 1100 watts and 115 volts.
Posted on Oct 03, 2009
SOURCE: cubic feet size of Kenmore refrigerator
Try this site: http://www.kouba-cavallo.com/refmods.htm
Posted on Nov 12, 2009
oldTech2332
  • 2341 Answers
SOURCE: Need to know if I
Hello Bob,
There should be absoluty no problem on that 1600 watt generator..at max when compressor just starts its drawing about 750 watts, that is the max usage when running its about 500 and on defrost its like 850 ..so on 1600 watt generator no problem
Posted on Aug 25, 2011
oldTech2332
  • 2341 Answers
SOURCE: I have a kenmore refrig/freezer.
The calulation of max wattage is going to be 750 watts at start up and be around 500 on normal running wattage after start up so a 1100 watt generator should be fine.
GENE
Posted on Sep 06, 2011
Onan 5500 marqui gen set stumbles on demand
Steve,
The microwave alone shouldn't cause a problem for the generator as even the most powerful models run about 1200 watts or about 10 amps. An air conditioner on the other hand, can draw considerably more power to run depending on BTU size; 15 amps and up is not uncommon (and even twice as much as that though only briefly when starting).
If these were the only things connected and on, the generator should be able to handle them - again depending on the BTU size of the AC unit. Generators state their capacity in Watts, but must of the devices we connect are in Amps. Calculating Watts in an AC circuit is complicated, but pretty close to the much easier Watts in a DC circuit for most residential settings. Here's how it's done:
Watts = volts x amps. Pretty simple stuff. Your generator is rated at 5500 watts. The microwave is say, 120 volts / 10 amps - which equals 1200 watts. The generator has 4300 capacity available now. Suppose your air conditioner is rated at 120 volts / 15 amps - which equals 1800 watts. 4300watts - 1800watts = 2400watts capacity is left. But, the starting current for the AC is as much as 25 amps for a few seconds (and once started drops back to 15 amps) - which means there's only 1200 watts capacity left. Add up the rest of the appliances you're running at the same time (TV set, Cable / Satellite box, stereo, toaster, lights, computer, etc.- you get the idea), and you can see how you might have exceeded the 5500 watts capacity of the generator for a few seconds. It's at these times that your hear / see the generator speed falter and sputter, lights dim, etc.. If this is happening a lot, you may need a larger or additional generator.
I hope this helps and good luck!
Dec 25, 2011 | Watts Onan Portable Generator - 5000 ,...
I have a kenmore refrig/freezer. Full load amp is 6.5 , 60 hz and 115 volts. I have a generator that will take 1100 watts with 1500 peak or surge watts. I heard that refrigerators use more electricity or...
GENE
Sep 06, 2011 | Kenmore Refrigerators
Need to know if I can run my fridge on small generator if there is power outage. Generator is 1600/1650 Watts; Amana fridge model TC18HG nameplate says 6.5 Amps. But I'm unsure about the starting...
Hello Bob,
Aug 25, 2011 | Amana Refrigerators
How many running watts will the saw take, I am buying a small generator and need to know the size I need.
The largest remington pole saw is an 8 amp model which would take about 900 W on a 110 v supply.
The 6 inch model takes 6 amps wich would be about 700 watt.
It's probably best to oversize your generator to about 2kva then you can use it to power lights and other power tools etc
Feb 17, 2011 | Remington Polesaw Wizard
Kenmore top mount refrigerator, 18 cubic feet. how many amps doe it use. question is for purchase of emergency generator. spec Plate states 4.5 amps, is that accurate? Refrig is 115 volts, 60 hz
Good day,
That sounds about right, however if your generator is rated in wattage the amps times volts won't work.
On an induction unit, such as a refrigerator, the wattage is volts times power factor times amps.
Nominal wattage should be around 375 watts. However, during auto defrost the heater will probably be around 450 watts.
As well, locked rotor amps on starting will be about 4 times running amps approx. 18 to 20 amps. so your generator will have to be able to handle that.
The short and long of it is give yourself wiggle room.
Aug 24, 2010 | Kenmore Refrigerators
I have a kenmore elite refrigerator. Am trying to
Oct 03, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Kitchen Aid Fridge Model KBR522K
Most fridges pull between 4 to 5 amps (600 watts) so a 1000 watt generator would cover all of them.
Oct 23, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
What size generator, watts, doe's it take to start AC unit 57915.531 ?
a 10000 due to the startup surge. also need start kits on any ac started by a generator.
Oct 08, 2008 | Dometic 57915531 Air Conditioner
Technical Question
A: Running watts are the continuous watts needed to keep items running. Starting watts, are extra watts needed for two or three seconds to start motor-driven products like a refrigerator or AC unit.
Aug 27, 2008 | Coleman Powermate Proforce 6,000 Watt 12...
Refrigerators Logo
176 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
