Question about Honeywell Heating & Cooling
Honeywell reset botton stuck
Ignitor botton red, reset botton stuck down will not push up on its own
    Genius:
  • 1,669 Answers
Buy some WD40 or CRC spray and using the thin tube that comes on each can, spray around each button to get penetration into the spring inside. Pump the switch until it loostens. If this doesn\'t work you need a new switch!
Posted on Dec 31, 2012
I reset my android now its stuck same screen how can i fix this
press home botton +volium up/ down botton+ power botton botton
Jan 09, 2013 | Cell Phones
Honeywell htt 011 air filter light won't go off
Thank you to MPODHOLA. After cleaning your Honeywell HHT-011, if the red light does not turn off locate the very small button under the red light. As suggested use a paperclip, hold the button for 5 seconds and this resets the system. Make sure the unit is on when you hold down the button. I tried it with the unit off and it did not work. Turned on the unit, held down the button for 5 seconds and the system reset. No more red light.
Dec 03, 2010 | Honeywell HHT-011 Air Purifier
No problem, just trying to find out what the amp draw is for this ignitor. Current ignitor pulls 4 amps, trying to cut down on usage in every way I can.Honeywell Q3200U ignitor
Because the ignitor uses resistance to heat up, it will use that much amperage only for a short period of time. A pilot light will cost you more than the pennies per year you spend on electricity.
Mar 20, 2010 | Honeywell Heating & Cooling
Thermostat does not read current settings or respond to commands.
HONEYWELL WEBSITE:
Go to honeywell.com
Under red welcome sign
Bottom red highlighted box literature/image search
Type in thermostat model number
Click on arrow to right
Then click on the PDF files owners manual / installation instructions
Oct 08, 2009 | Honeywell Power Humidifier: Furnace...
Zebra prints one page then light turns red.
TRY HOLDING THE BUTTON DOWN AND LET IT FLASH 5 TIMES. RELEASE. WHEN THE DIMENSIONS ARE AT THE CORRECT NUMBER PRESS THE BUTTON AGAIN.
Aug 19, 2009 | Zebra LP 2844 Thermal Printer
Honeywell Electric Baseboard Heater thermostat
You need to take the wires off the thermostat. And touch the red and white wire together. If the heater works then you need a new thermostat, if it does not work then you need a new ignitor. It all depends on the t-stat. Dont worry about the wires there are not enough volts to hurt you. It is milli volts so just touch them together and the unit should fire up
Apr 22, 2009 | Honeywell Programmable Thermostat Heater
Honeywell water heater. It's about 2 1/2 years old. I went to press the red button because the water was cold and it never got hot. The pilot is completely off and it won't go on after I press the red...
turn the gas valve button to piliot position, push it down and hold it, click the ignitor to light it... look thru the site glass to see the spark all at the same time, if it lights hold the button on the gas valve down for 30 seconds, let it up if it doesn't stay lit you need either a thermo coupling or a gas valve thermo coupling would be the first choice, the is also a filter around the bottom of th tank near the floor it needs to be clean that is the only soirce of air to run the heater
Apr 21, 2009 | Water Heaters
Trying to find out if my new hot water heater is shot
The red button you pushed on the hot water heater was probably what is called a "piezo-electric" ignitor. It's normal for it to make a snapping sound and then pop back out. It sounds like you just lost the pilot light.
That being the case, do this:
Turn the gas valve on the hot water tank to the "off" position - it should be silver in color and down low on the tank. You may have to push it down to do this
Leave it off for about two minutes or so
Rotate the valve back on to the "Pilot" position
Hold down the pilot gas valve - it should be red and immediately to the left of the main gas valve.
While holding the pilot gas valve down, push the other red button to the right of the main gas valve - this is the piezo ignitor - push it several times in a row quickly
The gas pilot light should light
You can stop pushing the ignitor now, but continue to hold down the gas pilot valve (the one just left of the main gas valve). Let this valve up after about another 20 seconds or so.
Now rotate the main gas valve to the "on" position
Listen carefully - you should hear the main gas light and feel heat at the water heater flue outlet on top - don't touch it with your hand - you could get burned
If no luck, repeat the process until the heater re-lights
TIP - the instructions for re-lighting the pilot should be written on the heater
Just a potential diagnosis - the thunder clap, if as close as you describe, may have been intense enough to create what is known as a "draft inversion" that may have snuffed out your pilot light. The air pulse came down the flue pipe.
Apr 08, 2009 | American Standard Water Heaters
Siemens Sx66 Pda phone- not responding for hard reset-
Hello, Did my solution fix your SX66 problem?
Jun 23, 2008 | Siemens SX66
Power button won't shut off
First thing to do is unplug the reciver for 12 to 24 hours. Sounds like it needs to be reset.
Sep 18, 2006 | Denon AVR-1803 Receiver
Heating & Cooling Logo
273 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
