Question about Hunter 23852 Classic Original Ceiling Fan
25260 model hunter ceiling fan - Hunter 23852 Classic Original Ceiling Fan
clyde2j2
  • 137 Answers
SOURCE: Light not working-hunter ceiling fan need part number 85112-01?
"Google" ----"replacement parts for ceiling fans"
there are dozens of sites that may be of help.
Posted on Mar 02, 2009
SOURCE: Hunter fan/light with remote installed turns on by itself
Many times this is caused by stray frequencies in the neighborhood. And, sometimes changing the frequencies on the remote and receiver reduce the occurrence.
But it sounds like this may not be the case, here. If not, the receiver in the fan is the culprit and should be replaced. No danger, just annoying.
Posted on May 31, 2009
  • 3 Answers
SOURCE: Hunter ceiling fan remote problem
You will most likely need to replace the receiver with a new one from hunter. The receiver is actually a complete controller and contains the receiver, relays (which you hear clicking) and starting condensors(large capacitors which hold a charge that is "dumped" over the windings to get the motor to start from a dead stop). These appear to be pretty tightly assembled unless you have a desire to start replacing parts "off the board."
Posted on Sep 07, 2009
SOURCE: Hunter ceiling fan remote 85095-01 stopped working
it also could be one of the the jumpers fell out of the remote
they are located just above the battery. you will need to match the placement of the jumpers with the receiver mounted in the fan.
Posted on Mar 09, 2010
  • 3640 Answers
SOURCE: The light on my hunter ceiling fan flashes on and
remove watt governor for lights. ( little black box). and wire lights direct. this is your problem.watt governors are used to reduce light output or energy. just remove it.
Posted on Jan 24, 2011
Hunter ceiling fan, replacing speed switch, what wire goes to the L, 1, 2, and 3?
I can only guess since I don't know what model or what color wires you have. Here's wiring for single stack switch on some Hunters;
L- black
1 - grey
2 - brown
3 - green
Hope this helps.
Feb 06, 2016 | Hunter Ceiling Fan Control Switch
Designers Choice Ceiling Fan Manual
All Hunter fan model numbers are 5 digit and start with a 2. Are you having a problem with the fan?
May 16, 2013 | Hunter Designer's Choice 5-Switchblades Lg...
Where can I get a new motor for my Hunter Designer's Choice Ceiling Fan (model # 99048
Call Hunter at 1-901-745-9222. I think this number is still current, it might not be. Tell them your issue, most likely they will send you an entire new unit (or is your fan the OLD Designer's Choice from the 80's with a rubber flywheel?)
Apr 06, 2012 | Hunter Designer's Choice 5-Switchblades Lg...
I need to purchase a Hunter ceiling fan receiver. The receiver model # is 85069-060.
hunter technical support number is-- 1-888-830-1326 call this number and they should be able to help. good-day ! just tell them you need a new receiver, and give them the model number of the receiver and the fan model number.
Aug 25, 2011 | Hunter Ceiling Fan Remote Receiver...
We got 4 HUNTER ceilin fans in one room. Model 27185-060 with remote FCC ID:IN2TX11 Two of them are runing clocwise another two in opsite side Wat can we do to run all in one direction?
Your Hunter ceiling fan is equipped with a small switch that changes the spin of the blades from clockwise to counter-clockwise. Regardless of the make or model of your ceiling fan, this switch is typically located on the center motor housing where the fan blades are attached. good-day!
Aug 19, 2011 | Hunter 52" Ceiling Fan With Light And...
Need the manual for our ceiling fan, Hunter, Park
i have to fans close to each other i would like to change the code on the remote
Apr 24, 2010 | Hunter Ceiling Fan Light Remote Control
Hunter 23852 Classic Original Ceiling Fan Logo
80 people viewed this question
Top Hunter Dryers Experts
Paul Bade
Thomas Perkins
Thomas Perkins
Are you a Hunter Dryer Expert? Answer questions, earn points and help others
