I have a beko wme8227w washing machine and about every 4 th wash the clothes come out with gunk on them do you know what is the cause of this?
barkencoa
  • 3463 Answers
SOURCE: how to change brushes on beko washing machine
remove rear cover of washer, locate and remove belt.
Unfasten motor ,disconnet motor lead, and remove motor.
Brushes are located at opp end to motor pulley.
Replace if less than 5mm long.
Plz rate my solution.
Thanks
Posted on Jan 21, 2009
Sea Breeze
  • 4655 Answers
SOURCE: Washer is turning my white clothes gray
Oil from transmission is a good possibility. The machine is still young but sounds like you do a lot with the washer. Better have a friend that don't mind looking it over, make sure that's oil and go from there!
Posted on Feb 02, 2009
  • 44 Answers
SOURCE: beko wma641w reset
hi
to reset these al you do is press and hold the start button for about 5 seconds then it should reset if not then you have a faulty pcb
regards
Posted on Mar 22, 2009
ginko
  • 19396 Answers
SOURCE: I have no manual to my washing machine and do not
Try locating the manual on Beko download page, click the link below to open the download page:
Manual Download Beko
Posted on Apr 17, 2009
  • 42 Answers
SOURCE: changing the brushes on a beko washing machine
Its been a while since I changed beko but here goes.......... Put the machine on its side (soapbox side down, This prevents excess water from the soapbox dribbling into the PCB and creating a further problem). There is an opening at the bottom of the machine in which you will see the motor. On each side of the motor will be the brushes each with a connecting spay-tag, gently take of the spay tag with long nose pliers (not grabbing the wire) and change the brush. VERY IMPORTANT.....each brush is angled and it is important you replace the correct brush eg. left hand brush to left hand etc. or else when you goto wash the next time you will simply hear a bang and have to price a new motor. I highly recommend when you take each brush off do it slowly noting its angle and replace the new one at the same angle. Wfen done replace the spay tag. I am presuming you know to do this when the machine is fully powered off and plugged out. Happy Fixing.
Posted on May 07, 2009
My Beko WMP601W wont drain, clothes come out soaking wet, also the draw keeps oozing with suds, all over the floor???
You need to check the drain pump is free of any obstructions, can you hear the drain pump operating?
The machine will need several short wash cycles to flush out the excess soap which is causing the suds.
Mar 26, 2017 | Beko Washing Machines
What is needing done to stop oily smears on clothing after being washed in beko washing machine
beko front loaders use sealed bearings ..
would suggest try doing several empty hot washes with a strong liquid detergent
and as a tester ..put in a white piece of material
check for oil sludge in the lint filter
if oil persists
have it looked at by a professional
May 27, 2016 | Beko Washing Machines
Black mould in rubber door seal beko washing machine how to remove?
Hi, the best way is to try and get a damp cloth and i use the end of a wooden spoon with the cloth to remove as much as i can. Then if and when you finish doing that i obtained from the supermarket a washing machine cleaner called Dr Beckmann deep clean .
Mar 18, 2016 | Beko Washing Machines
Washing machine fills with water but then won't wash, spin or drain
Hi Claire if your beko washing machine wont drain or has a spin problem then you have to check the carbon brushes first.
Also check all waste pipes are clear and inspect the pump I have included this video below.
At our website I am doing self diagnostic videos on these beko's as we speak so all tutorials will be in this link below
How to replace Beko Washing Machine Motor Carbon Brushes
you might find this test video helpful but only do it if you have checked the motor
Jan 28, 2014 | Beko Washing Machines
Beko washing machine not draining
If the drain hose is stretched too much to reach the standpipe, the hose can pitch.
May 21, 2012 | Beko WM5140W
Manual missing when purchased ,a new washing machine WME8227W
You can download this manual here:
http://www.beko.co.uk/manuals/wme8227.pdf
I would also contact the seller and complain that the manual was missing.
Ask them to post you a hardcopy.
Aug 15, 2011 | Asko 8005 Front Load Washing Machine
My beko washing machine WM 5140 is not taking the conditioner only the powder, and after every wash the clothes are coming out with a slimy residue on them even though i clean the drum and rubber seal...
beko washing machine WM 5140 is not taking the conditioner only the powder This video will show you how to keep your soap draw clear and how to service the parts
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
And don't forget to like us on facebook
Jul 30, 2011 | General Washing Machines
The washing machine belt keeps coming off any ideas why, should it have any stoppers or something to keep it from sliding off thanx . beko wma1512s
Belt would have become expanded after use. Try adjusting the motor base by moving in the direction it tensions the belt. Or replace with the identical belt No. Clean belt resting area free from any old belt rubber deposits /markings.
Apr 16, 2010 | Beko 24 in. D3731F Free-standing...
MY BEKO 1613S WONT WASH MY CLOTHES
Quite a common problem. The least common is the actual failure of the timer itself. It is much more commonly caused by the failure of the heater, water valve, pump, a broken wire or even a blockage in the pressure system or waste system.
May 03, 2009 | Washing Machines
Washing Machines Logo
61 people viewed this question
Top Washing Machines Experts
