Question about Kohler 14RES 14 Kw Generator
Kohler 14 RES won't start
Propane Generator, will not start. It has been cold out (-15F) at night. Oil was very close to a wax color and flow rate. Used an oil heater to warm up the oil. No Carb heater ( on order). Engine will crank, but not fire up. Tried over several days, varying temps up to 30F. still no luck. Will the Carb Heater cure this problem? If no, any ideas on what to look at next?
    Prodigy:
    An expert who has answered 500 questions.
  • Kohler Expert
  • 573 Answers
You need a couple of things / options. The carb heater base, and an oil heater (srews in the drain hole, and possibly a battery blanket at that temp. Some OEM's offer an adhesive strip that you can also stick to the bottom of the alternator, that is also 120V and warms the generator windings to keep moisture out
Not sure what country you ar ein but in the USA/CA they will be a 120V accessory and as such need utility power at the generator
Posted on Nov 19, 2013
4 Suggested Answers
SOURCE: I have a new Kohler 12kw res generator on propane - backfiring
did you put the propane orifis in and unplug the spark wire
Posted on Sep 20, 2010
GeneratorDan
  • 44 Answers
SOURCE: My 18RESL Kohler Propane Generator ran for 8.5
You have to reset it because it locked out on on under frequency. Just pullout the fuse on the control panel and then reinstall it a couple of seconds later. Now it will reset the fault codes. Hope that helps.
Posted on Dec 02, 2010
  • 12 Answers
SOURCE: I have a Kohler 12RESM1 propane generator with oc/uu code
U need to make sure that the relay driving ur auto start stay closed all thru the crank cycle.
Posted on Nov 30, 2012
Where is the speed sensor located on a 20resa kohler genset
Kohler Generator issue 20 RES - YouTube
? 0:24
www.youtube.com/watch?v=CT9u64dZna0
Apr 28, 2012 - Uploaded by Jeremy vanEyk
Brand new Kohler Generator Test cycle issue. ... Oh, and Mike, good call on the carb--that happens on some 20RES models. ...Indicates Locked Rotor (Lr). ... I'm on my second 20 RES-L,home depot swapped out the 1st one. ... Kohler 20KW RESA Whole House Standby Electrical Generator - Duration: ...
May 19, 2015 | Kohler 20resa 20kw Home Emergency Backup...
12 RES - Control Panel Dead With New Battery
If it won't start in manual, you have a short and/or a bad control board. Make sure battery polarity is correct, did you disconnect battery charger before removing old battery? If not charger can push DC volts over 20V and can damage control board.
May 26, 2013 | Kohler Electrical Supplies
I have a Kohler 12 RES home standby generator. Once in a while when the power goes out the generator will start and then immediately shut down with no fault codes. When I flip the control in the unit
Check the inlet fuel pressure, on exervise there is no load, when power is out it is loaded and demands more fuel. Also check for bugs blocking gas regulators vents etc
Nov 12, 2012 | Kohler Generator. 12 kW and 14 kW Home...
I have a Kohler whole house Generator that starts and works fine but stops after a hour or two. It restarts fine but again stops after an hour. Oil is good, load is not excessive, propane fuel is...
possible sensors to check are
overheat sensor for the coolamt
time run sensor if fitted
oil pressure sensor
loose wiring connections
possible icing of the gas regulator because if excessive gas flow requirement
have a gas fitter check the air mixture settings for the engine
Jan 15, 2018 | Electrical Supplies
Kohler 12 RES - Unit fails to start occasionally. Attempting a manual start by placing switch in run position, cause a loud click, but no cranking. The panel says CC. This morning I put a jump start...
I finally solved the intermittant starting problem on my Kohler 12 RES by replacing the strater and the starter relay. I was also experiencing the occassional OC indication, red blinking LEDs on the ATS, and intermittent non-starts during the weekly exercises. The problem happened during power outages a couple times also. If I flipped the start switch between auto and run quickly the generator would occasionally start. Once started, the generator runs fine. I ordered a new starter, which included the starter solenoid. By the way, don't worry about the genuine part thing..the old starter was a Delco made overseas. I ordered a new starter online for $85 (6744N) and it was indentical to the genuine Kohler starter. Replaced the starter and it improved the problem but did not totally solve the intermittent starting. Ordered the starter relay (GM49746) replaced it and the problem is solved.
May 09, 2012 | Kohler 12 kW Emergency Power System -...
The monitoring system of our Kohler propane generator has sent a "UU" message. What does this mean as it causes the generator to shut down 10 seconds after starting? Also how can this be...
The monitoring system of our Kohler propane generator has sent a "UU" message. What does this mean as it causes the generator to shut down 10 seconds after starting? Also how can this be corrected?
May 28, 2011 | Kohler 12 kW Emergency Power System -...
My 18RESL Kohler Propane Generator ran for 8.5 hours and shut down for overspeed. later it started up again and shut down for under frequency. Now it won't even turn over. Where do I start. I checked...
Dec 02, 2010 | Kohler 12 kW Emergency Power System -...
Is the outside air temp cold. These generators will backfire if it is real cold and if the propane pressure is low. It is suppose to be 11 to 12 inches of water colume at the generator fuel input. drygwals
Feb 18, 2010 | Kohler 12 kW Emergency Power System -...
Feb 04, 2010 | Kohler 12 kW Emergency Power System -...
Kohler 14RES 14 Kw Generator Logo
301 people viewed this question
Top Kohler Electrical Supplies Experts
rjivaro
Craig Butler
Craig Butler
John Trevino
Are you a Kohler Electrical Supply Expert? Answer questions, earn points and help others
