Question about Moen Plumbing
Faucet handle turns wrong way
Installed new moen wide faucet. cold water handle turns correctly clockwise. hot water handle also turns clockwise when it should turn counter clockwise. How to fix?
    Genius:
  • 1,669 Answers
You bought two cold water faucets. The threads are reverse on the hot water faucet. Exchange the wrong one at the store you bought it from.
Posted on Dec 31, 2012
Just removed an old Moen one handle pullout kitchen faucet and installed a brand new updated version. Unable to get hot water line to work properly.
some new faucets come with there on supply lines when you tighten one will twist at the top near the faucet look under the sink to see if this has happened. i've had it happen not long ago
Apr 04, 2016 | Moen Plumbing
L have a moen kingsley t125 with a moen 9000 m pact the cold water handle comes out with a trickle only when you turn it on the hot water is find unit is about one year old
You have a obstruction in cold side turn off both cold and hot water to faucet then disassemble cold side(take note of how you take apart it must go back correctly) slowly open cold water stop to see if you can dislodge obstruction(use a towel over cold water handle assembly to keep from water shooting everywhere).
May 30, 2011 | Moen Kingsley Two Handle Bathroom Sink...
We have a home that is 3 years old. We never used the 3rd bathroom shower until today. We have a Moen single knobe shower/bath valve. To get water from the faucet you pull the knob out. To adjust the...
Remove handle to gain acess to the temperature limit stop. Remove handle and pull out handle adapter kit and next there is a dail that can be adjusted to control the water to balance the temp. It could have been installed wrong, pay attention to where it is now and pull it back to it disengages out of the stem and move it counter clockwise a little and reinstall. Put handle on and test water for correct movement.
Go to link below for a part's diagram if needed.
TO ORDER PARTS CALL: 1-800-465-6130
www.moen.com
Aug 15, 2010 | Moen & Posi-Temp Single Handle Shower Or...
I just put in a Moen single, chrome handle shower faucet in my hall bath. Got it all together and the hot water is not comming out. Cold water is fine, but, when i turn the handle to the position where the...
If this is a Moen posi temp valve you may need to adjust the temperature limit stop. It is located under the handle. Usualy a plastic peice with grooves in it so it fits in another peice in the valve. If I remember right you pull this peice out and turn it counter clockwise to get more hot water. Do this in small increments and reassemble and test. I hope this helps.
May 25, 2010 | Moen Posi-Temp Single HandleTub And Shower...
& One Handle Tub & Shower Faucet : i have a moen shower faucet and i get not hot wate...
these valves can be adjusted by removing the handle and adjusting the white gear that regulates the hot and cold that come out, try going more to one way if it gets colder then go the other way.
May 16, 2010 | Moen & One Handle Tub & Shower Faucet
Moen single handle kitchen faucet, Hot water and
Hot water line connected to left side of faucet? Did you replace tap set, or just cartridge? Cartridge may be out 180 degrees.
Dec 29, 2009 | Moen 7065 Vestige Single-Handle Kitchen...
Moen Single Handle Shower Faucet-turn on get cold, little hot
You can try to rotate the first plastic ring to the left of center a few teeth, this will let the handle advance alittle more to the hot side.
Oct 09, 2009 | Moen 3175 Legend One Handle Shower Faucet...
Hot and cold backwards on a moen shower faucet
tun off the water.
unscrew teh allen screw under neath the handle. pull out hteh handle. undo the wall plate and gain access to the cartridge in the handle body. turn the artridge around 180 degree and reisntall all parts.
Apr 06, 2009 | Moen 3175 Legend One Handle Shower Faucet...
Not enough hot water, has to do with a shower valve
Hello, first if any water supply hot or cold is turned off, you will experience trickling as you mention. You must have both cold and hot in order to adjust the temperature on your valve. if you had a plumber intall this unit you should ask him to adjust it. Otherwise here is how:
Rotate the handle counterclockwise to stop and let water run till cold water is purged, check
temperature. Rotate handle to off, remove handle parts (see Disassembly in your manual) and temperature limit stop, rotate clockwise to decrease and counterclockwise to increase maximum hot water temperature, reinstall temperature limit stop and handle (TIP: Do not screw handle in until desired maximum temperature is achieved) Repeat steps until desired maximum
Feb 21, 2009 | Moen 3175 Legend One Handle Shower Faucet...
Shower Handle
You do not mention what make faucet we are talking about.
Moen makes two styles of Shower valves
The one that you discribe is called a Posi-Temp the goes from off to cold and to hot as you turn the valve counter clockwise.
The pressure should be greater mid range ans the cold and hot water mix but generally not noticeable.
A Moentrol valve is that should have been iinstalled in order to have greater control on temp and pressure.
Moentrols work but turning the valve clockwise for cole and counter clockwise for hot and pulling out on the valve for the water to come on.
sanray
Jan 09, 2009 | Plumbing
Plumbing Logo
443 people viewed this question
Top Moen Plumbing Experts
john h
Donni Steen
Don Numinen
Don Numinen
Are you a Moen Plumbing Expert? Answer questions, earn points and help others
