SOURCE: Bread toaster doesnt work
It could be the slide button connections or loose wires. You would have to take it apart to try and figure it out. It should be under warranty, though. I don't know if the box is required. You'll have to ask Back to Basics about that.
SOURCE: help with toaster. anyone there?
Well, I'm not a toaster pro, but I do make my fair share of toast.... I have an idea for you, I researched your product and couldn't find any specific help but try this:
Unplug your toaster, firmly hold the mechanism in the down position as far down as it will go, then turn the unit upside down, give it a good shake and flip the lever a bit. Reinvert, plug it in and see if you've got any improvement. (I think I learned this trick from the Andy Griffith show... you know old Emmett and the fix it shop) let me know if it worked! Sorry I can't be more help.
SOURCE: problem with the CUISINART RBT-450BKPC costco toaster
We had exact the same problem. Our problem was within the circuit board controlling the release relay, on the left side. 3 parts was dead:
1) rectifier diode 200V 1amp
2) Electrolytic capacitor 220uF 25V
3 Zener diode 12V 1W
These components supplies 12VDC to the rest of the circuits from the mains, 127 VAC.
SOURCE: Crumbs stuck on the sides and bottom of toaster
You can follow the instructions on how to replace the heating elemnts of the dualit toaster in the link
http://www.fixya.com/support/r4472039-procedure_replacing_heating_elements
With this way you remove yours clean the toaster completely and put the elemnt back.
Good luck
SOURCE: bread stuck in toaster. How do I remove cover to
you should turn it upside down and remove the bottom panel
