Question about Dirt Devil Featherlite Bagless Vacuum M085845Vacuum
Dirt Devil featherlite cyclonic belt comes off
Belt comes off almost immediately. I new belt has no effect. The belt will stay on with the handle in the upright position. Once the handle in lowered and the brush is in contact with the carpet the belt comes off.
  • 36 Answers
What makes the belt come off?
1) Wrong belt. use only genuine DD belt. No generics.
2) Worn out belt. Sometimes a worn belt acts this way. Just because it looks good, does not mean it is good.
3) Belt improperly installed.
4) Brush roll not spinning freely. (replace Brush Roll
5) Brush roll is not installed properly.
6) Machine is worn out where it pivots between the body and the lower nozzle. To check (without a belt installed) see if there is a lot of play forward and backward between the nozzle and the main body. If so, once a new belt is installed and you are pushing and pulling on the handle the motor shaft comes out of alignment.
NOTE: the #6 problem is the rarest and usually is due to an extreme amount of use over years.
Let me know if this helps.
Posted on Dec 31, 2012
nwj2468
  • 76 Answers
SOURCE: No Suction
it is probably the dirt fan. u may have to get it serviced
Posted on Aug 22, 2009
nwj2468
  • 76 Answers
SOURCE: replacing belt on dirt devil featherlite vacuum
did u check the owners manual
goodgold
  • 389 Answers
SOURCE: belt installation
The Regard. I performed this not once, and every time on move разберался. Nothing complex in general no. Simply take off first all lids, will afterwards find the bolts and staples, which keeps the rack vacuum прижима, will be an кольца and pucks. This simply. I shall prompt here is in than, sting you do not indicate the models so I have sent you manual , was more simply. There is some tricks. 1. You will be necessary to remove whole frame don't care, without this their will not draw on frame, her(its) it is necessary to remove. 2. Can be the belt only sprawl and so they slip. But condition belt good, simply they were extended and become more. So here is, remove the belt, set in order frame wipe the belt by liquid for rubber to moisten the belt. And when belt ready do so. Reel sticky summer скотч or another on grosses on which belt move, there there is drive axises and simply passive axis, so reel on drive if you will wind 2 mms, that this will it is enough, belt is drawn. Install the belt all and swab the axis a mask. Check that they all synchronous revolve and collect in inverse order frame. The Economy more $120US...
Thank you, good luck, write, I Sergey
Posted on Sep 14, 2009
  • 36 Answers
SOURCE: belt keeps coming off
I believe there is something wrong with the roller, could be the barrings or the end caps are warped. Try this, take the roller out and with each hand on each end hold the roller and try to spin the roller with your thumb. If it does not spin freely the problem is the roller.
Posted on Nov 20, 2009
VacuumRepair
  • 438 Answers
SOURCE: Got Dirt Devil Featherlite,keeps burning the belt
Hi There,
When a belt breaks immediately after installing it, this can ONLY mean one of two things. The first is that the belt was put back on incorrectly, and it may be pinched underneath of the beater bar. This would cause it to break immediately, but I seriously doubt after 4 belts that you put the belt on wrong all 4 times.
The second, and more probable cause is that your roller brush has gone bad. This could be why the belt broke in the first place. In order to test to make sure the brush is bad, unscrew the bottom plate, and remove the brush like you were changing the belt.
Hold the brush at the very end on both sides, using only your finger tips. While holding just the bearing caps, try spinning the bar with your thumbs. Does the brush spin freely in your hands? It should spin completely around 4-5 times on each spin. If the brush will not spin, or if you feel any resistance to it spinning, this is the reason why your belt continues to break.
If the brush can not spin, the motor shaft will continue to try and spin the belt, but since the brush doesn't spin, and the belt doesn't move, the motor shaft will just burn right through the back end of the belt.
If your machine is actually the model that's listed on this Fixya repair page, the Dirt Devil Featherlite model M085845, then your machine uses the following roller brush:
Dirt Devil Plastic Brush Roll for Model 085845 Part # 2-881020-000
The next time that change the belt, install the brush back into the machine, but this time pull up on the belt towards the brush to make sure that the belt spins freely, and spins the brush as well. If the belt doesn't spin the brush, there's some issue, and the belt will break as soon as you turn the machine on.
I hope this helped you. If you find out that you don't need a new brush, feel free to use the comment section here on the repair page and let me know, I'd be happy to walk you through some more advanced diagnosing. If you found this helpful, please be so kind and rate my repair and / or leave feedback for me.
Thanks so much,
Chris Jones
GoVacuum.com
Posted on Apr 22, 2010
My Mom has a Dirt Devil Featherlite and the belt falls off all the time. I put it on three times today and it falls off within a few minutes. The belt post I put it on doesn't have anything to hold the...
It sounds like the belt is too worn and loose to stay on. Buy a new belt specified for that model of vacuum and install. Ensure that there is only a slight amount of give in the belt when you press the middle.
Jan 05, 2011 | Dirt Devil CE6100 Featherlite Upright...
When machine is running the brush does not turn
You need a new belt. In order to change it, turn the machine compleatly upside down and place the head on a counter, handle on the floor.
There is a L shaped base plate to remove that has 5 screws in. Once the base plate is off, you see the brush roller and a silver shaft directly back from where the belt would ride. Remove the brush roller, place the new belt, Dirt Devil Style 5 ( see link below ) on to the shaft. Then insert the brush roller, so the belt is on the raised carved out section of the brush roller. Grab the brush roller at each end and stretch it till you are able to put the brush roller back into the base. Turn the brush roller backwards 3 compleat turns and the same forward to seat the belt.
Replace the base plate and you're done.
Dirt Devil Style 4/5 Belt - 2 Pack. Part # 3720310001 - Free Shipping Dirt Devil Style 4/5 Belt - 2 Pack. Part # 3720310001
Cost $ 8.00
Apr 28, 2010 | Dirt Devil Featherlite Bagless Vacuum...
Got Dirt Devil Featherlite,keeps burning the belt out immediately and there is only one way to put the belt on...have put on 4 new belts.....what up?
Hi There,
Thanks so much,
Chris Jones
GoVacuum.com
Apr 21, 2010 | Dirt Devil Featherlite Bagless Vacuum...
Belt is intact but brush won't turn
Even though the belt is intact it can still be stretched or worn and will not turn the brush on the carpet. Here are the belts you need:
Dirt Devil Featherlite Belt
Apr 07, 2010 | Dirt Devil M085850 Featherlite Bagless...
Dirt devil will not pick up
That means that you need to replace the belt. Here is the belt you need:
Dirt Devil FeatherLite Belt
Apr 06, 2010 | Dirt Devil Featherlite Bagless Vacuum...
I need to change the belt
Here is a link to the belts you need and the manual which has instructions.
Dirt Devil Featherlite Belts
Download the Manual (PDF)
Nov 25, 2009 | Dirt Devil Featherlite Bagless Vacuum...
Belt keeps coming off
Nov 20, 2009 | Dirt Devil Featherlite Bagless Vacuum...
Dirt Devil Featherlite Bagless Vacuum M085845Vacuum Logo
217 people viewed this question
Top Dirt Devil Vacuums Experts
Nick Olsen
JoeVacs
Are you a Dirt Devil Vacuum Expert? Answer questions, earn points and help others
