Question about Classco Jumbo Display Caller ID Phone
Ringer is not loud enough when button all the way up.
I put in batteries, pushed all volume buttons to max. The volume is almost muted. this phone is for a my grandmother who only has hearing in one ear. I have also attached another phone but neither ring LOUD enough.
What can I do? Must be something inside the phone
Model PH - 5562
Jumbo Display ID Speakerphone
Model No. 8/NM 7200846410
Please advise at your earliest convenience.
  • mangomomma Jan 19, 2009
    So your service is NOT free. To get a solution I must purchase the premium service?
THis problem is not fixed. I don't know how to fix it. That's why I asked you. I donot want to purchase your service, thank you. I want to know how to make the phone sound louder for an old lady I visit occasionally.
Posted on Jan 19, 2009
How do I turn the ringer on, on the handset?
Press program/mute button to confirm and you may program the following items: Set Language, Handset Name, Ringer Tone, Ringer Volume, Message Alert, Ring To Answer, Security Code, VIP Melody, Key Tone, Audio Predial, Vibrate Ringer, Area Code, Tone/Pulse, Registration, Deregistration and Default Setting.
Ringer Volume
From the Handset Setup Menu:1. Press the caller ID-volume ( 6 or 5) button to scroll to the RINGER VOLUME sub-menu.
2. Press program/mute button to enter the menu. SET RINGER 1HI 2LOW 3OFF shows in the display.
3. Use the touch tone pad on the handset to select 1, 2or 3, or use the caller ID-volume ( 6 or 5) button to scroll to your selection. HI is the default setting.
4. Press the program/mute button to save your selection. You will hear a confirmation tone and the new volume setting shows in the display.
NOTE: If you turn the ringer OFF, the ringer off icon shows in the display.
May 27, 2016 | Uniden Cordless Phone
How do I change silent from on to off so phone rings when I get a call?
On the D1680, D1481, and similar phones,
the three levels of ringer loudness plus
"off " are set at the base using the same
[ - ] Volume [ + ] buttons used to adjust
the answering machine message volume.
Pushing the [ + ] and [ - ] keys will
set the ringer to be louder or softer. A
number in the "message counter display"
will report the relative loudness...pushing
[ - ] below level-1 loudness will show
"0" loudness and an announcement of
"Ringer off" will be spoken. From here,
a single push of [ + ] will turn the ringer
on to level-1 and play a ~10 second
sample of the ringer at that volume:
while it is playing the sample ring,
subsequent pushes of [ + ] or [ - ]
will toggle the loudness levels of
( off, 1, 2, 3 ).
Jan 05, 2016 | Uniden DECT 6.0 Cordless Phone ID
How do i turn the ringer and microphone on in my iphone 6plus?
I can hear jingle bells in the background. You turn up volume with the the two larger buttons on the left hand side. Upper for louder and lower for lowering right down to mute. You need to be in the particular application when you adjust volume. In normal switched on and open mode, altering those buttons adjusts the ringer volume. Above those two buttons is the phones silent button. When you push it towards the back of the phone it turns off the ringer. When you are making calls, there is a mute button on the display. Also remember that the microphone is in the bottom edge of the phone next to the headphone socket. Don't cover it when you are making videos. Enjoy your new 6 Plus, they are amazing. I have the standard 6. It you have any other questions just ask.
Dec 27, 2014 | iPhone Apps
Volume on G E model 21028GE3-4
To adjust the speaker volume, press up/down on the base unit.
To change the ringer volume:
Make sure your phone is OFF (not in talk mode).
Press the MUTE/PROG button to go to the main menu.
Press CID/VOL (up or down) button to scroll to "HANDSET SETUP".
Press MUTE/PROG button to confirm.
Press CID/VOL (up or down) button to scroll to "RINGER VOLUME".
Press MUTE/PROG button to enter the menu. "SET RINGER 1HI 2LOW 3OFF" shows in the display.
Use the touch tone pad on the handset to select 1, 2 or 3, or use the CID/VOL (up or down) button to scroll to your selection. HI is the default setting.
Press the MUTE/PROG button to save your selection. You will hear a confirmation tone and the new volume setting shows in the display.
To change the receiver volume: When the handset is ON (in talk mode) you may adjust the receiver volume by pressing the CID/VOL (up or down) button.
If you need a manual, you can download one here.
Oct 06, 2011 | GE 21028GE3 Cordless Phone
My phone ringer is off and I don't know how to turnit on
You may follow the steps below.
2. Press mute/program button to enter the menu. SET RINGER 1HI 2LO 3OFF shows in the display.
3. Use the touch tone pad on the handset to select 1, 2 or 3, or use the caller ID-volume
4. Press the mute/program button to save your selection. You will hear a confirmation tone and the new volume setting shows in the display.
May 12, 2011 | GE Lands Phones
Ringer is set at max but is hard to hear
If the ringout volume is very low, then try not to select a soft, silent or low ringing tone. Try to choose a ringing tone that is loud so that you can hear your phone ringout.
Hope that was helpful?
Mar 18, 2011 | One Touch Jitterbug One-Touch Cellular...
How to adjust ringer volume
Yours is a little different from mine, but maybe this will help some, I hope. On the "talk" side, there is a button (2nd from right on mine) which says "loud" over the button, and "ringer" under the button. Pushing the button once gives you the soft ring. Pushing the button again will give you the loud ring. If you have gone to the loud ring, you will get the loud ring on the first time. Then you can push it again to get you back to the soft ring. I hope this helps.
Jan 23, 2009 | Panasonic 900 MHz Cordless Phone
Volume not loud enough
When you're in a call, there are two buttons on the left side of the phone that control the volume.  Outside a call these buttons control the ringer volume.
Nov 27, 2008 | Motorola Mobility RAZR V3xx Cellular Phone
Motorola cell phone sound problems W315
On the left side of the phone are two button: A rocker button and a push button. With the flip CLOSED, push the rocker button down. you will see Style:Silent. Push the other button until Style:Loud comes up. Push the rocker button down again to exit the function. Open the Flip and use the rocker button to set the Ringer volume. You can set the ringer volume however you want for each style. My phone swiches by itself constantly when I put it in my jeans pocket, very annoying.
Nov 01, 2008 | Motorola Mobility W315 Cellular Phone
Ringer off, need to re-install ringer. volume control does not put ringer back on
To turn your ringer back on, you do the following. For your handset, you push Menu, scroll to ringer settings, then push select, Press select again for ringer volume, then scroll up to turn on and increase the ringer volume. Then press Save once its at the desired volume. To change your base ringer, while it is not in use, push the ringer up button until you hear the desired setting. That should fix your problems.
Dec 31, 2007 | Panasonic KX-TG2357 Cordless Phone
Classco Jumbo Display Caller ID Phone Logo
158 people viewed this question
Top Classco Lands Phones Experts
Are you a Classco Lands Phone Expert? Answer questions, earn points and help others
