Question about Estate EED4400WQ Dryer
Dryer will not start
Thermo fuse good door switch good
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 31 Answers
I would say check your timer and motor.Dryer will not start - 12_31_2012_4_59_25_pm.jpg
Posted on Dec 31, 2012
Dryer does not start. I can hear the hummof it receiving power and have changed the motor and door switch.
Hi, I would check the white thermo fuse to see if it's blown. If the thermo fuse it bad it will keep the motor from running. Without a model number it's hard to give much detail, but here is a video that should be similar to your whirlpool dryer that shows you how to replace a thermo fuse. Most all Whirlpool Dryer thermo fuses are white in color. They show the most common one in the video, but your could be a little different shape too.
Aug 07, 2011 | Whirlpool Dryers
My dryer will not start when I push down on the dial. There is power to the dryer. When I turn the dial on to the timer, I can here the ticking sound, so the timer is working, but it wont start when I...
Maytag Performa Mod.PYET244AYW wont start has power door switch good thermo protection good at element cant fin any fuses timer has 120v and selecter switch
Oct 14, 2010 | Maytag Dryers
My kenmore 90 series dryer won't start
could be one of two things,, the safety switch in the door is bad, but more than Likely its the thermo fuse in the rear of the machine,, a blocked or clogged vent tube will cause this so check that too
Aug 02, 2010 | Kenmore Dryers
Push button does not allow the dryer to start
Check breaker, check door switch, & check thermo fuse inside back panel or inside panel under door
Oct 31, 2009 | Kenmore 62602 Electric Dryer
I have a maytag electric dryer it wont start on and the light does dont come on when door open i checked thermo fuse it tested good any other ideas
Did you pay the electric bill?
Seriously the door switch must be broken or stuck in the IN position. Seen it. Some repair info with pictures and locations of hidden safety devices.
Oct 24, 2009 | Dryers
Dryer wont start,
HI, check the following to address this issue.
1. No power to the dryer
Make sure there's power getting to the dryer. Check for a tripped circuit breaker or a blown fuse. Check the wall socket for power with a voltmeter or by plugging something else in.
2. Door switch / Door switch actuator lever
The dryer will not start with a broken door switch. Replace the door switch if found defective.
Most dryers have a door switch actuator lever - when you close a dryer door, it presses against the lever, which actuates the door switch. If the lever is broken, the switch would not activate and the dryer would not start. Replace the lever, if broken.
Note: Door switch actuator lever usually comes with the door switch assembly and it is recommended to get the whole assembly since there is almost no price difference between the door switch assembly and just the lever. Check your model for more details.
3. Thermal fuse
Most dryers have a thermal fuse, which burns out when the dryer overheats, in which case the dryer will either not run at all or stop heating. The fuse is usually located on the vent duct, inside the dryer. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting.
Note: It is recommended by most dryer manufacturers to replace a hi-limit thermostat when replacing a thermal fuse.
4. Timer
Replace if defective (note: uncommon problem).
**The most common issue here will be a defective Thermal fuse
Jul 24, 2009 | Bosch WTMC652SUC Gas Dryer
Dryer won't start
Does the unit have power? Have you physically turned the breakers off and then back on? Have you checked that the dryer cord is good? Have you checked that the outlet has not shorted out? If you have check all these things and it still won't start then it can either be a bad door switch or the on/off switch is bad.
Apr 11, 2009 | Maytag Dryers
LER331SRO Frigidaire electric dryer won't come on!
Check the voltage on the door switch, you can even jump the wires and see if it comes on, if not then replace the swiitch, Sounds like the door switch or the fuse. Door switch first though
Feb 12, 2009 | Frigidaire GLER331A Electric Dryer
Dryer will not start at all-maybe something with the start button
ck door switch first then your power to machine if all good ck the thermo fuse
Mar 01, 2008 | Kenmore 659 Electric Dryer
Estate EED4400WQ Dryer Logo
109 people viewed this question
Top Estate Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Terry Schneider
Are you an Estate Dryer Expert? Answer questions, earn points and help others
