Question about Pentax K Cameras
I want to use my old k 1000 lenses on one of Pentex's new camera body's.
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Pentax Master
  • 102,366 Answers
Your old Pentax lenses uses the Pentax K mount. The current Pentax digital SLRs all use the same K mount so the lenses will fit on them. You obviously won't get all the features available on new lenses, such as autofocus, but they should all work fine.
Posted on Dec 31, 2012
5 Suggested Answers
welsberr
  • 24 Answers
SOURCE: Camera lenses
If your new DSLR has the ability to be used in some mode with accessories like microscopes, telescopes, and the like (perhaps via T-adapters), you should be able to mount the lens via a screw-mount adapter for your brand. Unless the lens has a switch to make the aperture setting manual, though, or your adapter depresses the aperture pin on the lens, you will only be able to use it wide open. Generally, you should only expect to be able to use a manual exposure mode or perhaps an aperture priority mode.
Further, on some brands of camera (like Nikon), you will not be able to focus out to infinity with the lens with a simple adapter. While there are adapters that include an optical element to allow infinity focus, you should do some research to get one with good optical quality. The one made by Bower appears to do a decent job:
http://www.flickr.com/photos/mureena/2853461109/
Other camera brands may be able to attain infinity focus with a simple adapter.
In general, adapting an older screw-mount lens to a newer body is going to require some constraints that are likely only worth the bother if the lens provides some capability you otherwise do not have in your current selection of lenses or is unique in some fashion. It would be, for example, a good way to obtain the use of a lens like the Sirius 500mm f/8.8 mirror lens, which uses the fixed f/8.8 aperture. It would be doubtful that adapting the Sirius 80-200mm f/3.9 zoom would make you happy, though, when a lens offered within your DSLR brand of similar speed would not cost much and could be used in all modes offered by the camera, and have autofocus as well.
Posted on Sep 28, 2008
  • 20 Answers
SOURCE: Cannon lenses
All canon EF lenses (and compatibles e.g. Sigma EX) can be used with both analog and digital  EOS-bodies. Depending on the sensor size (usually smaller than a 35 mm negative) a crop-factor due to the smaller field of view must be considered.  Example: Canon EF 50mm/1.8 lens used on a digital EOS (40D, crop factor 1.6) equals a 80mm lens (50mm x 1.6) compared to analog cameras using 35mm film. Some digital EOS-models can also use EF-S lens-series.
Posted on Nov 28, 2008
Svetozar
SOURCE: can I use my old
Depends on the type of lens.
See this guide:
http://www.aiconversions.com/compatibilitytable.htm
Posted on Dec 04, 2008
  • 102366 Answers
SOURCE: Lense error on Nikon Camera
Try the procedures in this tip.
Posted on Aug 18, 2012
Can I use the old lenses on a new camera
Dec 31, 2012 | Pentax K1000 35mm SLR Camera
Old vivitar lens to adapt to a new digital camera
The nikon d80 you pointed out is a solid good camera. Id suggest buying it, if you are sure your lenses fit, didnt bother to check But I know Nikon is the way to go!
Mar 28, 2008 | Cameras
I have an old Minolta camera with quite a few great additional lenses. I'm looking at getting new camera and need to know what would I have to do to use those lenses?
That depends on how old the old stuff is. If the lenses have the ancient Minolta SR mount then you're pretty much out of luck (or you can continue using them with your old camera). If the lenses have the Minolta A-mount then they will mount on the Sony alpha-series digital SLRs.
Mar 28, 2012 | Minolta Cameras
How do you remove the lense? Bought new lense but didn't come with instructions on how to remove the old one.
Switch off your camera before changing or removing lenses to avoid dust being attracted to the sensor
If you camera is a Canon Eos Digital Single Lens Reflex, the lens fits onto the body by being inserted into the 'hole' in the front of the body. To disengage the lens, press the button found at 4 o'clock on the body looking at it from the front and right way up. At the same time twist the lens anticlockwise and the body and lens will separate.
To mount a lens, line up either the red dots on the lens and body or the white rectangle, insert the lens into the recess and twist clockwise until you feel and hear it click home I hope this helps
Feb 24, 2010 | Canon Cameras
I have an old Pantax 35mm SLR camera (zx5). Would the lenses still fit the new bodies or do I need to purchase an entire new kit?
Nope! Your old Pentax (and Taukimar!) lenses will still work. Any type of "K-Mount" lens will work on a Pentax digital.
Jul 01, 2009 | Pentax 100-300mm f/4.5-5.6 SMCP-FA Zoom...
Nikon Lenses
They will fit but will work only in manual mode
Jun 14, 2009 | Nikon 50-300mm f/4.5 Manual Focus Lens...
I have a pentex k1000 camera with a tamron ae 28-80 and ae70-210mm lens. They have pentex mounts on them. Are these lenses adaptable to todays autofocus cameras like the canon eos or pentex k100
If it is a pentax lens then yes but only for pentax cameras...it wont fit a canon at least not to my knolege. pentax makes all there cameas with the same lens mount.
Jun 07, 2009 | Tamron AF 28-80mm Lens
Trouble with Pentax MZ 60 camera.
does the camera work without lens mounted?
turn auto focus switch to manual focus when using non- auto focus lenses.
Dec 24, 2008 | Pentax MZ-60 QD 35mm SLR Camera
Minolta 7000 SLR
The Konica-Minolta 5d, and 7d, both discontinued but available used on ebay and other places will work with your AF lenses, as well as all the sony alpha camera bodies. KM sold their camera business to sony, and most of the whole maxuum/alpha/dynax group of engineers went with the sale to Sony. I had a 7000, and an 8000i, and all my lenses are quite happy on the 7D I picked up a few months ago on ebay.
Mar 27, 2008 | Konica Minolta Maxxum 7D / Dynax 7D...
Cameras Logo
80 people viewed this question
Top Pentax Cameras Experts
mohamed salim shaikh
Jerry Greenberg
Jerry Greenberg
Are you a Pentax Camera Expert? Answer questions, earn points and help others
