Question about Brother Mfc-j835dw All-in-one Wireless Color Inkjet Printer
My MFC-J835DW won't print although my computer indicates it is printing
Semi-Driver
  • 434 Answers
SOURCE: The printer
You may need to clean the printhead: (make sure you have paper in the tray)
1) Press <Menu>
2) Press <Up> or <Down> arrow to select "Ink" then press <OK>
3) Press <Up> or <Down> arrow to select "Test print" then press <OK>
4) Press <Up> or <Down> arrow to select "Print quality" then press <OK>
5) Press the <Color Start> button. The quality test sheet will be printed. Check this printout for gaps in any of the colors or black in the pattern across the page.
6) The display on the printer will ask if the print quality is OK:
- If all lines are clear and visible, select "Yes"
- If gaps appear in the pattern, select "No"
7) If you select "No" the display asks (in turn) if the print quality is OK for black, and the three colors.
Respond "Yes" or "No" accordingly. (In this manner you may clean just the black or color nozzle that is giving you the problem)
8) The display asks if you want to start cleaning - choose "Yes"
9) After cleaning is finished press the <Color Start> button - the print quality sheet will print again.
At this point you may determine that another cleaning cycle is necessary. You may need to repeat cleanings (up to five times) to resolve the problem. Any more than that indicates a problem that may need brother customer support.
10) When the print quality test sheet meets with your approval, you may exit by pressing <Stop/Exit>
Posted on Jan 23, 2010
pineworks
  • 4041 Answers
SOURCE: Print Brother Mfc-290c Error Print unable 4F
Hi there
With some Brother printers you can try this.
Access the internal maintenance mode by pressing the Menu/Set button, then press * 2 8 6 4 within 2 seconds. This should put you in the maintenance mode menu. Enter 80, and then scroll down with the arrow down (round) key. You'll find an entry listed as purge count. If number is over 6000, enter 2 7 8 3.
This will reset the purge count value. Then the printer will restart, hopefully without the annoying cannot clean message.
Some times this happens because of using cheap compatible ink cartridges if this is the case change the ink cartridges.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Posted on Feb 18, 2010
pineworks
  • 4041 Answers
SOURCE: Brother MFC 240c error 30 after printer jam.
Several conditions may cause the error message Machine Error 30, 33, 34 or 35 to be displayed on the LCD. This error may be the result of one of the following:
  • The print head carriage is failing to return to its home position to the far right of the unit.
  • Both of the springs located on each side of the carriage is out of place.
  • The cartridge covers may not be locked securely in place.
Please follow the instructions listed below to correct this problem:
  1. Press the INK button on the Control Panel.
  2. Using the dial pad, press 2 (Replace Ink). The display will prompt you PLS OPEN COVER.
  3. Pull the Scanner Cover release lever located under the Control Panel and lift the Scanner cover. The carriage should move to the left in order to replace the ink. If the carriage does not move to the left, your machine will require service.
    If your machine is still within warranty, click here to locate a Brother Authorized Service Center in your area or click here to obtain contact information for the appropriate Brother Customer Service Center. If you are out of warranty, use the link to locate a Brother Authorized Service Center in your area.
  4. After the carriage moves to the left, press down each cartridge cover and remove all ink cartridges from the machine. There are 2 springs located on each side of the carriage that hold the print head against the carriage assembly. They are thin silver springs approximately 2 1/2 inches, set at an angle.
  5. If the spring is out of place, press the spring back into place. You can use the spring on the opposite side of the carriage as a guide as to the correct position.
  6. If the spring is not out of place, reinstall each ink cartridge.
  7. After installing the ink cartridges, close the covers and verify they are securely locked into place. Your machine then prepares for a head cleaning and goes online. The LCD screen prompts you to verify if a new ink cartridge was inserted for each color you removed. For example, DID YOU CHANGE BLCK 1. YES 2. NO.
  8. Press 2 (No).
Note If you decided to place a new ink cartridge in for any of the colors when uninstalling and reinstalling the cartridges in the above process, press 1 (Yes). The machine will automatically go through a cleaning cycle.
Also this might be handy for you. To reset purge counter
1) Enter machine maintenance mode (on MFC240C all four photo/copy/fax/scan lights flash in maintenance mode). Care is needed in maintenance mode, otherwise critical settings may be inadvertently corrupted.
FAX models with numerical keypads: Press the Menu/Set, *, 2, 8, 6 and 4 keys within two seconds. (if you fail to complete the correct key sequence within two seconds, press the Stop key to try again).
Other (non-FAX) models: Press the Menu/Set and Black Start keys. Next press the “up arrow” key four times to enter the maintenance mode).
2) Press the 8 then 0 keys in the initial stage of the maintenance mode to call up the machine’s log information list (function code 80).
3) Press the Black Start key several times to scroll through the log information list to reach the purge counter. The purge counter is the 25th item in the list.
4) Press the 2, 7, 8, and 3 keys in this order to reset the purge count to zero.
5) Press the Stop/Exit key to return to the initial stage of the maintenance mode.
6) Press the 9 key twice to return to the standby state.
Please call back and gave us a vote. All The Best: Pineworks
Posted on Mar 02, 2010
  • 1382 Answers
SOURCE: brother MFC-290C not printing black
The nozzle may be blocked. So take out the colour cartridge and place its nozzle in a bit of water for about 10 mins. Bring it out and dab the nozzle with folded paper. If the tissue is blotted with the three colour it means you have unblocked the nozzle. Try now to print after returning the colour cartridge. You may need to repeat to get good results.
Thank you!!
Posted on Jun 25, 2010
Geekman
  • 32281 Answers
SOURCE: my brother mfc j220 canoot
It looks like the magenta print head nozzels are blocked.
Inkjet printers need to be used frequently to prevent inkdrying out in the print head nozzles.
If the print head cleaning maintenance routine does not clear the blockages,then print head needs replacing, but it may be expensive.
It may be more cost effective to buy a later model and better printer thanreplace the print head.
Posted on Sep 06, 2011
Error message "check connection" yet the printer works wirelessly.
If printer driver was shared from one of the pc, only the printing function can be used. For scanning functions, all PC should be installed direct to the network/wifi printer. Disable all sharing for this printer for the group.
Sep 12, 2014 | Brother Network-Ready Wireless Color...
Printer prints but stopped scanning
Delete the current Printer Drivers or Printer Software and reinstall the updated Software from your printer manufacturer. If the Printer works when printing a document; then the printer is getting the proper communications and it is recognized; thus the commands to scan are blocked and need to be renewed. If you have Photoshop, try their scan options and see if that works.
Dec 18, 2013 | Brother Mfc-j835dw All-in-one Wireless...
My printer won't connect to my network
Reinstall and set the priner up while it is connected by data cable.
Jan 28, 2013 | Brother Mfc-j835dw All-in-one Wireless...
Brother All in one printer screen is stuck on "telephone"
Press the Stop Button to cancel whatever you are doing on it. Then press Copy to be able to copy.
If you are printing to it from a computer it should just automatically get to printing when it is sent information.
Dec 21, 2012 | Brother MFC 7420 All-In-One Laser Printer
My brother mfc-7420 will print but won't let me scan and i can not find my disk
Go to the Brother web site and put in your MFC info and you may download it for free. If you find it to be difficult you may call Brother for support and they will walk you through it. Do not have to be under warranty. Hope this help you out.
Aug 28, 2012 | Brother MFC 7420 All-In-One Laser Printer
The black ink won't work even though its new
check if the noozles are on the catridges or on the independent print head. if the print head is seperate from catridges, them try print head cleaning. if you it cant work. then dip the print head in hot water for 5 to 10 seconds. dont dry it just put it back into the printer and try again immedeately. let me know if your problem is fixed
Jun 24, 2012 | Brother MFC J6510DW - Multifunction fax /...
Mfc 7860dw will not print from paper tray
Check the paper level in tray 1 and keep the paper within the levels indicated by the arrows on the side. I had this same problem, and although the paper tray accommodates the extra paper, the printer obviously does not like it and defaults to the manual feed.
Mar 08, 2012 | Office Equipment & Supplies
My MFC290C printer will not print in black. I changed the ink and it still won't print black. I changed the color of the type and it will print in colors, just not black. I ran the cleaning cylce...
You need to call Brother at 1-877-brother and tell them your mfc is "missing black". They will tell you where to take it to get the print head replaced under Brothers' warranty. This is a VERY common problem and Brother will cover the cost to repair it.
Aug 10, 2011 | Brother MFC-290C Printer
MFC-240C printer head repair
mY MFC-240C PRINTER IS NOT PRINTING WITH A MESSAGE " UNABLE TO PRINT SEE TROUBLESHOOTING
Nov 11, 2009 | Brother MFC 240C All-In-One InkJet Printer
Brother Mfc-j835dw All-in-one Wireless Color Inkjet Printer Logo
478 people viewed this question
CheckitRight
CheckitRight
James Cagle
James Cagle
Samyfam
Samyfam
