Question about Vizio L32 32 in. LCD HDTV
42" LCD HD TV keeps blowing fuses.
LCD HD TV blows a fuse every time we turn it on. We opened up the back and replaced the fuse.
Original fuse was T5.0A H/250V (ceramic fuse) We replaced it with non-ceramic fuses from Radio Shack. Does this matter? What else could be causing this problem?
  • Anonymous Mar 17, 2014
    turn on tv fuse blows right away? 42" gateay plasma tv
    President:
  • 1,077 Answers
A ceramic fuse stands up to heat better than a non-ceramic fuse. I'm no pro, but it sounds like your power inverter board maybe bad. There are replacements out there. Good luck
Posted on Jan 19, 2009
  • 3 Answers
Disconnect the cable from the TV and see if that keeps the picture on longer. I had the same problem it was caused by my ground having a steady 30 Volts coming from a loose wire in my box.
Posted on Nov 22, 2011
Tv does not turn on , there was a power outage and since then it wont turn on. there is power to the outlet
If the TV is completely DEAD. Check the main fuse in the power supply. Replace the fuse with exact amperage. Make sure you unplug the TV before taking the cover off. If the power supply keeps blowing the fuse, replace the power supply. Be very careful high voltage can kill!
Best of luck
AAA TV SERVICE
Jun 12, 2011 | LG 42LG30 42 in. LCD HDTV
Hey i have a 42 tv philips that has a transformer and the fuse blows in the transformer all time why is this? was usa tv
Tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.Because the power transformer and fuse blowns all the times,board have major shorts somewhere in the board with multiple components parts,will not able to solved it,only have excellent electronic trouble shooting skills and circuitries thoeries only able to solved it.
Jun 09, 2011 | Philips 37PF7320A 37 in. HD-Ready LCD...
My Philips 42"lcd tv modle
The parts on the Power Supply module will be to difficult to locate so the best thing is to replace the power supply board. The power supply is in stock at www.shopjimmy.com
The price is $83.96. Just enter your model number and follow the directions.
Nov 28, 2010 | Philips 42PF5421 42 in. LCD Television
Samsung LN40A530P1F LCD TV keeps blowing main power fuse when i turn set on it blows right away i have replaced fuse many times. Also when back was off i noticed a arcing as fuse blows at a component just...
http://www.samsung.com/us/support/detail/supportPrdDetail.do?menu=SP01&prd_ia_cd=&prd_mdl_cd=&prd_mdl_name=LN40A530P1F
If a fuse blows like that there is a major problem, inside. I suspect that what your are seeing is the inrush thermistor, and they exhibit this under great load. I would explect that this fault maybe in the actual PSU. Due to the lack of service manual support, i would get a quote for repair from an authorised service center.
Jun 22, 2010 | Samsung LN40A530 40 in. LCD TV
Heard a pop then screen went blank. Now TV wont turn on.
Sounds like your fuse.
If not the fuse in your plug, then the internal fuse in the TV. to get too this you need to open the TV by taking off the back plastic panel and look at the fuse.
the fuse is the glass tube on the board, will no doubt be near where the power cord connects to the TV. and are easy to replace with another fuse. you will know soon as you open it if its blown as the little glass tube will be blackened or the little wire inside the tube will be missing or severed.
Fuses in TVs are actually designed to blow over time with ware (usually to last a bit longer then the warranty time frame) so after the cover has ended the TV can go in for repair work at extra cost. Its a little known fact.
Jan 02, 2010 | Sony KDF-E42A10 42 in. LCD Television
Model 37M32ID/37 magnavox LCD. Replaced capacitor on power supply board location 2074 with 2200uF 35V. Fuse continues to blow. Replaced fuse with 250V F500mA. Is this the correct fuse? Original...
I think that is the wrong fuse but still it would pop if you have a line problem on the circuit that fuse is piping for a reason not the value but there are more issues on the circuit then what you repaired I would start digging and see if there are more popped caps! not in the power supply but else where like the hd push board or the decoder in better terms.
Thanks hope this helps if you cannot get it done take it in for a estimate as estimate will tell you the issue fixed or not and you can take that advice from that tech and repair your TV!!
Please do click the accept button if you like my advise.
May i suggest a service manual?
Dec 19, 2009 | LG 42LC2D 42 in. LCD HDTV
TV won't turn on
take the back off the tv and inspect the glass fuse off the ac power cord, it will probably be black and open, this is a common problem, it blows because the degaussing circuit works too slow, the original fuse is an 6.3 amp fuse, you need to replace it with a 6.3 amp slow blow or a 7 or 8 amp fuse to keep it from blowing, if you put an original 6.3 amp fast blow fuse in it, it will work for a while, but will blow again someday.
Sep 07, 2009 | Panasonic CT-32SX12 32" TV
Philips model 29pt3425-79 flat screen wont switch on
May try to replace your power supply. Average cost runs $200 via Internet. Also may inspect test & replace deformed an or any bulging caps.
Jun 01, 2009 | Philips 37PF7320A 37 in. HD-Ready LCD...
Vizio L32 32 in. LCD HDTV Logo
3,334 people viewed this question
Top Vizio Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
