Question about Shop Fox Dust Collector 1.5 HP, 1280 CFM, Model W1685
Got to have new motor - Shop Fox Dust Collector 1.5 HP, 1280 CFM, Model W1685
2001 plymouth neon windshield washer motor not working
check fuses and relays -if new bring back to installer have them repair --if new and you install recheck your wiring and motor hook up linkage also test switch and motor new doesnt mean free from defects
Sep 11, 2016 | 2001 Plymouth Neon
Whirlpool fridge no power on fan motor
check the fan motor itself to see if a wire did not short out
Dec 24, 2014 | Whirlpool Refrigerators
Need to wire motor for oreck xl upright
Your new motor should be very similar to the old motor. Compare the two motors to see if you can determine where each wire on the old motor should go on the new motor. If you are not sure it may save you money to have it wired by a qualified repair person. If you hook it up wrong it may damage the new motor and/or other electric components of your vacuum.
Mar 03, 2014 | Vacuums
Connecting replacement fan motor in HP condenser
What is the model number of the heat pump? What is the voltage that you are dealing with?
Nov 26, 2013 | Carrier Heating & Cooling
Motor wont start but runs without the belt on
replace the new capasitor,the capasitor is placing near the motor,unplug the unit before remove it and be carefull to touch the pin of the capasitor coz of high voltage,check the micro farad of capasitor and buy a new one,,but sometime the motor also problem if the motor have water mark is means replace the motor of new one,but ask the price of new one if is expensive try to buy a new one with 1warranty compare the motor you buy is only 1month warranty.
Dec 24, 2010 | Maytag Neptune MDE5500AY Electric Dryer
Old motor had 4 wires new motor has 7 wires new motor came with anew cap not sure how to wire
Are you trying to replace a two speed cooler motor? Verify the old motor is 120 or 240 volts which should be the same as the new one. Sounds like the new motor could be 240 volts.
Jun 29, 2010 | Heating & Cooling
How do I install a new windows motor- to include the cable drum (drivers side). The old motor burned up and the cable broke. Thanks Hans
You'll need to buy a new motor and regulator. You can go used or new, it's up to you. The regulator will include the cable.
- Remove the interior door trim,
- Disconnect the power cable from the window motor,
- Remove the window bump-stops (one at the front, one back),
- Remove the glass window from the regulator (two bolts),
- Slide the glass window out of the top of the door,
- Remove 3 nuts from the window motor,
- Remove all window regulator bolts,
- Slide the motor & regulator assembly out the top of the door.
- Mount your new motor to your new regulator,
- Install the new motor & regulator assembly in the reverse order.
Jul 27, 2009 | 2003 Hyundai Tiburon
Old capassitor has 3 prongs new capassitor has 2 prongs
The old motor relied on a leg off of the ol cap marked FAN. No need to bother with it anymore because the new motor probably has a different cap rating therefore it needs its own wittle capacitor. Cute ain't it? That new motor will probably have a common wire to connect to that Old cap at the C mark on it though. It will have 2 brown wires to connect to that new cap for it. (insulate that cute little cap to prevent any shocktastrophies) The black wire will of couse go to wher the old one did on the contactor. Read a little ditty I affectionatly wrote for further info entitled 'old motor had 3 wires new motor has 4 WTF"
Jun 06, 2009 | Heating & Cooling
Told motor was bad, replaced motor, new motor does not run
Black to Black, Purple to White and the new motor requires a run capacitor which brown goes to one side of capacitor and brown/white goes to the othe side of the capacitor. This is providing the old motor is a single speed. If the old motor is a two speed you have an incorrect replacement motor.
May 02, 2009 | Heating & Cooling
Shop Fox Dust Collector 1.5 HP, 1280 CFM, Model W1685 Logo
60 people viewed this question
Top Shop Fox Saws Experts
Tom Chichester
ray gallant
Are you a Shop Fox Saw Expert? Answer questions, earn points and help others
