Cannot connect to internet on wireless connection
  • 7,627 Answers
Is it the Wireless or the Computer? Is the wireless working? Connected properly? LED's blinking in the right place? You didn't give much info on the devices you are using? I can only give a general suggestion. The more info about What you are using, Make, Model of wireless and computer and the OS , the more we can assist you.
Posted on Dec 31, 2012
4 Suggested Answers
  • 21 Answers
SOURCE: Wireless and internet
1. Make sure that wireless settings are properly synchronized.
>> ssid/security key.
2. Check your computers wireless connection status
> Make sure that it is set to "obtain ip address automatically)
3. If still not working if computer is set to obtain ip automatically, try assigning static ip on wireless pc
> You need to know your router's ip address and dns
4. Disable firewall on wireless pc.
Posted on Jan 26, 2008
Geekman
  • 32281 Answers
SOURCE: the wireless internet connection wont work
Try turning off the router for 30 secs, then power it up again.
Then try connecting a LAN cable from the computer to the router and see if you can connect to the Internet.
If you can connect to the Internet then -
With the LAN cable open a browser and type in the configuration URL and check the Wireless settings, then check and/or the wireless card settings (it should have the router's SSID and encryption settings etc.)
Also install the latest wireless card driver.
Then test the wireless and Internet connection. If this doesn't work -
Next connect the computer with a LAN cable to the cable or DSL modem to see if you can connect to the Internet.
If you cannot get an Internet connection with the LAN cable, contact your ISP and get them to test the connection to your modem.
If the modem and Internet is OK and you still cannot get a wireless connection then the problem could be a faulty wireless router.
Posted on Dec 25, 2009
etaf
  • 779 Answers
SOURCE: Not able to connect through wireless
would you post back the make and exact model of the PC This is quite a long reply and may appear very technical - however, have a read through and see what you can do Answer.The following assums that your wireless connection is working and other PCs are able to connect:
There could be quite a lot of reasons you are not getting a connection to the wireless - some common issues 1) the wireless is switched off 2) Wireless Secruity 3) Firewall may be blocking 4) Remove profile 5) Check Device working in Device manager 6) Something else on the PC blocking so quite a few things to check - so lets start in order 1) Wireless Switch:- Most laptops have a wireless switch - some use a physical switch, other use a combination of the FN key + one of the F keys to toggle on/off - make sure this is on 2) Wireless Security:- Loginto the router, this may seem difficult, but its really straight forward, - however you will need to know how to login into your make of Router - A manual will be available from the routers manufacturers website to explain how to login. Once you have logged into the router main page, goto the wireless section and remove any wireless security, this maybe a simply as a box and click disable. --- Now see if the machine will connect to the wireless. Also remove wireless profiles http://mgmcc.forumotion.net/networking-tutorials-f17/removing-an-existing-wireless-profile-t109.htm 3) Firewall:- The firewall my be blocking access - try to disable the firewall. Often programs like Norton, Mcafee etc, when the subscription runs out can cause issues and need to be uninstalled, to uninstal you may need to use the removal tool available on thier websites. One of the ways to test this, is to do a PING test. Press the "Windows key" {bottom left of the keyboard} and at the same time press the "R key", now in the search box that appears - type "CMD", a black box will now appear on your screen, in that box type the following "ping google.com" if you get 4 replies then you can access the internet and your firewall may well be blocking the access try disabling the firewall. 4) Remove wireless profiles http://mgmcc.forumotion.net/networking-tutorials-f17/removing-an-existing-wireless-profile-t109.htm 5)Have a look at device manager Press the Windows key (bottom left of the keyboard} and at the same time press the R key, now in the search box that appears - type devmgmt.msc and see if you have any ? X or ! look under network adapters - click on the + and see if you have the adapter listed It will have a name something with wireless or 802.11 B/G/N included - check if it has any X or ! or ? 6) safemode:- Try to boot the PC into "safe mode with networking". To do this switch the PC on and now as it starts keep tapping the F8 key untill a menu appears, from that menu choose "safe mode with networking". If you can now connect to the internet,then there is something blocking your access on the PC when it starts normally - post back a comment and if that's the case, We can try doing a "clean boot" and try to identify the startup or process that is causing the issue A very useful tool to use for wireless issues is xirrus, http://www.xirrus.com/library/wifitools.php If you can copy the program onto the PC thats not working and install and run, this test if your adapter is working and also will display all the networks broadcasting in your area. Which will prove the hardware works.
If this solutions solves you problem, please do not forget to rate my solution. If not, then please comment back so I can help some more
Posted on Apr 15, 2010
Connected to wifi but no internet connection
Wireless networks have become an increasingly popular way to access the Internet. Connecting to a wireless network allows you to browse the Internet without having to physically connect any cords to your computer.
Troubleshooting wireless connectivity can sometimes be confusing, because even if a wireless network is not able to bring you to any web pages, often your computer's wireless card will still connect to the wireless network that is being broadcast.
In other words, a wireless network will read "connected" even if it is not connected to the Internet.
Connect to a different wireless network. If there is an alternate wireless network within range of your computer that you legally are able to use (a free public Wi-Fi rather than your neighbor's wireless network, for instance), try connecting to it and browsing the Internet.
If the same issue occurs on the alternate wireless network, you may have an issue with your computer's wireless card or with your Internet browser.
If you are able to connect to the alternate network but still not able to connect to your own, the problem is most likely localized to the wireless network you use at home.
Reset all devices.
The great majority of Internet connection issues can be resolved by a simple reset of all the devices in your home network.
Locate the power cords of both your modem and your wireless router and unplug them (if you use a modem/router combination, simply unplug its power cord) for a full 30 seconds.
Plug them back in and restart your computer.
Try to connect to the Internet using your wireless network after your computer has booted back up.
If the connection still fails, some further troubleshooting is required.
Bypass your wireless router.
If your computer's wireless card is connecting to your wireless network of choice yet you are still not able to access any websites, there may be a connection issue on either your modem or router.
The easiest way to locate the problem is to temporarily eliminate the router from the network. Locate the Ethernet cable that connects your modem to your router and unplug it from the router.
Plug the cable directly into one of the Ethernet ports on your computer and reset the modem in the manner described above.
Now try your Internet connection again. If there is still no Internet access, the problem is most likely with your modem or your computer; contact the technical support department of your Internet service provider (ISP) for further assistance.
If the modem goes online directly connected, your router is causing the problem and may need to be reconfigured. Contact the router manufacturer for further assistance.
Hope this helps
Oct 24, 2012 | Cisco Linksys WRT54GX4 WirelessG Broadband...
Setting up wireless conection to my wii
  • 1Before you connect Nintendo Wii to wireless Internet, set up your Wii console according to the manufacturer's directions.
  • 2Turn on the Nintendo Wii and wait for the main menu to appear.
  • 3Using the Wii remote, point and click on the small Wii button in the bottom left corner.
  • 4Select Wii settings.
  • 5In the bottom right corner click the black square with the number 2 in it or use the right directional arrow to go to the next page. When you come to "Internet" click it.
  • 6To connect Wii to the Internet select "Connection Settings."
  • 7On the next screen select the first connection that says "none."
  • 8On the following page, when given the option for wired connection or wireless Internet, select "wireless."
  • 9Now it's time for your Wii to search for a wireless connection. To do this choose "search for an access point."
  • 10Press "okay" and find the name of your wireless Internet. If it's not on the first page, arrow down until you find it. If you need a password to access the Internet, you will be asked to enter it. Click okay.
  • 11Click save and okay so the Wii remembers the wireless Internet connection options for the future.
  • 12Finalize the Wii Internet connection process by testing the wireless connection.
  • 13When Wii's wireless Internet test finishes successfully, you're ready to play Wii online.
  • Read more: Video: How to Connect Wii to Wireless Internet ' eHow.com http://www.ehow.com/video_5168009_connect-wii-wireless-internet.html#ixzz1f6AZS48m
    Nov 26, 2011 | NetGear WGR614 Wireless Router
    Cant connect to my router netgear
  • Read more: Video: How to Connect Wii to Wireless Internet ' eHow.com http://www.ehow.com/video_5168009_connect-wii-wireless-internet.html#ixzz1f6B48YnB
    Connected wireless to router, excellent signal, but unable to connect to internet.
    connected to wireless router with excellent signal may not means you are connected to internet. make sure your modem provided by internet service provider has signal! connect your computer to modem directly bypassing router. If you are online that means your internet is functional. Then connect modem to your Linksys router and use your wireless to log on to internet.
    Your router wireless signal active and excellent means you are connected to router not necessarily the internet. The modem supplied by your internet service provider with active internet should be connected to you router on WAN port!
    good luck!!
    Oct 07, 2011 | Linksys Wireless-G WRT54G Router
    I would like to know when it say laptop with built in wireless. Does that mine i already got internet service on it. Or i have to buy USB modem.
    Hello Blac,
    All the laptops available in market have built in wireless 802.11 b/g/n or 802.11 b/g/n Bluetooth® wireless networking. It means that you can access the internet via Wi-Fi or through Wi-Fi hotspots. In wireless connectivity you do not require the wired connection to access the internet. In home you can connect the laptop via wireless connection using the home networking router available in market. The advantage of wireless connection is that you can use the internet in your home anywhere with in 100 meters of range with proper wireless signals. You will require to get the internet connection from the ISP(Internet Service Provider).
    Please visit the link provided below for Home Networking Wireless Router :
    http://www.netgear.com/home/products/wirelessrouters/
    Jun 29, 2011 | Computers & Internet
    The wireless internet connection wont work. we previously had a wireless connection and now it wont register. we lost the connection completely and it doesnt show up on the list of internet connections....
    Dec 25, 2009 | Dell TrueMobile 2300 Wireless Router...
    Unable to connect to wireless internet. wireless connection shows disabled.
    check whether wireless drivers are installed.
    check wireless is enabled.
    check in network connections whether u can c wirelass lan connection.
    Apr 21, 2009 | Computers & Internet
    Can't connect the wireless internet to PS3!! HELP
    If you don't want your PS3 connecting to your wireless network, try going to the router control panel, and use the MAC filter to block it from connecting.
    Apr 20, 2009 | 2wire Wireless-G 802.11g ADSL Gateway
    My lap top connects to the network but I cannot get on the internet
    u need a wireless key to connect to the internet, log in to the router page and wireless settings - copy the wireless key to get connected wirelessely
    Nov 04, 2008 | Linksys Wireless-G WUSB54G 802.11g/b
    >> ssid/security key.
    Jan 23, 2008 | D-Link RangeBooster G WBR-2310 Wireless...
    Computers & Internet Logo
    16 people viewed this question
    David Payne
    David Payne
