Question about GE Profile Harmony DPGT750EC Electric Dryer
Ge harmony dryer won't power on
Won't power on
dragonsthatk
  • 547 Answers
SOURCE: ge profile harmony electric dryer doesn't always heat.
Remove back of dryer and take out the elament shield and replace element don't over strech it start at one side and work it around thank you for useing fixya rate me
Posted on Jul 19, 2009
garing
  • 998 Answers
SOURCE: DescrI have a GE profile harmony electric dryer
you should not have heat when motor stops there is a switch in the motor to shut the element off....yours is not working(you could burn your house)replace the motor.
PLEASE DO NOT TRY IT AGAIN...can't be lucky all the time
Posted on Aug 07, 2009
ftw1952
  • 10319 Answers
SOURCE: GE profile harmony dryer has power, drum turns,
check out the ignition spark ignitor
that makes the burner to heat up
Posted on Mar 12, 2010
mikes112
  • 56 Answers
SOURCE: My GE Profile Harmony Dryer is no longer Heating
Does it get hot when you turn it on, and then never gets hot again while its running? On my dryer the solenoid broke, when the dryer was cold it worked and the dryer operated properly because the dryer and solenoid were cold and the solenoid wire was closed, when the dryer was hot enough the solenoid opened and the heat would not restart. the solenoid is a coiled wire which is used to open the gas valve.
Posted on Mar 23, 2010
mkh5094
  • 145 Answers
SOURCE: I have a GE Profile Harmony Dryer. No Power.
Its not really clear to me where your measuring once you plug in the dryer, but all phases are measuring the correct voltage before, it appears you have an open circuit once you plug the dryer in. Now a dryer is 2 phase, so I would check all of your wiring connections, I would also check your circuit breaker and try swapping it out with a new one(as a last resort). Do some experimenting. In a dryer the heating elements are the only thing that runs on the 240V power. I would swap the hot leads in the dryer and see if any of the electrical components come on. Also try testing the continuity on your dryer plug wires to make sure there isn't a break in them (which can be proven by swapping the leads because now the same lead will read 0V on the other terminal).
Posted on May 04, 2010
Tip
GE Profile Harmony DPGT750GC
Are you having problems with your GE Profile Harmony but don't know where to start to troubleshoot? Let the dryer do it for you, here's how:
It's called "Field Service Mode"
1. Press the POWER key to turn the dryer on.
2. Press HELP. The main help screen is displayed.
3. Press and hold MY CYCLES and BACK simultaneously for 3 seconds. Press EXIT to return to the HOME screen.
The system will give you a description of possible hardware failure and troublecode.
Replace the failed piece of hardware and plug your system back in. It will go through a boot-up sequence and verify that your machine is working once again.
on Apr 30, 2009 | GE Profile Harmony DPGT750GC Gas Dryer
Tip
GE Profile Harmony DPGT750EC (Electric)
on Apr 30, 2009 | GE Profile Harmony DPGT750EC Electric...
Ge profile harmony electric dryer doesn't always heat.
Jul 16, 2009 | GE Profile Harmony DPGT750EC Electric...
GE Profile harmony dryer problems
Is the tub turning??Could be 2 different problems.I'll be happy to guide you through it.
May 24, 2008 | GE Profile Harmony DPGT750EC Electric...
How do you enter into the diagnostic mode
Dec 22, 2007 | GE Profile Harmony DPGT750EC Electric...
GE Profile Harmony DPGT750EC Electric Dryer Logo
108 people viewed this question
Top GE Dryers Experts
John Tripp
John Tripp
JP Services
JP Services
Are you a GE Dryer Expert? Answer questions, earn points and help others
