Question about Tracrac 2004 Ford F-350 - 6 9" short bed - T-Rac Truck Bed Rack
Lost power was driving at 60 mph and then it went down to about 20 mph received no codes. changed both fuel filters but no difference
    New Friend:
    Problem Solver:
  • 7 Answers
Try haveing someone check your gas tank someone might have dropped a hose or something in it that happened to me .
Posted on Feb 22, 2013
1999 oldsmobile alero missfire past 60 mph
do you have any code,bad spark plugs,fuel filter,air filter,coils could be too.
Feb 21, 2013 | 1999 Oldsmobile Alero
Lost power when trying to pull out of a gas station, turned off ignition and after about a minute was able to get power to bike but clock was flashing as if it lost all power. Later that day while riding...
Hi Nsmith845, and the usual suspects are:
1. Severely discharged or damaged battery.
2. Loose, corroded or broken battery cable.
3. Alternator not charging or below normal rates.
4. Failed ignition coil, ignition/electronic module.
5. Failed CKP, CPS, CMP, MAP, TPS, or BAS sensor.
6. Faulty ignition switch.
7. Water or dirt in fuel system, carburetor or filter.
8. Fuel tank vent system plugged or gas cap not venting.
9. Fuel tank empty.
10. Fuel valve vacuum line broken or carburator vent line closed off.
11. Restricted, blocked or kinked fuel line.
12. Failed fuel pump, pressure regulator and or fuel injectors.
For a prime suspect please visit website below and good luck:
Harley Diagnostic Codes 04 to Present
Sep 06, 2011 | 2011 Harley Davidson FXDWG Dyna Wide Glide
2003 honda element - it lost power while driving about 60 mph and then turned to come home.. going about 15 mph and lost power and started jerking - it did not die and the electrical was working - battery...
You should start with the basics, are you getting fuel and air to the engine and spark at the plugs? Is the battery being charged? When did you last change the fuel filter? Does the car still start and run?
Jan 08, 2011 | Honda Element Cars & Trucks
2004 chevy malibu 2.2 driving 60 mph shut down
either you have a fuel pump that went out, or your fuel pump relay went. These fuel pumps last around 100,000 miles, so if you're way under that, it's more than likely the relay, if you're close to that, it could be either.
Jun 14, 2010 | 2004 Chevrolet Malibu
As driving when speed reaches 19 to 20 mph it acts like it isnt getting any gas it cuts out and resumes
check fuel pump or change fuel filter. its not getting enough fuel, change fuel filter, and it should make a big difference.
Apr 22, 2010 | 1994 Cadillac DeVille
2001 Nissan Maxima loses power at 40 MPH.
Fuel pump is not pumping hard enough anymore. Have a mechanic check the pressure. Either pump is bad or the fuels filter is clogged. One other thing that causes this is a clogged Calalytic Converter.
Oct 27, 2017 | 2001 Nissan Maxima
Stalling around 15 30 mph
I would try insoluating the fuel lines anywhere they go past hot parts.I would also run some fuel cleaner in with a few tanks of gasoline. It has done wonders on my truck of 189k.   Lean or no fuel related problem do not set codes. Too much unburned  fuel sets codes.
Jan 11, 2009 | 2003 Mercury Mountaineer
Lossof power and ets off inicator on
check fuel pressure 1 fuel pump 2 fuel pressure regulator and 3 fuel filter.
Oct 30, 2008 | 1998 Chevrolet Cavalier
Engine power slows
Maybe batteries has lost it a little bit and need re-charge, i had the same problem.
Jun 17, 2008 | 2000 Lincoln Town Car
Tracrac 2004 Ford F-350 - 6 9" short bed - T-Rac Truck Bed Rack Logo
44 people viewed this question
Top Tracrac Boating Experts
Lawrence Oravetz
Mike
Are you a Tracrac Boating Expert? Answer questions, earn points and help others
