Question about Car Audio & Video
Got a red light on amplifire how do you reset amp I have an Insignia NS P2000 I believe with two 12-inch Insignia subs & I have a similar problem with the indicator showing that the amp is in protection mode.  I've checked the wiring and it's all fine.  I've also completely unhooked everything from the amp and plugged it all back in.  When I replug the components and the amp turns on, the light is green for a couple seconds and will hit, but then it goes red real soon.  Any idea what the problem may be and how to fix it?
    Problem Solver:
  • 5 Answers
Have you tried turning your gain down a little and then slowly turn the gain up while the sound is on!!!! There could be a pinched wire in you speaker wires!!!! Make sure your remote wire is not touching any metal or ground wire!!!!
Posted on Jan 18, 2009
My Insigina flat TV Screen is showing half purple and half black, what can i do to fix this right
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
Nov 01, 2014 | Insignia Brand LCD LED TV remote control...
Insignia ns ht51 subwoofer the speaker is vibrating but with no sound i believe it is the fuse, if so which fuse do i need
If the fuse had blown the sub woofer would be dead. I think you have a very low frequency oscillation problem . Now the frequency is so low ( below 15Hz ) one cannot hear it but if you look at the sub woofer speaker it will be pushing like a piston - to and fro very powerfully.
You will need professional help on this one.
Apr 28, 2011 | Insignia NS-HT51 Speaker
2 12" subs + 600W amp. Turn on, goes boom once, then red light
Is your gain all the way up? If it done this before, sounds like your over working the amp. Make sure your subs ohm load is capable with the amp load to. If they are 1 ohm and your amp is only 2 ohm stable, it would beat for a lil bit then go into protection mode to. Check your wires too.
May 13, 2010 | Insignia 600W Bridgeable Amplifier with...
I have two 12 inch rockford p1 punches powered by an 800 watt sony explode amp (2 Channel) and i want to install another 15 inch kicker with a 1200 watt amp not sure the model, i got it from a friend and...
I have a similar setup & I just run the second amp straight off the other amp by running positive & remote wires directly from 1 amps positive & remote inputs to the others amps inputs. But my head unit has RCA inputs, (sub in & front & rear inputs) so from my 4 channel amp I run 2 6 inch alpine S's to the front to the front RCA inputs of the head unit, & 2 Pioneer 440w 6x9 inch speakers to the rear inputs. & my 800w 12 inch sub from my 2 channel amp to the sub woofer inputs on the head unit. Has blown my eardrums for nearly 12 months now great stuff! Hope this has helped
Mar 12, 2010 | Sony Car Audio & Video
The amp light turns red
it is probably a bad ground, but maybe not, but maybe.......hope this helps
Mar 18, 2009 | JBL BP300.1 PowerValve Series Car Audio...
Red tint on my TV, instead of all colors? Reset doesnt work?
Sounds like the component cables are misplaced. Check that, and report back.
Dec 30, 2008 | Insignia IS-LCDTV32 32 in. Television
Not getting Charged
If you mean the Insignia NS-BTHDST or NS-BTHDP, I read elsewhere in this forum that you can reset it and that might work. See the manual. Basically you hold the volume up and volume down together while the charger is plugged in. The instructions were vague and mine did not reset nor show a purple light as indicated in the manual.
However, after trying that a couple of times, I accidently got it to work by pressing the phone/play button twice. Press it normally, not the long press you use to turn it off and on.
So in other words, plug it in to the charger. Press and releas play. Press and release play.
For me, the charge light turns on and it starts charging. I hope this helps.
Mine is new too, sort of. It was an "open box" from an ebay seller. I may return it anyway, since it is clearly NOT behaving correctly. You shouldn't have to press buttons at all to get it to charge. I know because I have another one.
Bon chance, mon ami.
Oct 10, 2008 | Insignia Bluetooth Wireless Headphones...
Amp getting hot and shutting off
no mine do that and its pretty much normal
Jun 06, 2008 | Insignia 600W Bridgeable Amplifier with...
Installing The Subwoofers to the amp... etc.
You should go with a 4 guage power wire kit. If your amp is going in and out
at high volume than that is your problem. 8 guage will work but, if you want
the proper current which is your power from your battery, going to your amp
than I would recomend the 4 guage amp install kit or just the main power
wire coming from your battery. If you would like contact me and I will send you
to a very good sight with all the info you will ever need for car amplifire installation.
Apr 21, 2008 | Insignia 600W Bridgeable Amplifier with...
12 inch insignia subwoofers model # ns-sub12
how to wire 12 inch insignia sub woofers
Apr 01, 2008 | Car Audio & Video
Car Audio & Video Logo
344 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
