Question about Frigidaire ATF6000ES Front Load Washer
Frigidaire front load washer fills up with water on its own
My washer sometimes fills with water and if I don't check before I open the door it floods the room. If I catch it I can run a rinse wash and it will run the water out - does anyone have this problem and know how to stop it?
SOURCE: Frigidaire Front load washer FTF2140FS
I HAD THAT TOO I UNPLUNG IT FOR 30 MINTUES AND WHEN PRESS START AND CANCEL TOGETHER AND PLUNG IT BACK ON IT SHOULD BLINK A FEW TIME THEN STOP . IF THIS DOESNT WORK THEN REMOVE IT AND MAKE SURE NOTHING CAME LOSE AND PLUG IT IT AND IF THEN NOTHING HAPPENS SORRY ITS BROKEN REPLACE CONTROL PANNEL.
30-50 $$ NOT MAD AT ALL
Posted on Nov 10, 2008
Coldcut
  • 1554 Answers
SOURCE: Frigidaire FWTr445rfs1 front loader - door closed but buzzes during washing
by the way it too fixya over 14 hrs to relay that message
Posted on Apr 16, 2008
SOURCE: FRIGIDAIRE FRONT LOAD WASHER
I too had the same problem, I closed the soap tray and a magnet popped out and got stuck to the door. Same problem with it acting like it was going to start and then beeped. This is where the magnet goes, just stick it back in, its held in with pressure (barely) :)
I took the whole control panel off to locate the magnetic reed switch, then just reverse engineered where the magnet is supposed to go on the soap drawer.
Posted on Sep 26, 2008
  • 29 Answers
SOURCE: frigidaire front washer has power but won't fill up, drain or go through correct cycles
You'll very likely have something caught in your drain pump. First set the washer to drain and spin. If you hear a hum or grinding noise and the water in the tub isn't draining or it's draining slowly you have something in the pump. If you take the rear panel off you'll reveal the drain pump at the right front corner or maybe middle on this model. if you empty all the water from your machine you can take off the spring clamp (this can be tricky) attaching the thick rubber hose from your tub to your drain pump. (you may want to have some old towels ready) With this off you can feel around for what's blocking the drain pump's impeller. You may want to take the screws out that secure the drain pump to the base and the other spring clamp that attaches the drain hose to the drain pump. Good luck!
Posted on Oct 15, 2008
SOURCE: frigidaire front load washer won't spin, belt looks good, makes noise
Don't have much experience on Frigidaire. Is the motor a brush type, capacitor type or one of those new DC types? If it's got brushes and they are ok, then I would say your armature is up the creek. If it's a capacitor type (unlikely) then the capacitor is most likely duff. If it's the new DC type it could be a lot of things, most likely the module which breaksdown and passes an AC component in the motor supply which make the motor tremble but not rotate
Posted on Nov 02, 2008
MY FRIGIDAIRE FRONT LOAD WASHER WONT FILL WITH WATER OR SPIN . HAVE TRIED CLEANING THE DOOR LOCK & UNPLUGGING IT FOR EXTENDED PERIODS OF TIME.
Sounds like the fill water solenoid has bust, they are cheap to replace and fairly easy. make sure you disconnect from power supply and water supply before trying.
Jan 30, 2014 | Frigidaire GLTF2940ES Front Load Washer
Frigidaire gallery top load washer
After 13 appliance years, your washer is a candidate for replacement.
Aug 08, 2017 | Frigidaire CWS3600AS Top Load Washer
I have a Frigidaire Front Load washer Model#ATF6000FS2 washer . It will not start and seems to be experiencing a problem with the door. There is 'DOOR LOCK' light that does not turn on and th
Sounds like the door is not latching correctly. Check the door for any sagging problems and then check the door latch itself for any damages, cracks, or issues with the door itself connecting to it.
Jul 21, 2012 | Frigidaire ATF6000ES Front Load Washer
I have an ATF8000FS1 front loading washer. after wash cycle(when water drain out) It smell like sewer! I leave the door open after use and when not in use. How to solve this problem ........ Please let me...
I recommend purchasing "Affresh" for front loading washers. It is used to clean and freshen up your washer. It can usually be found at any major brand grocery store
Sep 12, 2011 | Frigidaire Washing Machines
My washer is filling with water when i'm not using the machine. I read somewhere abot some wort of inlet vavle needing to be replaced?
Unplug the machine. If it still fills with water then mechanically the water valve has failed. If it don't fill while being unplugged then something in the control is doing it, might be the main control is bad. Who knows?
Affinity Service Manual
Jun 25, 2011 | Frigidaire Affinity ATF7000E Front Load...
My Frigidaire front load washer won't start it doesn't even fill up with water and it also doesn't spin.
Most likely a faulty door switch. Machine thinks door is open and won't start. Part number 131763202
Apr 09, 2010 | Frigidaire ATF6000ES Front Load Washer
Washer filling with water when off
sounds like a bad fill valve...contact HHGregg. This is a warranty issue. Do not attempt to make any repairs, it would void your warranty and then you would have to bear the repair costs.
clarkco
Feb 12, 2009 | Frigidaire ATF6000ES Front Load Washer
Frigidaire ATF6000ES Front Load Washer Logo
283 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Jason Harris
Jason Harris
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
