It is a marantssr4001 shows pow5 - Computers & Internet
  • 3,799 Answers
Ask in the audio or Hi-Fi section as your Home theatre receiver is not a computer.
Posted on Dec 31, 2012
#324 chak printer alram cameing
when you power on your fax machine and display show DATA ERROR its mean that 3 volts battery on the main board expired and lose all data fax number, logo and related with cartridge ink data so first of all you replace the battery. (this is a pure technical job and if your are not a technician you must take help of a technician)
After replacement of battery you power on fax machine and press
function key display show DATA REGISTRATION
press # display show #1SSSW
press left arrow key one time display show TEST MODE
press start/copy key display show TEST MODE [1]-[8]
press # display show AMI MODE
Press 7 display show FACULTY 1-6
press 5 display show INK CHECK 1-2
press 2 and start key
display show INK=YES and INS (ink level any one within 100 for example 42/205 you just remember first two digit of lest side)
press stop display show FACULTY 1-6
press 6 display show LOST INK CHECK
press start/copy key display show LOST INK CHECK [1]-[2]
press 2 display show SET LOST CNT
press start/copy key display show LOST INK= (here you enter the last left side two digit which you remember for example 42)
press stop two times
and unplug fax and plug again now your fax machine is okkkkk
NOTE:- If you can't get the success first time you must try until you get the success because this is the only way to get success
Jun 11, 2012 | Canon FAX-L250
Marantz SR7400 AV Surround Receiver wont switch keeps converting to standby and reading check pow5
try a hard reset
leave the unit unplugged for one night and then switch it ON
Oct 07, 2008 | Marantz Televison & Video
Tip
Unable to open .PPS attachments directly from Windows Mail in Windows Vista
To resolve the issue, follow these steps:
For .PPS files (Microsoft PowerPoint Slideshow)
· Click Start, type regedit.exe and press ENTER
· Navigate to the following branch:
HKEY_CLASSES_ROOT\PowerPointViewer.SlideShow.11\shell\Show
· Right-click Show and click Rename
· Type the word Open so that Show is replaced by Open command
· If you have PowerPoint Viewer 2007 installed, repeat the above steps in this key, as well:
HKEY_CLASSES_ROOT\PowerPointViewer.SlideShow.12\shell\Show
· After changing Show to Open, close Registry Editor window.
For .PPT files (Microsoft PowerPoint Presentation)
HKEY_CLASSES_ROOT\PowerPointViewer.Show.11\shell\Show
HKEY_CLASSES_ROOT\PowerPointViewer.Show.12\shell\Show
on Apr 27, 2008 | HP Pavilion a1410n (ER890AA) PC Desktop
Power 5 fault on marantz sr7400
Service manual says that POW5 error is because bad 5volts supply but could be something else. Check all supply voltages.
Jul 29, 2011 | Audio Players & Recorders
Our Marantz SR7400 displays check Pow5 when turned on for a few seconds and then dissapears and unit doesn't turn on. We unplugged it and wated and plugged it back in. Same message. we changed the...
pow5 - your receiver has an internal problem, most likely with power supply unit. As soon as macroprocessor detect the power problem it shuts down the receiver. Check the power supply at first.
Jan 08, 2011 | Audio Players & Recorders
When I turn on the receiver it displays check pow5, then returns to standby mode. SR7001 Marantz Unit
I have the problem of check POW5 too and have the similar procedure taken several times but it doesn't help. What actually problem I have encountered? Or the quality of this brand is not reliable? Does any body help?
Aug 09, 2010 | Audio Players & Recorders
Need some basic show command to troubleshoot
mode exec user Router)
ping ip
show ip route
show version
traceroute ip
mode exec priveligiado
show arp
show interface
show protcols
show ip protocols
show startup-config
erase startup-config
reload
Jul 27, 2010 | Cisco ASA 5520 Firewall
I have a Marantz SR-5600 surround Receiver. It has been shutting off the volume at various intervals recently. When I attempt to turn it back on a display reads " Check POW5
The POW5 fault indication means that the 5Volt power supply grid is not OK. The unit needs to be repaired by a professional repair engineer. No user servicable parts inside.
Jul 19, 2010 | Marantz SR-5600 Receiver
What is the error POW 5 on a marantz sr 7500
I have a POW 5 failure on a marantz sr 7500. Anybody know how to fix?
Jun 02, 2009 | Marantz SR-7400 Receiver
Try resoldering the main bridge rectifier on the power amp circuit board. You will have to remove the board from the heat-sink. The rectifier is mounted off the side of the board and screwed to the back of the heat-sink. Resoldering this usually cures that problem.
Oct 07, 2008 | Televison & Video
Computers & Internet Logo
27 people viewed this question
David Payne
David Payne
