Question about GolfBuddy World GPS Range Finder - GB4-UNIT-WORLD
Touch screen is not working
Screen not reacting to touch. Have tried rebooting and added all recent updates. Giving distances and menu and back buttons work but have to hold down the power button to shut off as screen is unresponsive
Touch screen not working
Well, if you touch screen is giving you trouble is because something happened to your phone, meaning it felt or hit it onto something. They don't go wrong because they feel like it. Something must to happen in order for it to react. If you want me to give a solution please let me know what happened to the phone.
Mar 29, 2014 | Samsung GALAXY S4
You will have to make sure all the drivers are installed and if it is not working because an updated added incompatible drivers you will need to do a system restore back to the date the touch screen was working and do not update those drivers for the touch screen.
Jan 21, 2014 | Lenovo Computers & Internet
Just had a strange problem with PS3 trying to play Clash of the Titans bluray. Started fine, played first two previews/commercials completely, then blank screen and won't react to controller commands. ...
first before it even gets into first preview start hitting the fast forward or next button untill you get to root menu or you can try hitting the green triangle button and try menu button but i had same problem and skipping forward worked for me
Aug 26, 2010 | Sony Playstation 3 (PS3) Console
The touch screen does not reacted when touched. The battery is fully charged and the software has been updated.
These units have a common problem with touchscreen failures. Please see this link for more info and how to have it repaired:
http://www.sharc.net/gps_LCD_repair.htm
Jun 11, 2010 | Garmin Nuvi 660 GPS Receiver
The touch screen isn't responding very well, sometimes it will react to a tap but mostly the screen is non responsive, the keys work ok when scrolling on a menu screen. any ideas?
first try to calibrate the touch screen.Take all games out turn on then go to the very small ds on the bottom touch screen. If you can't touch it move it with the cross down then hit a. Then select the option all the way to the right it looks like cross hairs that's the calibration screen fallow instructions. If that doesn't fix it it could be a broken screen or a loose ribbon.
Feb 24, 2010 | Nintendo DS Lite Console
Is my iPod touch bricked? It is unresponsive
Well if its not responsive ya I am afraid its bricked. You might want to try to recover but it seems like you did that already i hate to spread bad news.
thanks please rate
Oct 03, 2009 | Apple iPod touch
Screen Replacement Problems
have just installed a new screen, all good, reset using the sleep and menu button at same time for 10secs, but the screen doesnt react to touch... no reaction at all?? just the screen safer and security code request, cant get any further?? any suggestions, thanks for your time pete
Aug 01, 2009 | Apple iPhone Smartphone
I don't have any voice and the touch screen is slow
kaelor, Yes, that would be my first instinct.. that is if I was in a shop with spare parts lying around.. but I'm guessing your not so... 1st off we are only talking about the touch screen's respones time right? You said the enter button is slow to react as well.. so that makes me think keypad too. If both are reacting well, then try resetting the user data. yes, all of your POI's would be erased if you did this.. so if you can't afford that to happen , then don't do this. 1. At user menu (upon initial boot) 2. press + key and repeat (on top) button 3. select reset user data, then select the verify yes button. 4. unit will reset, post back on here and let me know if this worked.
Apr 14, 2007 | Magellan RoadMate 700 GPS Receiver
LCD screen will not respond to touch
First of all examine the LCD connecting flexible strip. If faulty or broken, let me know. Sivaram.V videolabs@gmail.com
Jan 08, 2007 | Sony DCR-HC18E Mini DV Digital Camcorder
GolfBuddy World GPS Range Finder - GB4-UNIT-WORLD Logo
70 people viewed this question
Top GolfBuddy Photography Experts
Tony
Are you a GolfBuddy Photography Expert? Answer questions, earn points and help others
