Question about GE JBP64 CleanDesign Electric Kitchen Range
Reinstall oven door on GE JBP64 oven?
I can't get the door hinges to catch when reintalling the oven door.
2 Suggested Answers
tunde007
  • 2382 Answers
SOURCE: install oven door jgs968. I have removed door,
Hi, to re-install the door, read page 34 of the user manual of the oven on this LINK......
It will definitely help.......
Posted on Dec 22, 2010
Installing lower oven door on GE profile gas oven`
Removing or Reseating Oven Door To remove most oven doors:
  1. Open door to the BROIL POSITION, where you feel hinge catch slightly.
  2. Place your hands on both sides of the door near the handle.
  3. Lift the door up and away from hinges.
  4. If the door does not readily lift off, there may be 2 phillips head screws on the inside of the door down near the hinges that are holding it on.
To replace the door:
  1. Place your hands on both sides of the door near the handle.
  2. Resting door against knee, line up door with hinges and slip into place.
For instructions specific to your model, check your Owner's Manual or Installation Instructions. Download a copy of your Owner's Manual and/or Installation Instructions
Aug 11, 2016 | GE Profile 30" Self-Cleaning Freestanding...
Clean inside door
take door off oven, usually has a catch on hinges when fully open then close to 80% and take off.
Lay door flat on bench with handle overhanging bench.
disassemble inner and outer.
CLEAN
reassemble.
reinstall.
Oct 14, 2013 | Miele H4082BM Oven
Opening door catches
pull down the door hinges there is a slot turn it and it will lock the hinge put the door back on turn the slots back
Dec 01, 2012 | Neff B1421 Electric Single Oven
I ordered and received a replacement door for my 2002 spacemaker ge microwave. The lady I spoke with said I would be able to install it myself. I figured there would be directions in the box explaining...
HELLO.
Below is the solution to replace your microwave door.
Unplug the oven from the outlet and/or shut off the gas valve. Open the old door completely and unlock the hinges by pushing the hinge out toward you and down toward the door. Slightly close the door and lift the door up and toward you.
Install the new door. Make sure the wall oven door hinges are aligned to go into the rectangular wall oven slots. Place the hinges into the slots. The hinges should "catch" on the slots comfortably.
Ensure the door is fully opened and push the hinge locks into an upright position. The two hinge locks should rest on top of the two hinges that are inserted in the wall oven slots.
Close the door and open it several times to make sure the door is properly opening and closing. Replug the oven back into the outlet and/or turn the gas valve back on.
Thanks.
Sep 25, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
Westinghouse oven does not close fully.can door hinge be adjusted?
If it has a drop down door, the only solution is to replace both door hinges, if it is hinged on one side, then the door catch, or door striker could be worn, these are easily replaced,
Please rate my solution.
Thanks.
Oct 31, 2009 | Ovens
Oven door hinge detached from the oven
Pull the door completely off and re-insert the door on the hinge supports.
May 23, 2009 | GE Ovens
Kitchenaide KGST307 cracked inner oven window.
Open your oven door and look at the hinges. You should see a drop down thumb lock on each hinge that you pull down and after you do so, lift up on the door as to close. The door will catch on these thumb locks and then at this point continue to lift up on the door as you pull the door out at the bottom. Reverse directions to reinstall.
Apr 05, 2009 | KitchenAid KGST307 Gas Kitchen Range
How do you install oven door on Beaumark Model 13340-1
Figured it our by myself - the 2 hinges (long and short have to be "hooked" together and then inserted into the oven hinge opening.
After I solved it found the solution is also posted on appliance repairs- how to remove and install oven door. It also posts pictures.
http://www.applianceaid.com/oven-hinges.html
Jan 23, 2009 | Ovens
GE OVEN/RANGE INSIDE GLASS ON DOOR SHATTERED.
You will need a window pack, part number WB56T10152 which is not hard to replace. You should be able to order it right from GE, or an appliance repair firm can get it for you, often without extra shipping if they can combine it with other parts they need to order. Should set you back just over $100. You can remove your oven door to make it easier to work on. Use a little screwdriver to pull down the little square hole you will see on the top of the hinge opening on the frame of the oven on each side. That little metal part will lock the hinge open. Next, lift on the door and pull it toward you. The hinge actually stays with the door and lifts right out of the rectangular opening in the oven frame. Reverse procedure to reinstall repaired door.
Nov 29, 2008 | Frigidaire FEF336BC Electric Kitchen Range
GE JBP64 CleanDesign Electric Kitchen Range Logo
73 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Craig Butler
Craig Butler
Are you a Kitchen Range Expert? Answer questions, earn points and help others
