Question about Sewing Machines
A "clunking" noise when stitching
Don't really hear a "knocking" noise as described in other notes; it is more like a metallic clunking when sewing; just sounds like something is loose, but machine is stitching fine. The noise is more evident when I am chain stitching and there is no fabric under the foot.
  • Sewing Machines Master
  • 7,365 Answers
Some sewing machines have more sounds than others, check to make sure the bobbin is setting securely in the bobbin case,and if that doesn't
solve the noise problem then ,it would be a good idea to have the machine serviced
Posted on Dec 31, 2012
bargainbox
  • 1388 Answers
SOURCE: tension
As this happened mid project, I would pay most attention to check the top tension for lint or thread...........this full process of elimination ought to cover all possibilities.
Ensure that all is clean and free of lint and jams, this is the most likely cause....now for tension troubleshooting .......
This solution is for tension problems...if you cannot form any sort of stitch, the issue is quite different, so please let me know if you need a different problem solved.....
It is quite long, but just work through each section in order.
The "knotting up" can reveal a lot. If you have loose threads on one side or the other, the tension on the opposite side will be the culprit.
QUICK SUMMARY FIRST:
Ensure sharp new needle,
Thread guides and Bobbin are Clean & Clear of lint
Set Top Tesion to 4 ....then....
Balance Bobbin to suit.
TOP THREAD TENSION:
If the looping threads are on the underside as you sew, it is the top tension. Top tension ought to be between 4 & 6 (this variation to allow for the different weights of fabric in your
projects).
IS YOUR NEEDLE SHARP ?
If you are using a needle that has seen quite a deal of work, or you suspect it may be blunt, change it for a new one !
TOP TENSION & GUIDES:
Make sure that when you thread the machine the presser foot is up so the thread goes between the discs and not to one side, top tension between 4 and 6, and that you have threaded through all the guides, including the last one, usually on the needle arm, just above the needle clamp.
It may be there is lint trapped between the discs, this will keep them slightly apart and reduce the actual tension, sometimes dramatically.
If tensions appear correct, and the thread is definitely in the channel between the discs, but still too loose and looping, try raising presser foot and remove your thread.
Now, with a 2" (50mm) wide strip piece of fabric 8 - 10" (20 - 25cm) moistened with methylated or denatured spirit, gently insert the fabric strip and clean between the discs with
a see saw / to and fro action.
In the worst cases, gentle use of a needle to pick & remove the jam may be necessary, but be very gentle and make sure the tension is set at Zero and the presser foot is raised, (to
disengage tension plates).... do not gouge or score the plates, they need a polished surface to work correctly.
BOBBIN TENSION:
Far less common, but if the loose threads are on the top, it is bobbin tension that is loose, it too may have lint in the spring and be giving a "false" tension.
I would not recommend fiddling with bobbin tension without good reason, it may end up with missing small screws and spring pieces, however, you can take the needle plate off to clean
the hook race area (where bobbin case sits)
...this is just good housekeeping, my wife does this every time she replaces the bobbin....
just take it out and clean the bobbin case and the fixed metal hook race with a small brush to remove lint. If there is a significant amount of lint, use a vacuum and small brush to get the worst.
Then wipe all this area with a cloth or cotton bud (Q tip) moistened (not soaked) with methylated spirit, especially if there appears to be fine dirty deposits....oil and lint combine to conspire against you.
If it seems likely that you ......really ....do .....actually .....need .....to adjust the bobbin case, first check there is no lint trapped in the metal spring where the thread is tensioned.
TOP LOADER:
Drop-in Bobbin case will look similar to this image with the tension screw in the middle of the metalwork....
4c76dc1.jpg ...the other screw at one end is holding it all together, so beware....it is not a tragedy to undo the whole lot and clean it, but very gingerly and lay the bits out in sequence and orientation, or you risk tearing your hair out !
FRONT LOADER:
....this is a bobbin case from a front loading machine and works in a very similar fashion to the top loader with drop in bobbin, again, if you dismantle it, take care so you can put it all
back properly.
165ca5c.jpg FINISHING UP
GETTING THE BALANCE RIGHT:
When you are certain there's no trapped lint in top tension or bobbin, set the top tension to 4 and the bobbin tension to a point where you just begin to feel resistance.
Try using good quality thread of contrasting colours so you can more easily spot the changes.
Set your zigzag to one width less than maximum (eg. 5 of 6 ...or... 4 of 5 etc) and sew a sample for a few inches and check the result.... adjust the bobbin tension screw very little at
a time, perhaps 1/16 of a turn.
You may find you are playing with this balance for some little while and if you are putting the needleplate on and off each time begin to think it cannot be correct to do this.....BUT....it is,
and eventually, you do get a "feel" for the correct tension and then it happens quite quickly.....as a user you won't be doing it very often unless there is lint built up (or are there small hands at work around the house !?!?!)
OTHER ISSUES:
If you live near the ocean as we do, salt air can play havoc with metalwork inside and out, so to help minimise this, keep a few small packets of dessicant (silica gel) in your machine
case....no case ? then make some sort of cover !
Same applies in any damp or humid environment, keep your machine dry and dust free.
Budget for a proper full service every couple of years (more often if heavily used) and if you don't use your machine for a few years, be aware that old oil will dry out and combining with
dust and form a "clag" like glue (another reason for some sort of cover, even a teatowel !)
FINALLY, A WORD ON THREAD:
If it is worth spending the time, energy and money on making something that you would like to give lasting enjoyment......use quality thread, .......it may seem to cost a little more at the
time, but the results, ease of use and added longevity will be worth the extra, and as a bonus, your tension troubles may be fewer and further between, because there is a more consistent diameter with good thread, and less compensating to be done by your tension plates and less thread breaks !
Posted on Jun 24, 2008
bargainbox
  • 1388 Answers
SOURCE: My bottom thread is loose when sewing a straight stitch
Please TRY the solution BEFORE giving your considered rating.
TOP THREAD TENSION:
projects).
BOBBIN TENSION:
TOP LOADER:
FRONT LOADER:
back properly.
OTHER ISSUES:
Posted on Jul 24, 2008
bargainbox
  • 1388 Answers
SOURCE: singer 237 stitches loose on bottom of fabric
Specific detail on bobbin case adjustment (with picture) near halfway down reply, the remainder will help you achieve a balance of top and bottom tensions.
TOP THREAD TENSION:
If the looping threads are on the underside as you sew, it is the top tension. Top tension ought to be between 4 & 6 (this variation to allow for the different weights of fabric in your projects).
Now, with a 2" (50mm) wide strip piece of fabric 8 - 10" (20 - 25cm) moistened with methylated or denatured spirit, gently insert the fabric strip and clean between the discs with a see saw / to and fro action.
In the worst cases, gentle use of a needle to pick & remove the jam may be necessary, but be very gentle and make sure the tension is set at Zero and the presser foot is raised, (to disengage tension plates).... do not gouge or score the plates, they need a polished surface to work correctly.
BOBBIN TENSION:
TOP LOADER:
FRONT LOADER:
back properly.
OTHER ISSUES:
bargainbox.com.au
Posted on Sep 02, 2009
  • 96 Answers
SOURCE: stitching loose. won't thread the fabric
try to rethread the machine all the way back to the spool of thread and check the top and bottom tensions on scrap of same fabric
Posted on Dec 13, 2009
  • 11 Answers
SOURCE: How do I fix thumping/clunking sound?
make sure your needle is facing the right way, some needles if you look at the front and back you will see a groove side and a flat side sometimes it is hard to tell the difference depending on needle style.. hold it up to light and look at it from the side the difference will be slight but you will see a difference groove should face the back or if your presser foot is out of wack (lol so technical terminology) it could cause needle breaks and noise you can detect damage to the presser foot if this is happening.... only other thing i can suggest is to make sure bobbin is securely snapped into the housing if not it can cause problems with the needle picking up the bobbin
Posted on Apr 08, 2010
My singer heavy duty 5532 makes a knocking noise when I use the decorative stitches
check thread and make sure thread has been in its threading slot in your bobbin case
Mar 23, 2016 | Singer 5532 32-Stitch Heavy Duty Sewing...
My singer curvey 8763 is making clunking noise when start sewing and then stop working
possibly out of time with the bobbin . take in to a shop for checkup
Feb 05, 2015 | Singer Sewing Machines
Sewing machine clunking and missing stitches
the best advice is having the machine serviced, but here are some other suggestions
Jan 29, 2014 | Sewing Machines
Loose top thread bernina 1008, tension problem but no solutions yet...
Are you sure you are getting the top thread between the tension discs? You should be able to tell the difference when you lower the pressed foot.
Jan 27, 2013 | Bernina 1008
I'm trying to get my mother's Singer Touch & Sew Deluxe 645 to sew a straight stitch. I don't want to buy a manual since the machine rarely gets used and I have limited time to "fix"
Not much information to go on. What do you mean it won't sew a straight stitch. It just won't sew a straight line? It won't form a stitch? What?
Dec 12, 2012 | Singer Sewing Machines
Loud clunking noise when sewing. . . then it starts to stutter then it stops & gives me an error. It doesn't occur when reverse sewing though
try these suggestions
change the needle
rethread the machine top & bobbin
make sure to use every thread guide
make sure the bobbin is not damaged or warped
make sure the bobbin is not over full
make sure the bobbin is inserted correctly into the bobbin case
make sure the bobbin case fits securely into the machine unless it's
a drop in bobbin
if these suggestions don't help then the machine may need to be
checked at a repair shop
Sep 11, 2012 | Brother CS6000i Computerized Sewing...
Sewing machine won't stitch
try changing the needle
if the suggestions don't work, it's possible that the machine
may have jumped time,, taking it to a sewing machine shop
the technican can tell you for sure
Jul 27, 2012 | Sewing Machines
My brand new Janome Sewist 500 is making noise - it's clunking as I sew. I'm sewing two layers of cotton twill, stitch A, length 2, tension 5. Help!
have you checked to see if the bobbin is in the bobbin case correctly
is it still under warrenty? you might want to take back to the place you bought it from & let them check it
Mar 09, 2012 | Janome Sewist 500 Sewing Machine
Distorted embroidery with Designer SE
have you tried changing the needle
try rethreading the machine top & bottom
also clean under needle plate area & bobbin area for loose threads & lint
Jan 27, 2012 | Husqvarna Designer I
The lower thread does not bring up , so that the uper thread does not come in contact with the lower thread .I hear unusaul noise while sewing.All these happend when I tried to sew a jeans .i used a thread...
As a general rule, domestic machines don't like buttonhole twist, that heavy yellow thread you see on the RTW jeans. Sometimes you can put it through the bobbin but use a regular weight thread on top but this means sewing upside down as you'll want the yellow on top. And lots of machines dont like different weight thread top and bottom so it just makes for awful stitching anyway.
Best solution to top stitch jeans is use a regular weight thread, large size jeans needle but thread up two spools of thread on the top with both threads going through the same needle eye. It still may not solve the problem though.
To your machine, firstly change the needle as it may be bent. Then unthread the machine and manually turn the flywheel through a stitch cycle and listen carefully, if you still hear a noise as the needle touches the rotary hook, you've knocked the timing out. Service man visit time.
Probably if you check the manual, it will say 50 weight thread, and you'll need to stick with that in the future.
Those big industrial sewing machines that they top sew jeans on are very different to a domestic SM, many make a chain stitch or fell the jeans seams and are very heavy duty.
Jun 05, 2011 | Toyota STF17 Sewing Machine
Sewing Machines Logo
325 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
