Question about Toshiba Satellite M65-S821 Notebook
Webcam problem when i start my webcam i see nothing but green and bluish verticle lines throughout the entire screen and my viewers also see the same thing please help i am an online teacher and this means no work untill i repair this problem,is there something i can do to repair it or can i get another cam and plug it into the usb?please help me ,thank you,Anastacio Rangel
Jumping lines throughout the screen affecting quality of picture
You didn't say weather the lines are verticle or horizontal, but if the lines are verticle check the circuit for a weak capacitor or if the lines are check the horizontal circuit for a weak capacitor. During your check check for cold solder joints, idf you come across ant re-solder then. Good luck.
Jan 27, 2011 | Pioneer PRO-520HD 53" Rear Projection...
Wen i installed my new logitech webcam 300. everything installed properly. but wen i use the camera a whole bunch of white lines run up and down the screen. verticle lines. ive tried changing settings, but...
Try to rotate the web camera lens adjustment knob. It controls the images quality of the camera. It is located in the front face of the cam. But if nothing happens right then take your camera back from the store you bought it.
Dec 23, 2009 | Logitech Webcam
Bluish green colour vertical line is coming in my
Your laptop screen has been faulty. you can checked it from service center.
Nov 13, 2009 | Dell E173FP 17" LCD Monitor
My picture turns to "Green Screen" while video calling on Skype..
sometimes i get similar effects when i use skype or MSN my view goes yellow i think it is due to the age of the model of the webcam, so i recommend getting a better one. If the problem persists then maybe the graphics arent that good with the webcam or the software is dodgy. hope i helped!
Apr 30, 2009 | Logitech Webcam
Screen on my extensa 5630 laptop shows nothing but verticle lines
I had to finally send the machine to ACER and it was a hardware problem; they have to change the cable linking the display with the MB
Mar 22, 2009 | Acer Extensa 5630-6806 Notebook
Laptop lcd screen
that's not a firmware issue..your lcd is starting a slow decay to final unhappiness..
you can try the old driver downloader trick, but it's just a matter of time now.
Feb 21, 2008 | LG Flatron L1750S 17" LCD Monitor
LG DU-42PX12X Verticle lines of various colors, and widths throughout the screen.
Check within you area for a reliable LG repair center. To fix the problem of the blue, red or green vertical line you just need to replace the control board PN 6871QCH038C. The part cost about $150.00 and a honest repair center should not beat you up to bad on the labor. Good luck and Good viewing.
Feb 06, 2008 | LG DU-42PX12XC 42 in. Plasma HDTV
Green verticle line on Maganavox flat screen tv
Most likely it's due to the LCD panel assy failure. It may cost you as much as to buy a new tv. The LCD panel is very expensive in retail market.
Jan 24, 2008 | Samsung LTN1535 15 in. HD-Ready LCD...
Polaroid LCD only shows green verticle lines?
your picture tube is not blown you are having problem in the color circuit there is an ic that controls that circuit,the tv is also having a vertical problem an ic also controls that circuit you will have to call a tech to repair your tv good luck
Apr 27, 2007 | Polaroid FLM-2011 Television
Toshiba Satellite M65-S821 Notebook Logo
55 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
