Question about Samsung DV328AE Electric Dryer
Samsung dryer is showing TO, what does it mean?
Dryer shuts off after a few minutes and TO signs appear,
  • Samsung Master
  • 8,220 Answers
Dryer thermister is open. Thermister Open. Thermisters will change in resistance with temperature changes. The control relies on reading from this thermister so it can make a determination of whether or not to turn the heat on. If it is open then the control don't know what the air temp is inside the dryer and therefore it shuts down and declares an error. The thermister is mounted on the blower where it gets the air coming out of the drum on the way out the back. The fuse is right next to it. I bet you would like a service manual wouldn't you? SAMSUNG DRYER MANUAL
Note: dryer error codes are on page 32.
Posted on Dec 31, 2012
3 Suggested Answers
SOURCE: have a retangle showing as the dryer ends it dry
I have the same problem with my dryer. I noticed this rectangle that showed up on time dry and there wasn't any code that matched this in the manual. I called samsung and they told me to flip the breaker and see if that helps. I have not tried another load, but I hope that fixed it.
Posted on Dec 21, 2009
  • 71 Answers
SOURCE: My dryer runs for a minute or so and shuts off and
This is an issue with the thermostat. It will need to be replaced .
Posted on Oct 25, 2010
I have Samsung gas dryer model DV410. no heat, replaced two thermal fuse and hi low limit. Now it only works with timed cycle mode. the rest mode, it runs only for least the 5 minutes and shut off.
timed cycle mean dryer not on sensor dry mode. check wire connection on moisture sensor bars (i think you forget to put 2 wire connector put together). when you use other cycle dryer use moisture sensor to dry cloths so sensor not working dryer will stop in 5 minutes or so because dryer think there are no wet cloths to dry. hope this help you.
May 02, 2017 | Samsung Dryers
Dryer shuts off within a few seconds and smell burning
That's a sign your motor is bad. Soon it won't start at all.
Mar 13, 2014 | Maytag MEDC300XW - 29", 7.0 Cu Ft, He...
Samsung dryer DV218AEB shuts off in middle of dry cycle - "dead" mode
This is a sign of a bad motor. There is an overload protector on the motor that when the motor overheats it shuts the motor down.
May 01, 2012 | Samsung Dryers
Heat shuts off after a few minutes
Check Replace Thermostat. The Dryer Thinks Its Not Lighting Because The Thermostat Isn't Working.
The Dryer Has A Safety Mechanism So It Wont Flood Your Home With Gas. When The Thermostat Is Broken The Unit Doesn't Detect The Heat And Shuts Off The Gas.
If You Like You CV
Jan 09, 2009 | GE DBXR463EBWW Electric Dryer
THE KENMORE DRYER I HAVE... IF REN IN THE COTTON CYCLE IT WILL RUN FOR 50 MINUTES AND SHUT OFF. ITS BOLWING HOT AIR AND THE OTHER CYCLES SEEM TO WORK FINE WITH OUT SHUTING DOWN SO ID APPRECIATE A TIP ON WHAT THIS PROBLEM COULD BE
May 17, 2008 | Dryers
Samsung DV328AE Electric Dryer Logo
285 people viewed this question
Top Samsung Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Samsung Dryer Expert? Answer questions, earn points and help others
