Question about Sungale DVD-2026 DVD Player
Error message: error data
Dvd will not play movie. get the error, error data
Netflix error 1810
Try clearing data on browser, each are different so try googling steps to clean or clear data, if this does not work
Silverlight installed to play netflix on computers & laptops might be the problem.
The Silverlight plugin, which Netflix uses to play movies and TV shows on your computer.
This error is usually caused by one of three things:
  • A computer setting preventing Silverlight from storing files it needs to play your movie or TV show
  • An issue with the Silverlight plugin itself
  • An issue with the content you're trying to play.
  • Try re-installing uninstalling then reinstalling silverlight.
Hope it works for you, best of luck.
Jun 22, 2014 | Netflix Computers & Internet
Tip
When you try to play a DVD game on Xbox 360 it tries to play as a movie?
c on your Xbox 360 console, you may receive an error message. This article presents step-by-step guidance to help you determine whether your disc is playable.
SYMPTOMS When you try to play a disc, you may receive the following error message: Can’t read this DVD.
CAUSE The DVD or game disc may be dirty or damaged. Because the console cannot read the disc well, it may even mistake a game disc for a DVD and report this error. If this problem occurs with multiple discs, even clean and undamaged discs, there may be a problem with your Xbox 360 console.
Note If you receive a different error message, such as one of the following messages, the problem is a different problem:
Error message 1 Can't play DVD. Wrong region code. Error message 2 Can’t play DVD. Family settings restrict playback of this DVD. If you receive one of these error messages, see the corresponding Knowledge Base article: 907620 While attempting to play a standard DVD movie using your Xbox 360 console, you receive the error message: "Can't play DVD. Wrong region code" 908645 While attempting to play a DVD movie using your Xbox 360 console, you receive the error message: "Can’t play DVD. Family settings restrict playback of this DVD"
THINGS TO TRY Here are some things that you can do to try to fix the problem or to determine what caused it.
Determine whether the disc is dirty or damaged Discs that are smudged, scratched, or otherwise damaged cannot be read by the Xbox 360 console. You will want to examine the disc to see whether it has smudges, scratches, or other damage. To do this, follow these steps: 1. Examine the disc for dirt or damage: a. Pick up the disc by its edges. Do not touch the top or bottom surface. b. Examine the shiny side of the disc to make sure that the disc is clean and has no damage.
NoteScratches that follow the curve of the disc are very damaging and prevent a disc from being read. If your disc has even one of these kinds of scratches, the disc is damaged, and you will no longer be able to play it. If this is the case, see step 4. 2. If the disc is dirty, clean the disc by hand: • Use a soft, clean, dry, chemical-free cloth to clean the disc. • Lightly wipe from the center of the disc outward. 3. After you clean the disc, try to load it in the Xbox 360 console. If the disc still will not load or you receive the same error message, the disc is damaged, and you will no longer be able to play it. If this is the case, see step 4. 4. If the disc is damaged, do one of the following: • Because DVD discs are not game discs and the disc was damaged because of misuse of some type, such as not storing the disc in its case, the only thing that you can do is buy a new one. • If you feel that the disc was damaged by the Xbox 360 console in some way, please contact Xbox Customer Support. To do this, please visit the following Microsoft Web site: http://www.xbox.com/support/contact
on Feb 18, 2010 | Video Game Consoles & Games
CDS BURN BUT CANNOT PLAY WHY?
You mean, you burn the CD in your PC but you can't play it in external CD player ?
Maybe you didn't burned it in "movie" mode, just burned in "data" mode. As you know, CD player can't play .avi or .mkv or other video formats. They only can play movie in .DAT format, and when you burn in "make a movie" mode, the burner will convert your movie to this format so you can re-open your movie via CD player.
Or there is an error during the burning time, if this happen then you have to re-burn your movie into another CD.
Hope this help and be kind to rate this answer.
(^_^)
Jan 06, 2011 | LaCie Dupli DVD121 DVD±RW Dual Layer...
Cannot play dvd movie at media player 12
What happens?
What does not happen?
What do you expect to happen?
What error-message(s) do you get?
Does the DVD-movie play in some other DVD-player or some other computer?
Apr 03, 2010 | Acer Aspire One A150-1006 Notebook
When i put an Xbox 360 game in it tries to play it as a DVD movie. please help!!!
When you try to play a DVD movie or an Xbox 360 game disc on your Xbox 360 console, you may receive an error message. This article presents step-by-step guidance to help you determine whether your disc is playable.
Feb 18, 2010 | Microsoft Xbox 360 Console
No File and Disc Error message
clean dvd first with cd cleaner.. before you change optical lens. lens cannot read data on your disc.
Sep 09, 2009 | Televison & Video
DVD SKIPPING
Try DVD player laser lense cleaner.
Jul 10, 2009 | Panasonic PVD4744 DVD Player/VCR
"0 not found" Error message when using DVD player on laptop
This is generally an indication that the DVD end of the drive is going out. First try a different or updated DVD decoding software. It could just be a simple glitch with the software, or that the software is outdated.
Jul 14, 2008 | IBM ThinkPad T43 Notebook
Bush television & DVD error message 'unknown disk'
Some units jusy won't play certain types of recorded DVD discs. I would transfer one to a DVD+R type and see what happens. Buy a good brand like Memorex.
Hope that helps...
Geno
Mar 24, 2008 | Computers & Internet
No data disc error
not all dvds will play in a ps2 some have different formats than others
Mar 23, 2008 | Sony PlayStation 2 (PS2) Console
Sungale DVD-2026 DVD Player Logo
20 people viewed this question
Top Sungale Televison & Video Experts
janman
Chris Baker
Chris Baker
Level 1 Expert
Are you a Sungale Televison and Video Expert? Answer questions, earn points and help others
