Question about Vizio L32 32 in. LCD HDTV
My Vizio 32" lcd is hung with message "there is no device connected to tv" and the remote will not work so I can push "exit" button shown on screen. Any way to get out of this?
SOURCE: Vizio LCD DTV 32 inch. Model L32. I can't 'scan'
Follow up on No DTV tuner after unplugging it a month for vacation. After I let it set plugged in for about 2-3 days it started working normally again and has been fine ever since. I hope this may help someone else. Genez 6-7-09
Posted on Jun 08, 2009
SOURCE: Vizio 32 and Direct TV remote codes??
Oh Boy Good Day...code 10056 worked for me...FINALLY...have been searching codes for 17 months...cheers thanx ever so parseeker :))
Posted on Oct 18, 2009
budmrtn
  • 11361 Answers
SOURCE: Vizio TV won't turn on
The power supply will be the first place to look, look for burnt parts, bad capacitors, etc. Look for 5vdc, 12vdc, and 24dvc.
http://en.wikipedia.org/wiki/Capacitor_plague
Parts: http://www.shopjimmy.com/catalogsearch/result/?q=l32hdtv10a
Please post back what you find.
Posted on Dec 24, 2009
  • 76 Answers
SOURCE: My Vizio remote doesn't work...
I know that on the Logitech Harmony Remotes, sometimes the infrared LED emitters go bad. Perhaps that is what is happening to your Vizio remote. If everything was working just fine but now none of the buttons work, it is probably your issue. You can test to see if the LED(s) are working by using a digital camera (or cell phone camera). Here is link that describes how to test to see if your IR emitters are working. Although you have a different model, you may be able to pick up a few tips from this article. Good luck!
http://hubpages.com/hub/HowToFixaLogitechHarmony880Remote
Posted on Mar 02, 2010
eagle338
  • 4889 Answers
SOURCE: my vizio flat screen tv
You have faulty electrolytic caps in the power supply section of the tv. Capacitors with reduced quantities of electrolyte take longer to charge compared to normal ones. That is the reason its coming on after you repeat the on/off sequence a few times. If you are not good at soldering, replacing the power supply should do the job. It should cost you about 75-100$. Let me know if you want to do it yourself(please get me the model number of the set as well so that I can find you a replacement).
Sai.
Posted on Dec 28, 2010
How do you get the menu/factory display off TV screen to get tv to work?
To exit the factory mode, you should have its remote control. If you wish to buy its original remote control, contact the authorized service centre, or authorized dealer to your device brand. They can either give you a genuine remote control to your device, or can direct you, from where can you purchase a suitable one.
Without its remote control, no other way. Contact the authorized service center.
http://electrohelponline.blogspot.com/
Jul 25, 2014 | Vizio P50HDTV10A 50 in. Plasma HDTV
I have a Vizio Model XVT3D554SV TV that uses a bluetooth technology remote. I have been unable to get the MX 500 to learn from the TV remote and cannot find the code for the TV. I would like to use the MX...
2. Auto Scan With Three-Digit Number
You can also program your remote control by sending out a
series of Power Off commands for different brands stored
in the library by using the following steps. This is similar
to the first method, except it is easier to move through all
of the device codes for your device and make note of each
one that turns your device OFF.
1. Manually turn on the device you plan to operate.
2. Go to the SETUP mode by pressing both the MAIN and
ENT buttons simultaneously for three seconds.
3. Press the P-PRO button next to the LCD screen.
16
17
4. Programming the MX-500TMto Control Your Components
4. The remote will be flashing "SELECT BUTTON".
Press the device you wish to program. (For example, to
program TV, press the TV button.)
5. The remote will be flashing "FROM TABLE". Select the
device from which the scanned code will be selected.
(Important: If you have already relabeled your device
keys, your LCD screen will not look like the illustration
above. Select the appropriate LCD button for the "FROM
TABLE" using the labels as shown in the illustration on
page 11 of this manual. For example, if you have relabeled
AUX as LIGHTS, you would still push the bottom-left
button to access the AUX Code Table.
6. Point the remote control toward the component and
alternately press the UP (or DOWN ) button on the LCD
and the Power button. If the right code number is sent, the
component will turn off right after the code number is
transmitted.
(Please press the UP (or DOWN ) button within 20 seconds
of beginning programming, otherwise the remote will
revert to the SETUP menu, and then after a period of time,
it will go back to the MAIN device page.)
18
7. Confirm that it is the right code by pressing the Power
button. After you have confirmed that the right code is
entered, save the code by pressing the SAVE button on the
LCD.
8. Confirm that you entered the right code number that
matches your component by pressing other functional
buttons. If any of the buttons do not operate, as they
should, please repeat from Step 1.
9. Continue to program other components by repeating
from step 1 above.
10. You can press EXIT at any time if you do not wish to
proceed.
11. Exit from Preprogrammed mode by pressing the MAIN
button and then exit from the SETUP mode by pressing the
MAIN button once again.
Sep 14, 2011 | Universal Remote Control MX-500 LCD Remote...
My Vizio, when I turn it on the Vizio turns white, but the screen is black and there is no sound coming through
Have you tried hitting the 'input' button on the remote control?
Check the connections of external devices like an antenna, satellite, or cable that may be connected to the TV.
Press the TV button on the top of the remote to return to the TV mode if you have changed modes.
May 04, 2011 | Vizio 42 in. LCD TV
Remote stopped working Got new remote and it
It can be the IR remote receiver board inside the TV. Is the new remote setup for VIZIO TV?
Old VIZIO remote is bad for sure?
Testing remote control:
The remote control puts out IR (InfraRed) signal that human eyes cannot see, to find out if the remote is sending out the signal or not you just point the remote at the digital camera's Lens (Digital Camera can detect IR), you should see flashing light on the camera's screen when any one of the remote button is pushed. If you do see the flashing on the camera, then the problem is in the TV IR receiver or the main logic board; more troubleshooting with scope will be needed to look at the signals.
Parts: www.shopjimmy.com
Dec 03, 2010 | Vizio L32 32 in. LCD HDTV
Screen
try unplugging th tv for 30 second and then turn it back on that should work =]]
Mar 26, 2008 | Vizio L32 32 in. LCD HDTV
Vizio L32 HDTV 10A-remote
Try a new Remote control, and if that doesn't fix the problem, it may be a remote sensor in the set. Hope this helps. Have a great weekend
Ed
NC Electronic
Mills, Wyoming
Jan 06, 2008 | Vizio L32 32 in. LCD HDTV
Code for Vizio tv
I contacted Vizio the other day. They tell me that they use the same generic codes as LG. I have Suddenlink Cable, formerly Charter, so I still use the Charter remote. My remote only needed 3 digits and I have noticed that many need 4 or 5. I can tell you that the LG code worked for my tv. I can power on/off, volume, and change the channel. All other functions require the manufacture's remote. The code I used is 005. There was also 004 but that did not work on my tv. Hope this helps someone!
Dec 26, 2007 | Vizio L32 32 in. LCD HDTV
Vizio L32 32 in. LCD HDTV Logo
402 people viewed this question
Top Vizio Televison & Video Experts
CoppellTVRepair.com
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
